Networking Resources (Error TCP client request failed Net Module Rule: 34:406)
All I need to do is hit a specific website (e.g. http://www.my_domain.com/something/here.php)and I don't care if it returns anything or not (e.g. fire and forget).
If I set it up to hit www.google.com it works.  If I change the domain name to my domain (even without the path) it fails with Net Module Rule 34:406.
What am I missing?
Edited by cam
There is no authentication/data... I just need to simply hit a website that I own.
For instance, if I create a new resource to www.google.com (with no path) it runs just fine.  If I alter that resource and add /news to the path I get a Net Module Rule: 36 error.
For the life of me I can't remember how to copy/paste an image...
Top Section:  http GET Host www.google.com Port 80 Path /news [no encode] timeout 500 ms
Detail Headers
GET /news HTTP/1.1
Host: www.google.com:80
User-Agent: Mozilla/4.0
Actual
GET /news HTTP/1.1
I then Save/Save, click on the newly added resource and click test.  For this google example I get the errors Subscriber didn't replay to event 1 followed by TCP client resource moved Net Module Rule: 36
I have a hello.html file here:  http://www.justautomated.com/hello.html and it outputs <html><body>hi</body></html>.  Works great from any browser.
In NR I create a new resource with protocol information:
  • http
  • GET
  • Host: www.justautomated.com
  • Port: 80
  • Path: /hello.html
  • Timeout: 5,000
  • URL Encoded (I've tried it both ways)
I'm using default headers (didn't touch what ISY adds).
Error:  TCP client request failed [Net Module Rule:  36:406]
Just thought I'd update the thread...  apparently most hosting companies run mod_security (an Apache security module) that block inbound requests originating from an HTTP client (e.g. ISY network resources) if that client doesn't have a variety of HTTP header details (Michel posted a link to some of them).  I tried every combination of accept headers and I was never able to get the ISY to access my backend server.  I also tried to access wiki.universal-device.com using NR and that didn't work (I suspect due to the same mod_security reasons).
I gave up and routed the call from iRule for now...  If I get the time/patience I'll try it again and post an update.
Is the server not on the same lan as the ISY; you can’t use a local nat address (192.168.x.x or 10.x.x.x)?
I do have a server on my LAN but I'm working on some cloud-based automation and I need to execute a Network Resource on a remote/hosted server.
Can you get to https://google.com?
I was able to access google.com's home page without issue (they must have mod_security disabled and/or allow 3rd party non-browser clients (like the ISY) to connect.  I spent several hours late last night and found a solution to allow ISY calls to a remote server with mod_security enabled...  We're basically trying to trick the Apache server in thinking the ISY is a browser.  Here are the headers I set in the ISY Networking Resource to get it to work:
Accept: text/html
Accept-Charset: utf-8
Accept-Language: en-US
Content-Type: text/html
User-Agent:  Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/58.0.3029.110 Safari/537.36
