Z-Wave equivalent of Insteon 6 & 8 button dimmers
As I've been adding more and more z-wave the one thing I haven't found yet is an equivalent to the 6 and 8 button Insteon dimmers which I have used as scene controllers.
Does anyone have suggestions for Z-Wave scene controllers that will work with the V5 ISY firmware?
There really isn't such as yet. Inovelli is working on some designs but is very early in the drawing stage.
Sent from my SM-G955U1 using Tapatalk
There are no Z-Wave equivalent devices, but there are 4-scene controllers available. Actually, I just found a 5-scene controller, but the reviews are less than stellar.
  • 2 months later...
I've got a hybrid X-10 / insteon system.  one of the reason I am staying with X-10 as long as possible, is I like the quality and feel of the smarthome switchlinc X10 switches better than the insteon ones, and I I like my in all 5 button Leviton X10 controllers, much better than my 6 buttn in-wall INsteon controllers.  Anyone have any feedback on the build quality and feel of the Cooper  RFWC5WS in wall controller?
As you may have read in another thread, I purchased two of the Aeotech Wallmote Quad devices to give them a try as scene controllers.
Unfortunately, they aren't fully supported just yet, but I have been able to make them work using programs to control scenes and devices.
It's handy not having to have them installed in a wall. The reason I took the leap was because I needed something to control the multitude of fans I use for my indoor bicycle training setup. Needless to say, getting off the bike to push a button on the wall isn't really an ideal solution. The battery powered, portable, Wallmote was just the ticket for this use case.
I was looking at Aeotec this morning, they have some new devices.  Not sure if this helps but, one is a 4 button "Wallmote".  https://aeotec.com/z-wave-wireless-switch .  Not sure of the compatibility issue.  Maybe someone else can elaborate on their experience.
Hi jc986,
What's your ISY's firmware version?
  I'm running 5.0.11C
Hi jc986,
You should be able to use the Wallmote as a scene controller in an ISY Scene using native links, but you have to be sure the lamp/fan/etc. is compatible.  Using programs instead is obviously fine as well.
I bought the wall mote.  It works as a button etc. but,  I cannot light an indicator led like I did on the Insteon Keypad.  This is a significant down side for me, since I cannot provide feedback to the user.
Hi jc986,
  Chris,
Thanks, I will give that a try this weekend. I suppose that means that I won't be able to use the scene buttons in any ISY scenes that are mixed Insteon and -Z-Wave devices?
Would I also be correct in assuming that some of the other association groups will only work with native links as well?
