rvandersteen Posted August 31, 2017 Posted August 31, 2017 Has anyone gotten Google home to work win the FanLinc or Thermostat??? Quote
asbril Posted August 31, 2017 Posted August 31, 2017 Has anyone gotten Google home to work win the FanLinc or Thermostat??? This may not be exactly what you are looking for, but my two Google Home devices work generally well with my 4 Zwave fan switches as well as with my 2 Nest thermostats. Sometimes GH does not recognize my speech and I need to repeat command. Quote
apostolakisl Posted August 31, 2017 Posted August 31, 2017 I don't know about the portal, but IFTTT can do all REST commands. So, yes, you setup an IFTTT account, link it to your google home, and use a webhook to set whatever you want on the ISY. Quote
Jimbo.Automates Posted August 31, 2017 Posted August 31, 2017 Has anyone gotten Google home to work win the FanLinc or Thermostat???Using the portal I control the fanlincs by adding spokens for the low, medium and high scenes, that's the only way I know of. Thermostats are not directly supported thru the portal, Michel has said they are working with Google on it. Sent from my Pixel C using Tapatalk Quote
rvandersteen Posted August 31, 2017 Author Posted August 31, 2017 Thanks for the info! I was able to set up a single fan variable and then use the spoken "set to X percent" to set the variable. Behind the scenes in the ISY, I have a state variable that sets the Fan speed to off, low, med, high. Sent from my iPhone using Tapatalk 1 Quote
Michel Kohanim Posted August 31, 2017 Posted August 31, 2017 apostoloakisl, Not sure what you mean by : I don't know about the portal, but IFTTT can do all REST commands. So, yes, you setup an IFTTT account, link it to your google home, and use a webhook to set whatever you want on the ISY. Google Home is natively supported by ISY Portal. Why do we need to use IFTTT? With kind regards, Michel Quote
apostolakisl Posted August 31, 2017 Posted August 31, 2017 apostoloakisl, Not sure what you mean by : Google Home is natively supported by ISY Portal. Why do we need to use IFTTT? With kind regards, Michel I already had IFTTT running before the portal. Quote
MWareman Posted October 1, 2017 Posted October 1, 2017 Thermostats now officially supported! http://forum.universal-devices.com/topic/22581-google-home-thermostat-support/ Quote
