ryarber Posted April 6, 2009 Posted April 6, 2009 I was trying to use the elk system to control a KPL button via the 99i. Is this not possible? I just have a rule in the ELK that says something like... When system is armed any state control lighting back entry keypad.D to on It doesn't work.
Sub-Routine Posted April 6, 2009 Posted April 6, 2009 KPL buttons cannot be controlled directly. You will need to create a scene that contains the button(s) you want to switch. Rand
ryarber Posted April 7, 2009 Author Posted April 7, 2009 does a scene have to have responders or can it be only controllers?
Michel Kohanim Posted April 7, 2009 Posted April 7, 2009 Hi ryarber, It can haveany permutation of both. With kind regards, Michel ryarber said: does a scene have to have responders or can it be only controllers?
