Motion sensor prgram dependent on other controllers
Is this the best way to write a program to turn on and off a motion sensor controlled light but only when that light is not already on via an RL or KPL? is there another way since if I add this light to another scene or add another controller to the scene I need to go back and add them to this program. No other way to write it independent of what is controlling "garage lite" ?
Control '11.A0.A5-Sensor' is switched On
And Status 'KPL A' is Off
And Status 'RL Backyard #1' is Off
And Status 'RL Backyard #5' is Off
And Status 'RL Backyard #6' is Off
Set 'Garage Lite' On
off:
Control '11.A0.A5-Sensor' is switched Off
Set 'Garage Lite' Off
You could put all your controllers in one program and then check that program to be true.
Status Off Check
       Status  'Family Room KPL 2' is Off
   And Status  'House Remote 2' is Off
   And Status  'Living Room CL 2' is Off
Motion On
       Control 'Motion Sensor 2-Sensor' is switched On
   And Program 'Status Off Check' is True
       Set Scene 'Kitchen Motion' On
Motion Off
       Control 'Motion Sensor 2-Sensor' is switched Off
       Set Scene 'Kitchen Motion' Off
Then you only need to maintain the Status Off Check program.
Rand
