Z-wave Plus Easy Install with PET Immunity Motion Detector with PET Immunity, White (PIRZWAVE2.5-ECO)
I have two of these Motion Detectors. I have created programs in my ISY Adm. Console so that when motion is detected a selected light goes ON for a set time.
However there is a lag of several times before the light goes on. Is there a way to change the parameters of the Motion Detector so that the light goes on immediately ?
what sensitivity setting are you using for the MS
Post a copy of the program you're using to turn on the light
Here is one of the programs.
The programs look OK
Being that these sensors are "pet friendly" I would assume that there's a built in delay or lag time in order to prevent a pet from triggering the sensor.
Have you tried tweaking the sensitivity setting on the sensor?
I remember setting it on highest sensitivity. Maybe I buy another brand and see if it works better. Can you recommend a good motion detector ?
T H A N K S
T H A N K S
Aeotec multi-sensor 6 (Zwave), available on Amazon. Works well with ISY.
