problem with Aeon in-wall micro switches
I have a problem with 4 out of 5 of the Aeon in-wall micro switches (2nd edition, not dimmer, no metering) that I own.  I had 4 of them (that were previously working on my Vera) paired to the ISY, and for a number of reasons decided to reset everything and start over from scratch - now I have almost all of my other dozens of zwave devices working except for those 4 switches.  The one I didn't have paired originally works fine, but the others are acting very weird - they are now configured for a momentary switch (have to flip the switch twice to get the lights to turn on/off) and won't respond to on/off commands.  I also have a few 1st gen aeon micro dimmer in-wall units (with metering) and they're working fine.
Any help would be greatly appreciated!
Josh
Unfortunately they no longer respond to exclude or include at all, even with the isy right next to them. I've got a zstick somewhere that I'm going to try and connect them to that when I find it and get the software set up to see if I can get into them that way.
I'm hoping that there's a way to hard reset them (by hand), hard to troubleshoot as it is now.
Thanks for your help!
-Josh
Is there a way to factory reset them?  I can't find anything in the manual.
Got it!  I tried turning the breaker off for one of the switches for a full 24 hours, once I powered it back up I was able to exclude/include.  I repeated the process with the other units and they're all working again.
-Josh
