Web Power Switch 7
khargy
Can't really get it to do anything... I just want basic controls... not sure if the Rest API is the right approach or not...
Can't figure out how to authenticate myself? I try:
http://admin:XX@192.168.1.xxx
in a browser and it just redirects me to the login page.
I tried the curl example from the documentation:
curl -H "Range: dli-depth=1" -H "Accept: application/json" --digest 'http://admin:xxx@192.168.1.xxx/restapi/'
and I just get back:
<HTML><HEAD>
<META HTTP-EQUIV="refresh" content="0; URL=/">
</HEAD><BODY></BODY>
You do a GET request for
/outlet?7=ON
/outlet?7=OFF
/outlet?7=CCL
You have to put
Authorization: Basic [token]
in the header where [token] is the Base64 of the USERNAME:PASSWORD
You can't do username:password in modern browsers as that feature was removed a log time ago.
Also, the Power Switch 7 does not support the restapi.
Edited by Gary Funk
Ah perfect that worked! Also it didn't help matters that the outlet I was testing and I thought was empty was actually controlling my ISY :)
Lol oops! Glad Gary got you sorted out. Also look at "auto ping"
Thanks, I've used the "auto ping" feature when I used to have some web cam that's would get stuck and then I would power cycle them as needed.
I wanted to set this up in the ISY to I can use the Echo for control over the switches.
