Can't include Insteon scenes into Routines
So, yet another question about Alexa. I can't seem to include Instead based Scenes into Alexa routines. I see them in Scenes in Alexa portal (and iOS app) and can execute them. But they're missing when selection actions for Routine. Insteon devices are there. All other scenes are there. But Insteon scenes are not.
3 hours ago, Michel Kohanim said:
Hi firstone,
What does "other" refer to in "All other scenes .."?
Hue, nanoleaf and Harmony hub, controlled through respective skills, rather than isy skill.
Is this the deal where you have to mark the scenes as type "lights" or some such (e.g. "Alexa Category"), instead of "scene", in the ISY Portal, to make them show up as usable for Routines?
This is a good workaround. After changing it to light, it allowed me to add it as device to routine. Still doesn't explain why scene doesn't work but better than nothing.
Can verify the same workaround.  Change to light/device from scene.   (remember to 'forget' the old scene and 'discover' on the Alexa app or website).
Only risk I can see here is now you could tell Alexa to set a scene to a percent on.  Not a big deal.
Why do you consider that a risk and not a feature?
If the routine says to turn on a scene exposed as a device to x percent, the scene will simply be turned on as long as x > 0. Otherwise, the scene will be turned off.
Benoit
Hello everyone,
From now on, you should be able to use Scenes in Routines. You no longer need to expose them as a device.
This was due to a work-around we had for scenes related to the fact that ISY scenes are dimmable, whereas scenes from other manufacturers are not. There was initially a bug at Amazon that prevented the use of dimmable scenes, but this has been fixed since then. I was therefore able to remove the work-around.
Benoit
Besides organization does anyone know any feature differences between scenes and devices on the Alexa?
You may want to read through this thread. Benoit gave a very thorough explanation on why I was experiencing the results I was using scenes in Groups and Routines.
  • 1 month later...
Noticed the same issue but this time with using ISY programs. If added as "scene', it doesn't show up in Routine actions. But if added as "light", it works .
This is now fixed. Programs exposed as scenes now can be added to routines.
Benoit
