Repeat Program
Hi guys. i need help with a program
basically i need a program for my irrigation system.
The program needs to open a shut off valve first then start zone 1 for 5 min then move to next zone, total 5 zones, then repeat the whole process 4 times and after the Repeat command is completed, i need to close the shutoff valve.
I can get almost everything to work but i don't know how to execute an order only when the Repeat cycle is completed.
To end a repeat cycle add a "Repeat 1 time" to the end of the repeat body. Then you can add another program line to shut off your valve.
Edited by andyf0
The only place where i have to add the "Repeat command" is at the end and none at the beginning?
You said you had it working apart from the last command to close the valve.
Open Valve
Repeat 4 times
  Start Zone 1
  Wait 5 minutes
  Start Zone 2
  Wait 5 minutes
Repeat 1 time
  Close Valve
Edited by andyf0
Thank you for the explanation sir, one last question. It would matter if i put Repeat 4 time at the end or it has to say Repeat 1 time, i just wonder what would happen.
Only statement that occur after the Repeat command are repeated.
