Controlinc not showing in scenes?
I have a couple of scenes using a controlinc and the scene seems to work as it should . The problem is the controlinc does not show up in the list of devices added to the scene, even though it added to the scene just fine? The controllinc was linked to the ISY-26 quite a while ago, there have been many updates since then. Should I relink the controlinc to the ISY?
I have another question! I have a IOLinc and would like to know how the options for the sensor relate to the options for the relay? they seem to be the same.
ISY-26
2.7.2
Are you saying the CL is not in the tree view of the scene? A ControLinc will not be in the list of responders because it is only a controller. Other Controller only devices are RemoteLincs and MotionSensors.
The sensor does not have any separate options, the Option button is there so the function can be called when viewing either the sensor or relay.
Rand
