Help needed with emoncms
Hi.
I have nodelink and emoncms running on raspberry.
Nodelink is configure on ISY according to instructions.
I've put in "Write API Key" from emoncms.
Under Node ID I have : ZW057_143.ST
Installed devices I have:
ISY Data
Data Logger
What else do I have to do(configure) so emoncms would recieve feed(data)?
Do I put anything in nodeling in :Use custom address.
Just started with nodelink so have no idea what I'm doing, forgive the ignorance.
Node ID should be 0, that's not where you log. It's a generic setup.
Custom address is IP address of your Pi.
ISY Data logs nothing to Emon. Data Logger will log the variables you create in it's config. If you want to see a Zwave device value, you'll need to copy it to a variable via an ISY program.
