Insteon 2868-222 Unsupported Device
captainc
I am trying to add a Insteon 2868-222 siren and I get the error message :
Unsupported device:7.30
- Cannot add insteon device
I have the 994i pro with 4.5.4 UI and firmware.
I have tried it at both my houses with the same ISY setups and cannot add the device.
Any recommendations?
The 2867-222 Alert Module is also not supported yet.
Both are going to be in version 5. I believe the next Alpha release was mentioned but I am waiting for at least a version 5 Beta release.
Thanks, any idea about when, just wondering if I should return this or keep it.  Aging smarthome firmware has given me headaches.
The Alpha could be any time but I feel not too much longer. A Beta maybe a long way away.
Good though on aging firmware.
Though it will not add them. I have seen enough information using the Start Linking method to see the firmware reported version. In the Event Viewer Level 3.
From the ones I have.
My two from late last year are v45. My recent ones are v46.
The latest v46 have issues manually linking to a Mini Remote I am using to test them for now. Mini Remote too close to the Siren Module when manually linking. The Enable Disable link causes it to lock up and go dead. LED out Mini Remote flashes LED for no response. Move it to the other end of the house and link it. Worked fine.  Once linked they can be next to each other no problems.
  • 4 months later...
is there any info on how to get the siren to work with isy , meaning changing of the sounds for entree detected.
volume control
as of now the only application for this device through the isy is siren.
Kind regards
Mike
