Dimming to fast ON?
Has anyone seen any issues when say dimming or brighten a single light with a 2477 when you stop at the desired level it will turn fast on to 100%? I am seeing this happen in my house a lot lately when trying to brighten from off. It happens on KPLs too and scenes so it’s not specific to just a single switched light. FW is v4.6.2
Are you using the paddle or a scene when that happens? What's the ramp rates (in the scene and locally)?
Both, around 4s - I like a smooth ramp rate. More on scenes. Also the ISY sees the end level percentage but then goes full on. Tried writing to the device/scene just to be sure but no change.
Edited by Scottmichaelj
What's the load? CFL and LED bulbs tend to not ramp up smoothly. Some of my LED bulbs use a 2 or even a 4 minute ramp rate.
Also, what's the starting/ending brightness level. The ramp rate is based on from full off to full on. A 4s ramp rate will go from 0 to 50% in 2s.
Edited by stusviews
There doesn’t seem to be any coronation between the load being off or at a certain brightness, say 30%. Same thing happens. The loads are all LEDs. The strangest part is the fact the ISY admin console does see the on level properly but then it will suddenly goes to full on. I have not tried to change the ramp rate to a slower setting though, might be a good idea.
This started happening to me immediately after I clicked on the "Never offer me Chrome browser again" option in my browser on more than 499 webpages. :)
You a goofball! [emoji13]
It doesn’t happen all the time but every once in a while it happens. It happened tonight but I just tried to replicate it and can’t get it to happen. I think Stu’s made a good point even if he didn’t mean too, lol. I will try and increase the ramp rate speed to make it slower to see if that helps. Maybe there’s a small micro delay and even though the ISY sees the right level it’s then thinking the button is still being pressed due to some type of lag in the system power line due to the LEDs. Making it slower might help resolve this.
My thoughts were if you are doing a slow ramp fingering you got contact bounce looking like a Fast On of Fast Off.
Yeah that’s not it. Tonight I set my lamps to 40% via MobiLinc and it did the FAST ON. I am not certain the ramp rate increase is the solution either.
Check your links between ISY and devices. Has to be a confused signal. You know what those are like. :)
