MagicHome LED WiFi Controller
OK so, I've gotten theMagicHome LED WiFi Controller to:
Turn On
Turn Off
Turn Blue
Turn Red
Turn White
Tur Cyan
But I cant find the commands anywhere for anything else? Dim.  Mode, Speed, Fade? Here are the commands in case anyone would like them, also it Must be in Binary Mode, Port 5577 (See example of ON command)
Any help would be appreciated:
Turn On
Turn Off
Turn Blue
Turn Red
Turn White
Tur Cyan
Thats because mode, speed and fade/dim don't exist. Read my other threads about the MUFO.
Just send whatever R/G/B/WW/CW bytes you want it to be.
There are effects and a speed control for them but mostly useless.
I have discovered the brightness levels work well with the squares of 0-10 for a nice small stepped ramp.
I am using python3 so don't try this at Home ISY.
In view of the constrants you shouldn't need more than off, dim, med, bright anyway.
