Set <XXXX lights> to X percent
Is it a device or scene? Just verified it works for me on a device.
Sent from my Pixel 2 XL using Tapatalk
Standard 2477d switch. Tried on all my switches . Nothing. I must have it setup wrong.
Sent from my Nexus 5X using Tapatalk
Weird, So you can turn it on/off but not set brightness?
I don't say "XXX lights" I just say "XXX"
no work that way either...  ???
The only response I get for a dim level is "It looks like that device is not setup yet, go to your google home app to setup devices" arg....!!
note:  Echo/Alexa works just fine.
Edited by James Peterson
I have both Alexa and Google home. Just tested the dimming by saying "turn dining room lights to 80%".
Can confirm that Google Home doesn't see the light as setup.
Can turn it on or off just not a %.
Alexa works in both scenarios.
One thing I just looked at is the way the portal (or I) set them up. In both cases they are set up as lights. I switched them to switches.
After pushing the commands and waiting 5 minutes. I get the same results.
Seems like it is a Google thing....
Sent from my Pixel XL using Tapatalk
