February 26, 20179 yr I'm trying to see Multisensor 6 values in ISY using Trend (Chart) tool. I can see 'Status' and 'Humidity' but I get blank for 'Current Temperature'. I'm on ISY firmware 4.5.4 and Multisensor 6 firmware 1.0.7. Is anyone able to see the temperature values for the Multisensor using the Trend (Chart) tool?
February 26, 20179 yr Hi, First of all, thanks for asking the question. I've never used this feature of the Admin Console. I am using the same ISY firmware, but not sure at the moment what the version of my Multisensor 6 firmware. I can get a graph of "Current Temperature", "Humidity" and "Status". None of the others show any graphs. Here is what it looks like. My graphs actual show the day I moved the sensor outside to my garage. I will have to check out a wiki if there is one for this feature. I'm not familiar with getting a shorter time axis. I'd like to just see my latest day broken down into hours/minutes. PhanTomiZ
February 26, 20179 yr Hello all, Unfortunately chart feature is set to be removed (just like the floorplan) simply because you can do the same using Excel and the logs. With kind regards,Michel
