Lights Turning Off On Their Own
I am running on ISY version 5.04.  I am having a problem where I turn a light on and it immediately turns off.  If I turn it on 2 or 3 times it will stay on.  It will do this when executed by programs, Alexa, tablets, and switches.  It doesn't do it all the time.  I also have this issue with Insteon and Z-Wave devices.  It started off just with kitchen devices but has spread through out the house now.  Any ideas would be most appreciated.
These are the steps I would take if this were to happen to me :
  • Check my programs for possible conflicts
  • Reboot my ISY
  • Restore most recent backup
or post here again if none of the above work :oops:
The best place to start is to get an event trace: tools>diagnostics>events. Set it to level 3 and repeat the activities that are causing the problems, noting which thing you did first, second. Post the event log for that time here in a post.
If the affected devices are controlled by programs, post the program for the first thing you tried above in the event log
Paul
