All of a sudden can't access Admin Console reliably
ISY finder doesn't pick it up either.
Router shows it in IP list. I have an app running on a server ("Venlink") that allows ISY to communicate with thermostats - this is unable to work also.
Sometimes (1 in 20 attempts maybe) you can get Admin Console to come up. Same with web-ajax access. Same issue on multiple machines. All access is on same LAN.
Reset all switches / router / on network, reset PC, reset ISY multiple times.
Reseated micro sd card, let it sit a few minutes unpowered. Worked the first time, then no go after that. Things seem to work normally if you can access it.
Any ideas? I'm afraid it might be dead or dying.
EDIT: Solved. Router has developed a bad port. Intermittent issue. Lovely...
Edited by telljcl
I'm having similar issues, the last 2 weeks.
