JayC Posted October 12, 2017 Posted October 12, 2017 I am looking for suggestions on a in floor receptacle that Is able to support a decora outlet so that I could use an Insteon outlet. Does anyone use anything worth the ~$50+ price tags?
Goose66 Posted October 12, 2017 Posted October 12, 2017 Is the outlet underneath furniture? I connect the floor outlets in my living room via a 1 foot 3 prong extension cord to a LampLinc that sits under my couch or table.
JayC Posted October 12, 2017 Author Posted October 12, 2017 On 10/12/2017 at 5:47 PM, kingwr said: Is the outlet underneath furniture? I connect the floor outlets in my living room via a 1 foot 3 prong extension cord to a LampLinc that sits under my couch or table. Yes I will install it under the couch or sofa.
Goose66 Posted October 12, 2017 Posted October 12, 2017 The the LampLinc is a much cheaper solution and would allow you to use a conventional brass floor outlet with a screw cover, in case you ever need to sale your house.
johnjces Posted October 12, 2017 Posted October 12, 2017 You could use an Insteon Micro Dimmer or Micro On/Off module as it will probably fit inside the box behind or in your case, underneath the outlet. They are in fact quite small. Just watch your wattage as the on/off will do up to 100 watts as I recall and the dimmer only 200 watts. John
