EZ-Flora pump change?
It used to be that if you highlighted an EZ-Flora and hit options you would get a choice between Zone8 being PUMP or Zone8 being NORMAL.  The NORMAL choice no longer appears  in my UI (4.5.4)
Am I missing something?
It appears in my Console with Firmware v.4.5.4 on UI v4.5.1 and UI 4.5.4.
Which Firmware are you running?
I'll go back and check my UI.  I'm on 4.5.4 but my UI might be behind.
Just to clarify - you see both the NORMAL and the PUMP choices?
[Edit] Confirmed - it works with the newer UI.  Thanks!  I hadn't considered that it would work with an older one and a newer one but not with the one I had.
mark
Edited by MarkJames
Actually, I noticed something afterwards...
My screen is a 32" BenQ (3840x2160).  The popup box that the UI was putting up was too small for all the elements to show up so the 'normal' and the 'pump' buttons were superimposed and looked like 1 button.  I stretched it out and they were both there all along.
I'm not sure why these are buttons, though.  Seems radio buttons would be a better choice here as this is an either/or proposition.
mark
