Levition DZ6HD-BZ led dimmable switch and 994i ZW/IR Pro?
Hi, new to ISY and I just ordered the 994i ZW/IR Pro which is on the way. I would like to order some companion z wave led dimmable switches and I am thinking of the Levition DZ6HD-BZ as the look will match my existing Leviton switches. Any compatibilty issues with this switch and the ISY that I need to be aware of? Also can I run with the current stable firmware or do I need to try the 5.x alpha?
Many Thanks
Tony
Many Thanks
Tony
Not sure about the Leviton switches but if your want a stable and reliable system then stay with 4.6.2 firmware. The 5.x.x alpha is not recommended.
When buying Zwave devices  it's best to stay with devices that support the Gen 5 interface also know as Zwave+
Here's a link to Aeon Zwave products https://aeotec.com/z-wave-gen5
Edited by Techman
Thank you Techman, I'll stick with 4.6.2 as per your suggestion. As a noob to ISY I am looking fwd to coming up the learning curve. If I decide to give the Leviton switches a shot I'll report back as to their compatibility.
