NodeLink docker update
NodeLink itself will auto-update with the option selected in the system config page.
The docker itself, you don't.  You'd need to rebuild the image and clean the container, which is a PITA.  I wouldn't bother.
Well, I have very,very limited knowledge of linux so I will not be rebuilding the docker.
That sucks as it means no updates for me.
I'm on ver.0.8.8.
No you missed my first part.
Under NodeLink system config, check "Enable daily program update check".  NodeLink will update fine.
Oh. Sorry.
Ok. I see the setting.
Checked.
NodeLink updated to v.0.9.5
Thank You.
12 hours ago, tibbar said:
Oh. Sorry.
Checked.
Thank You.
The other plus is that io_guy's update process updates the Node profile in the ISY and reboots it automatically when required.  You can set when you want that to happen, like 4am
Yes. Definitely thanks are in order to io_guy for well designed piece of software.
