Aeotec MultiSensor 6 strange behavior with ISY
I have an Aeotec MultiSensor 6 ZW100-A sensor that I have connected via Zwave to my ISY -- I've been playing with it (including and excluding it multiple times) and I noticed some strange behavior -- if I include it as a non-secure device I get 4 devices - Multilevel Sensor, Motion Sensor, Binary Sensor, and Tamper Alarm.
This is different from what I get if I include it as a secure device:  Multilevel Sensor, Motion Sensor, Tamper Alarm, and sometimes a Glass Break Sensor, Tamper Code Sensor, and one other (can't remember now).   I'd expect to see exactly the same sensors and values whether the device was as a secure device or insecure device.
Has anyone else seen this sort of behavior?
Mitch
I can't remember if I added all three of mine in secure mode or not and I don't know how to check after the fact.
I am also using 5.0.10 and I get all six devices you mentioned: binary sensor, glass break alarm, intrusion alarm, motion sensor, tamper alarm, tamper code alarm. One of mine will give me a seventh, low battery, even though it says the battery is just at 50%
I assumed this is just the way the battery operated devices work in that you'll only hear from those z-wave components when they get triggered. I have some garage door sensors that I really had to shake around to get all the features to register
This morning I got a new device on one of my Multisensors - an energy meter. It registers as zero watts
I used to get spurious devices on these Multisensors as well.  Running firmware > 5.0.9 allows you to suppress these using the following menu: Z-Wave | Options | Freeze ISY Nodes.  I haven't seen anything but the devices shown in the screen shot since.
Good to know, thanks
FWIW today one of my two devices is showing Moisture as a %.  0 to 10% shows one decimal place then integers to 100%.  Firmware 4.5.4.
I have one that has been showing up as a pulse sensor and within the multilevel sensor display I have seismic intensity and sometimes have a tank level datapoint. I have another one that has never displayed anything "abnormal" so far, but I've only had them in the system for a couple weeks.
Edited by tommyrob
