andyf0 Posted April 20, 2017 Posted April 20, 2017 The portal web access tool seems to take forever to display all the devices when using "Chunked Data". I can literally sit and twiddle my thumbs while waiting for the display to come up. Switching back to Default seems to make it much faster, maybe 1 second or so.
MWareman Posted April 20, 2017 Posted April 20, 2017 The portal web access tool seems to take forever to display all the devices when using "Chunked Data". I can literally sit and twiddle my thumbs while waiting for the display to come up. Switching back to Default seems to make it much faster, maybe 1 second or so.It was reported that the portal does not yet support it, and if you are a portal user chunked encoding should not be enabled yet.
andyf0 Posted April 20, 2017 Author Posted April 20, 2017 The last portal update added support for Chunked Data. Previously, it didn't work at all.
bmercier Posted April 21, 2017 Posted April 21, 2017 Yes, I confirm chunked encoding is now supported. I will investigate the response time. Thanks, Benoit 2
bmercier Posted April 23, 2017 Posted April 23, 2017 Response time with chunked encoding should be faster than without it. I measured it with my own ISY in the prod environment, and for /rest/nodes, it was 20% faster. I was getting 850ms from request to completed response, vs 1.05s without chunked encoding. That's the round trip from browser< -> ISY Portal <-> ISY. While testing I found a subtle bug that was fixed this morning. This may be what you experienced. Benoit
