ISY Error: Web Error - MethodNotAllowed (climate)
I'm seeing this error every 30 seconds or so:  ISY Error: Web Error - MethodNotAllowed (climate)
My wife mentioned my DSC system isn't triggering my lights on doors opening like they usually do.  I looked at nodelink and noticed these errors and that the profile was out of date.  I updated the profile (from http://automationshack.com/Files/nodesetup.zip), restarted the ISY, and restarted nodelink (shows version 0.9.7) and I still see these errors and my DSC isn't working.
Any ideas?
My full log since restart:
2018-02-20 04:57:13 - ISY NodeLink Server v0.9.7 started
2018-02-20 04:57:13 - Mono version: 3.2.8 (Debian 3.2.8+dfsg-10)
2018-02-20 04:57:14 - Web config server started (http://192.168.1.249:8090)
2018-02-20 04:57:14 - ISY resolved to 192.168.1.250
2018-02-20 04:57:15 - ISY Node Server config detected (profile 1)
2018-02-20 04:57:17 - Warning: nodesetup.zip file needs updating in ISY
2018-02-20 04:57:24 - ISY Error: Web Error - MethodNotAllowed (climate)
2018-02-20 04:57:49 - Subscription Error: Heartbeat timeout, re-subscribing to ISY
2018-02-20 04:57:54 - ISY Error: Web Error - MethodNotAllowed (climate)
2018-02-20 04:58:20 - Subscription Error: Heartbeat timeout, re-subscribing to ISY
2018-02-20 04:58:24 - ISY Error: Web Error - MethodNotAllowed (climate)
2018-02-20 04:58:54 - ISY Error: Web Error - MethodNotAllowed (climate)
2018-02-20 04:59:25 - ISY Error: Web Error - MethodNotAllowed (climate)
2018-02-20 04:59:55 - ISY Error: Web Error - MethodNotAllowed (climate)
2018-02-20 05:00:25 - ISY Error: Web Error - MethodNotAllowed (climate)
2018-02-20 05:00:55 - ISY Error: Web Error - MethodNotAllowed (climate)
2018-02-20 05:01:25 - ISY Error: Web Error - MethodNotAllowed (climate)
2018-02-20 05:01:56 - ISY Error: Web Error - MethodNotAllowed (climate)
2018-02-20 05:02:26 - ISY Error: Web Error - MethodNotAllowed (climate)
2018-02-20 05:02:56 - ISY Error: Web Error - MethodNotAllowed (climate)
I am seeing the exact same errors since 0.9.7 - nor is the DSC integration working.
I was seeing a different error on 0.9.6 and it seemed like it was slowing down my DSC integration, sometimes it worked, others it didn't. That error is now replaced with the same one as kohi.
Sorry, was supposed to be fixed.  Ill get a new version out tonight.
Thanks io_guy!
Having the same issue. I jumped from NodeLink 0.9.4 to 0.9.7,  really hicoughed and threw errors for a while. My ISY was auto-rebooted after NodeLink upgrade.
2018-02-20 08:30:58 - ISY Error: Web Error - MethodNotAllowed (climate)
2018-02-20 08:31:28 - ISY Error: Web Error - MethodNotAllowed (climate)
2018-02-20 08:31:59 - ISY Error: Web Error - MethodNotAllowed (climate)
2018-02-20 08:32:29 - ISY Error: Web Error - MethodNotAllowed (climate)
2018-02-20 08:32:59 - ISY Error: Web Error - MethodNotAllowed (climate)
2018-02-20 08:33:29 - ISY Error: Web Error - MethodNotAllowed (climate
All my NodeLink devices were down, showing blanks in the admin console. Many notifications about stat failures.
For a temporary fix I renamed NodeLink.exe to NodeLink_0.9.7.0.exe and then renamed NodeLink_0.9.4.0.exe to NodeLink.exe.
Rebooted NodeLink. Now it complains about the ISY profile needing to be updated, but my ISY device nodes are all being populated with data, for now until io_guy gets this fixed up again.
Awesome, thanks!
Installing NodeLink for first time and trying to work out my setup issues (vs NodeLink bugs).
Do you know if there is any way to get v0.9.4 just to see if I've cleared up things on my end?
The only other version I have downloaded is 0.9.6.
Wow! I never thought of that. When io_guy installs a new version the old one is renamed with the version in th anme and found in the same "node" folder on your RPi.
Not sure where you could go with that except to wait for the fix. io_guy is good and will make it work.....just more time.
Here are two previous versions (0.9.4 and 0.9.5).  NodeLink keeps a copy of every version in ~/Nodelink
Edited by Bumbershoot
Success!  My ISY now knows it's an even day in the Winter!
Not sure what to do with that, but it's a start.Data.thumb.JPG.43c0782b5f5aa3b708945d3d5555fa17.JPG
The New v0.9.8 seems to be working for me (I also updated the profile).  My log shows one error, but it seems like things are working.
2018-02-21 04:55:19 - ISY NodeLink Server v0.9.8 started
2018-02-21 04:55:19 - Mono version: 3.2.8 (Debian 3.2.8+dfsg-10)
2018-02-21 04:55:20 - Web config server started (http://192.168.1.249:8090)
2018-02-21 04:55:20 - ISY resolved to 192.168.1.250
2018-02-21 04:55:21 - ISY Node Server config detected (profile 1)
2018-02-21 04:55:22 - ISY Error: Input string was not in the correct format (profiles/family/10/profile/1/download/EDITOR/I_EDIT.XML)
