Dim/brighen via google home
So, I noticed that I can dim/brighten devices but not scenes, tried on multiple devices and it works and also on multiple scenes and it doesn't? I read in the wiki that I should be able to dim or brighten scenes?
Sent from my Nexus 6 using Tapatalk
Unfortunately, it's not possible to brighten/dim scenes with Google Home.
The Google Home API only allows to set an absolute brightness, which cannot work with a scene.
You may notice that you can brighten or dim a regular light, but under the cover, GH determines what the absolute level should be and sends that command.
Benoit
Edited by bmercier
Thank you, I will just have to create a scene with levels I need.
