Setting up an Open/Close sensor
born2dive
Hello,
I am trying to setup an Open/Close sensor (2843-222) to work with ISY.  I was able to link it (I think?) to the ISY.  I followed the directions to link a sensor and ended up with 3 new entries in my ISY: Open, Close, Heartbeat.  All 3 devices have yellow arrows next to them in the admin console which I have not seen before and I am not sure what it means (screenshot attached).
When I move the magnet away from the main sensor, nothing happens.  The status of all 3 devices remains set to "On".
What is the "Heartbeat" device used for?
How do I get/use the sensor's status from the ISY?
I looked around the forum and could not find an answer.
Thanks.
Hello,
Thanks.
2 things...
1- what's normal
  • Yellow arrow pointing right indicates a sensor input device.. that's as it should be
  • 3 devices
    • Open and Close indicate state, but the responses are opposite of each other
    • There really is no difference other than making a program more readable, looking for a door to open vs close.
    • A heartbeat message is sent ~ every 24 hours as a way to know the battery, or the unit died
    • You can write a program with a 24 hour wait and then a notification. If you get the notification a few times, the battery is probably going
  • Using the sensor
    • 'If control' program statements let you respond to the action of the door being opened or closed.
    • 'If status' program statements let you use the doors state, especially if timing is needed. We have long periods in the spring and fall when its nice out for a while, then its not. I use this for my doorwall is in open state for x minutes (along with month, outside temp and other factors) to shut off HVAC , as well as cancel my HVAC fan cycling programs.
2- what's not
  • The green light on the sensor body should blink once when you pull the magnet out of range and once when its back in range. Did that not happen?
  • Are there dual band devices nearby to carry the sensors signal onto the powerline or PLM?
Paul
Edited by paulbates
2 things...
1- what's normal
  • 3 devices
  • Using the sensor
2- what's not
Paul
Paul,
Thanks for the info. Very helpful.  Ultimately it ended up being a bad sensor.  I bought 4 and the other 3 are working fine.  I just happened to start with the faulty one.  Good info regarding the 24 hours program to check for battery.  So basically something like this:
If time is 12:00 AM
and Hearbeat is "on"
then
"Nothing"
Wait 24 hours
Send message
Thanks again for the info?
Glad you figured it out. I've had a bad one as well.
Here is the program that's worked for me. The hearbeat doesn't have an on/off state per-say. It sends a message every ~24 hours and is detected "If xx is switched on"
I give it 25 hours as its not always exactly 24 hours, 25 proved safely outside the window. The next message, ~24 hours later, restarts the program (until it doesn't, and falls through to the notification)
Battery Doorwall Heartbeat
        'Zystem / Battery Alerts / Doorwall Sensor-Heartbeat' is switched On
        Wait  25 hours
        Resource 'Pushover Doorwall Sensor Battery Low'
Paul
Edited by paulbates
      379.9k
