understanding scenes
experimenting /learning
so lets say I am using and ISY and have two SLs and an RL, and create a scene. There appears to be three different ramp and brightness levels
If I click on the SL I can set Brite and Ramp applied locally, so I guess this is when I physically press the SL?
then I can set scene brite and ramp, but this one I don't totally understand, because...
I can also set the RL key I have attached to that scene at yet another brite and ramp level, so does this mean that the levels are unique to that RL button?
if I were to have and add a Keypadlinc, would that button I assigned to the scene also have a unique brite and ramp level assigned to it?
so both the scene and any controller have separate levels?
and the reason the scene has separate levels is if the scene is called from a program? If I have it correct then there are a lot of choices, a little confusing, but I guess more control is better
Thx
Joe
Hi Joe,
Yes:
1. Each controller in a scene can have different on level/ramp rates for any of the other controller/responders in the same scene. This way, your Entrance and Exit buttons could have different effects while both controlling the same set of lights
2. The Scene itself could have different on level/ramp rates for all the members in the scene. These settings are used when you use the scene in a Program
3. If you want all of them to have the same effect, apply the changes to the scene first and then, for each controller, click on Copy Scene Attributes from ....
Thx
Joe
Thanks! I am sloooooowly getting it, but so far (when I got past the X10 dead PLM issue) I am pretty impressed with both Insteon and ISY
THx
Joe
and I now see that more than one RL button cannot be added to the scene, so only one controller per scene?
Joe
Hello Joe,
No, you can have multiple controllers per scene except for buttons from the "same" RLs and CLs (ControLincs).
The work-around is to make a new scene with the same responders for each button.
Rand
