MWareman Posted December 25, 2017 Share Posted December 25, 2017 Here is a simple KumoApp that sends a JSON POST from the Tag Manager (no need for firewall holes) to a specified IP (in this case 192.168.1.2 on port 5001): var tags = <#tags_[12|13|21|26|32|62|72]_N#>; tags.forEach( function (tag) { tag.updated = function () { var cur_name = tag.name var cur_rssi = tag.rssi; var cur_batt = tag.batteryVolt; var tag_moisture = Math.round(tag.moisture); var cur_temp = tag.temperature; var cur_temp_c = Math.round(cur_temp * 10) / 10; var cur_temp_f = Math.round((cur_temp * 9 / 5 + 32) * 10) / 10; KumoApp.Log("Temp F for "+cur_name+" updated to "+cur_temp_f); KumoApp.Log("Temp C for "+cur_name+" updated to "+cur_temp_c); KumoApp.Log("Humidity for "+cur_name+" updated to "+tag_moisture); KumoApp.httpCall("http://192.168.1.2:5001/", "POST", "{\"tag\": \""+cur_name+"\",\"humidity\":"+tag_moisture+",\"temp_c\":"+cur_temp_c+",\"temp_f\":"+cur_temp_f+",\"rssi\":"+cur_rssi+",\"battery\":"+cur_batt+"}"); }; } ); The idea would be for a NodeServer to receive these - and expose tags as nodes to ISY. I'm currently using this to get tag data into my ElasticSearch database, from where I can graph them... It would need fleshing out to modify the specific properties based on the type of tag.... Link to comment Share on other sites More sharing options...
MWareman Posted December 25, 2017 Share Posted December 25, 2017 Had a few mins this morning, and updated my ISY Kibana dashboard. I now have my zwave Thermostat, couple of Aeotec multi-sensors and 3 CAO tags all reporting temperature and humidity on the same set of graphs... It’s also interesting to compare what my Brultech GEM sees as total power usage vs the Zigbee ISY that is getting data from my ComEd meter.... they are pretty close to each other (within rounding errors) Link to comment Share on other sites More sharing options...
Michel Kohanim Posted December 26, 2017 Share Posted December 26, 2017 MWareman, This is absolutely amazing! With kind regards, Michel Link to comment Share on other sites More sharing options...
