Updated ISY, updated Z-Wave firmware, now devices show a red exclamation mark?
Last night I upgraded my ISY to 4.5.4, and then  I proceeded to "Upgrade Z-Wave Firmware" as well.
Now, when looking at my devices in the Administrative Console, they are unresponsive and show with a ! beside them. I tried restoring the ISY but no luck.
I can't get anything to respond. Any ideas?
What does 'restoring the ISY? mean? IIRC the admin vonsole does not have that option.
Did you mean something else?
Sent from my SGH-I257M using Tapatalk
I went to "File > Restore ISY" and choose a backup that was made prior to upgrading to see if that would help.
Hi DarkCanuck,
When you upgrade the firmware on the Z-Wave dongle, Unfortunately you lose all the data which you cannot restore unless you have backed up the dongle. The question are:
Why would you upgrade the firmware?
Had you ever done Z-Wave / Tools / Backup any time before upgrading the Z-Wave firmware?
I didn't think that upgrading the Z-Wave firmware would have wiped everything; I thought it was just a simple firmware upgrade like every other device. Lesson learned (the hard way) I guess.
...and no, I've never done a Z-Wave > Tools > Backup before.
That being said, I assume I need to delete all my devices (I only have 5), Add/Include them all again, and then update my programs to make sure they're using the newly added devices?
Hi DarkCanuck,
Unfortunately so. But do Z-Wave / Tools / Synchronize / All rather than deleting nodes. This will Synchronize ISY with your dongle.
I was afraid of that. Haha.
Thanks so much Michel, you've been a great help!
Hi DarkCanuck,
After reading this post, I did the Z-Wave / Tools / Backup.  Where does this backup get saved?
As I understand it, once you do a Z-Wave backup it becomes part of your next ISY backup. If you add another Z-Wave device you need to perform another backup before it becomes part of your next ISY backup.
