Aeotec LED bulb
ArunGupta2014
Here it is with lamp ON at 100%.
-<node flag="128" nodeDefId="UZW004E">
<address>ZW018_1</address>
<name>Aeotec LED Lamp Left</name>
<family>4</family>
<parent type="3">46817</parent>
<type>4.17.1.0</type>
<enabled>true</enabled>
<deviceClass>0</deviceClass>
<wattage>0</wattage>
<dcPeriod>0</dcPeriod>
<pnode>ZW018_1</pnode>
<sgid>1</sgid>
-<devtype>
<gen>4.17.1</gen>
<mfg>134.259.98</mfg>
<cat>109</cat>
</devtype>
<ELK_ID>E13</ELK_ID>
<property uom="" formatted="100%" value="100" id="ST"/>
</node>
-<node flag="0" nodeDefId="UZW004F">
<address>ZW018_186</address>
<name>Aeotec LED Color Left</name>
<family>4</family>
<sgid>186</sgid>
-<devtype>
<gen>4.17.1</gen>
<cat>186</cat>
</devtype>
<ELK_ID>E14</ELK_ID>
</node>
<family>4</family>
<sgid>1</sgid>
-<devtype>
<gen>4.17.1</gen>
<cat>109</cat>
</devtype>
</node>
<family>4</family>
<sgid>186</sgid>
-<devtype>
<gen>4.17.1</gen>
<cat>186</cat>
</devtype>
</node>
I can fix the on level, but the UOM of the object is not displaying "51" (Percent) This indicates that the device is dimmable in my app.  If there are other ways I will keep my ears open, but for now not sure how to detect that option for that type of device.
I also observed that if I use the ISY web interface (http://<ISY addr>/WEB/udajax.htm), I can dim and brighten these bulbs. Does the ISY web interface use a different API than Agave? I am not sure what UOM is but it keeps changing as I change the brightness level. I am assuming that UOM indicates the current brightness level. So, if I took the node dump with bulbs at 100%, UOM would be 100%. When I took node dump with brightness set to 50%, UOM was 50%.
Arun
5.0.10 fixed both the issues.
Another observation: I have created a scene with two Aeotec LED bulbs. The scene does not show the slider to dim/brighten, I have to go through button press which takes several minutes to go from 100% to 30%.
01. Can a slider be provided to dim/brighten the scene?
02. Can the dim/brighten be speeded up?
Arun
      37.3k
      373.8k
