Programming Schlage Deadbolt BE469NX via zwave
I have a schlage deadbolt BE469NX.
I'm running UD admin console 4.6.2.
I would like to change the delay before the deadbolt automatically relocks.
The default is 30 seconds.
Has anyone tried to do this - is it possible?
Thank you!
The Lock & Leave feature can be enabled or disabled, but the duration cannot be changed.
Thank you!
I'd like to change it to. 30 seconds is way to long but we've learnd to adjust our routine and move a little slower.
Sent from my Nexus 6P using Tapatalk
Unfortunately, 30 seconds is way to short, when opening the door, carrying food outside and reentering the house.
i'm thinking maybe i should take a single button insteon switch and have that operate a macro that disables the auto-lock feature while in off mode.
is that possible - any idea how I would programatically script the auto-lock off?
NW
NW
I have found no way to do what you are asking.
Easy, peasy. Set Auto-Relock to Off and use a program like the one below:
        Status  'LR / Devices / LR ZW006 Deadbolt' is Unlocked
        Wait  1 minute  <---use any wait you want
        Set 'LR / Devices / LR ZW006 Deadbolt' Lock
