Z-Wave Dongle Not Responding
Good Morning,
I have an ISY 994i/IR PRO w/ the Z-Wave module added on.  I recently updated to v4.6.2, and after the upgrade, I noticed that under the Z-Wave Menu, it says:  ! Z-Wave Dongle Not Responding and below that is an option to upgrade the Z-Wave firmware.
When I attempt to upgrade the firmware, it runs for several minutes until showing me an error saying the update failed.  I've included the relevant log data from the system.  Any ideas?
Mon 09/04/2017 11:07:42 AM : Z-WAVE FIRMWARE UPGRADE (0)
[Z-WAVE FIRMWARE ] FIRMWARE VERIFY: VERIFYING
Mon 09/04/2017 11:07:43 AM : [Z-WAVE FIRMWARE ] FIRMWARE VERIFY: VERIFYING 0 ...
Mon 09/04/2017 11:07:43 AM : [Z-WAVE FIRMWARE ] FIRMWARE VERIFY: VERIFYING 100 ...
Mon 09/04/2017 11:07:43 AM : [Z-WAVE FIRMWARE ] FIRMWARE VERIFY: VERIFYING 200 ...
Mon 09/04/2017 11:07:43 AM : [Z-WAVE FIRMWARE ] FIRMWARE VERIFY: VERIFYING 300 ...
Mon 09/04/2017 11:07:43 AM : [Z-WAVE FIRMWARE ] FIRMWARE VERIFY: VERIFYING 400 ...
Mon 09/04/2017 11:07:44 AM : [Z-WAVE FIRMWARE ] FIRMWARE VERIFY: VERIFYING 500 ...
Mon 09/04/2017 11:07:44 AM : [Z-WAVE FIRMWARE ] FIRMWARE VERIFY: VERIFYING 600 ...
Mon 09/04/2017 11:07:44 AM : [Z-WAVE FIRMWARE ] FIRMWARE VERIFY: VERIFYING 700 ...
Mon 09/04/2017 11:07:44 AM : [Z-WAVE FIRMWARE ] FIRMWARE VERIFY: VERIFYING 800 ...
Mon 09/04/2017 11:07:44 AM : [Z-WAVE FIRMWARE ] FIRMWARE VERIFY: VERIFYING 900 ...
Mon 09/04/2017 11:07:44 AM : [Z-WAVE FIRMWARE ] FIRMWARE VERIFY: VERIFYING 1000 ...
Mon 09/04/2017 11:07:44 AM : [Z-WAVE FIRMWARE ] FIRMWARE VERIFY: VERIFYING 1100 ...
Mon 09/04/2017 11:07:44 AM : [Z-WAVE FIRMWARE ] FIRMWARE VERIFY: VERIFYING 1200 ...
Mon 09/04/2017 11:07:45 AM : [Z-WAVE FIRMWARE ] FIRMWARE VERIFY: VERIFYING 1300 ...
Mon 09/04/2017 11:07:45 AM : [Z-WAVE FIRMWARE ] FIRMWARE VERIFY: VERIFYING 1400 ...
Mon 09/04/2017 11:07:45 AM : [Z-WAVE FIRMWARE ] FIRMWARE VERIFY: VERIFYING 1500 ...
Mon 09/04/2017 11:07:45 AM : [Z-WAVE FIRMWARE ] FIRMWARE VERIFY: VERIFYING 1600 ...
Mon 09/04/2017 11:07:45 AM : [Z-WAVE FIRMWARE ] FIRMWARE VERIFY: VERIFYING 1700 ...
Mon 09/04/2017 11:07:45 AM : [Z-WAVE FIRMWARE ] FIRMWARE VERIFY: VERIFYING 1800 ...
Mon 09/04/2017 11:07:45 AM : [Z-WAVE FIRMWARE ] FIRMWARE VERIFY: VERIFYING 1900 ...
Mon 09/04/2017 11:07:45 AM : [Z-WAVE FIRMWARE ] FIRMWARE VERIFY: VERIFYING 2000 ...
Mon 09/04/2017 11:07:46 AM :
[Z-WAVE FIRMWARE ] EEPROM VERIFY: VERIFYING
Mon 09/04/2017 11:07:46 AM : [Z-WAVE FIRMWARE ] EEPROM VERIFY: VERIFYING 0 ...
Mon 09/04/2017 11:07:46 AM : [Z-WAVE FIRMWARE ] EEPROM VERIFY: VERIFYING 100 ...
Mon 09/04/2017 11:07:46 AM : [Z-WAVE FIRMWARE ] EEPROM VERIFY: VERIFYING 200 ...
Mon 09/04/2017 11:07:46 AM : [Z-WAVE FIRMWARE ] EEPROM VERIFY: VERIFYING 300 ...
Mon 09/04/2017 11:07:46 AM : [Z-WAVE FIRMWARE ] EEPROM VERIFY: VERIFYING 400 ...
Mon 09/04/2017 11:07:47 AM : [Z-WAVE FIRMWARE ] EEPROM VERIFY: VERIFYING 500 ...
Mon 09/04/2017 11:07:47 AM : [Z-WAVE FIRMWARE ] EEPROM VERIFY: VERIFYING 600 ...
Mon 09/04/2017 11:07:47 AM : Z-WAVE FIRMWARE UPGRADE
[Z-WAVE FIRMWARE ] FIRMWARE UPDATE: UPDATING
Mon 09/04/2017 11:07:48 AM : [Z-WAVE FIRMWARE ] FIRMWARE UPDATE: NOW UPDATING - DO NOT TURN OFF ISY
Mon 09/04/2017 11:08:29 AM : [Z-WAVE FIRMWARE ] FIRMWARE UPDATE: CANNOT GO INTO PROGRAMMING MODE
Mon 09/04/2017 11:08:50 AM : [ZWAVE           ] Factory Resetting Z-Wave dongle
Mon 09/04/2017 11:08:50 AM : [ZWAVE           ] Setting our application node info
Mon 09/04/2017 11:09:26 AM : [ZWAVE           ] Factory Reset of Z-Wave dongle failed
Mon 09/04/2017 11:09:39 AM : Restarting the Z-Wave dongle
Mon 09/04/2017 11:10:12 AM : Z-WAVE FIRMWARE UPGRADE PROCESS STOPPED (Failed)
Have you tried rebooting the ISY? I had mine get into that state a while ago and it fixed itself through a reboot.
Thanks!  That did the trick.  I had previously tried rebooting through the GUI, but doing a full shutdown seemed to fix it.
