Missing Venstar TSTAT Outdoor Temp after Upgrade?
Sorry about that, was focused on fixing the Space Temp and forgot all about Outdoor.
Should be fixed in the next version, just waiting to see if I can figure out Larry's ecobee issue before releasing.
Sounds great io_guy, thanks again!
One more question that just occurred to me...  Will this outdoor sensor value reappear as a Temp Input option for the Auto Humidity Adjust?  That feature has worked very well for us, and I like the idea of having it use an accurate local temp...
I turned on the "Home and Hold" before verbose, during verbose, and no verbose again. I couldn't find the error in the log until I turned it off gain but two showed up  in the log, anyway..
attachicon.giflogfile_2018-01-03.txt
Bipto
. Sorry about hijacking this thread on you. I hope this results in some Venstar results for you, also. . io_guy has worked hard and some Venstar improvements have been noted  so far.
Not sure what to do with this one Larry.  I can't recreate it here at all.  Doing the same thing with two stats and setting a hold.  Is "Home and Hold" something special?
In the webpage app for ecobee click on the "Home and Hold" box. This is the same as sending a "Hold" via ISY -> NodeLink - stat.
Also to be noted when I change the climate mode it works but goes on Hold and is permanent. It overrides the schedule change time out.
Hi bipto
 I noticed you mentioning using outdoor sensor value as a Temp Input option for the Auto Humidity Adjust. Is Auto Humidity something that is available in the Venstar t7900 or is it done through ISY programming. I did see where the sensor can be defined as outdoor instead of remote as I have it set.
Gary
Hi bipto
Gary
The Auto Humidity Adjust is a NodeLink feature...
Just installed 0.8.12, looks like all's well with the Outdoor sensor node.  Thanks for all your hard work, io_guy!
--Bill
