Moshe Posted April 8, 2009 Share Posted April 8, 2009 I have an ISY 99i that is working great, however it seems to gain time. It is about 1 minute fast. I have it synchronizing with NTP server every 24 hours. When I choose "sync now" the time is corrected. Any thoughts? Link to comment
Michel Kohanim Posted April 8, 2009 Share Posted April 8, 2009 Hi Moshe, That is very odd unless ISY is not actually synchronizing with NTP every 24 hours. So, is ISY 1 minute fast every day or every month or every time you check it? With kind regards, Michel I have an ISY 99i that is working great, however it seems to gain time. It is about 1 minute fast. I have it synchronizing with NTP server every 24 hours. When I choose "sync now" the time is corrected. Any thoughts? Link to comment
Moshe Posted April 8, 2009 Author Share Posted April 8, 2009 It seems to gain time every couple of weeks. When I resync the problem is corrected. Link to comment
Michel Kohanim Posted April 8, 2009 Share Posted April 8, 2009 Hi Moshe, Can you check your logs to see if you have any -6000x errors? It seems as if ISY is not synching with your NTP properly. With kind regards, Michel It seems to gain time every couple of weeks. When I resync the problem is corrected. Link to comment
trosmus Posted April 13, 2009 Share Posted April 13, 2009 Hi Moshe, That is very odd unless ISY is not actually synchronizing with NTP every 24 hours. So, is ISY 1 minute fast every day or every month or every time you check it? I am seeing the same problem. Version is 2.7.0 I have the NTP server Enabled and set to sync every hour. I run my own local NTP server so I know it is not a connection problem. Upon a ISY device reboot, I see the initial time sync.... (.130 is the ISY device and .50 is the server running NTP) 9:47:17.89708 172.22.22.130 -> 172.22.22.50 NTP client (Wed Feb 6 22:28:16 2036) 9:47:17.89761 172.22.22.50 -> 172.22.22.130 NTP server (Sun Apr 12 09:47:17 2009) Then nothing, ever. If I do a manual "Synchronize now", I get another valid time sync.... 16:22:46.36672 172.22.22.130 -> 172.22.22.50 NTP client (Wed Feb 6 22:28:16 2036) 16:22:46.36844 172.22.22.50 -> 172.22.22.130 NTP server (Mon Apr 13 16:22:46 2009) Also note the initial date/time from the ISY device Link to comment
Michel Kohanim Posted April 14, 2009 Share Posted April 14, 2009 trosmus, thanks SO very much. Your invaluable log provided me with enough to actually find a very rare bug the finding of which would've been impossible otherwise. Moshe, thanks for finding this bug. It's all fixed now and included in 2.7.3 (hopefully to be dropped any day now). With kind regards, Michel Hi Moshe, That is very odd unless ISY is not actually synchronizing with NTP every 24 hours. So, is ISY 1 minute fast every day or every month or every time you check it? I am seeing the same problem. Version is 2.7.0 I have the NTP server Enabled and set to sync every hour. I run my own local NTP server so I know it is not a connection problem. Upon a ISY device reboot, I see the initial time sync.... (.130 is the ISY device and .50 is the server running NTP) 9:47:17.89708 172.22.22.130 -> 172.22.22.50 NTP client (Wed Feb 6 22:28:16 2036) 9:47:17.89761 172.22.22.50 -> 172.22.22.130 NTP server (Sun Apr 12 09:47:17 2009) Then nothing, ever. If I do a manual "Synchronize now", I get another valid time sync.... 16:22:46.36672 172.22.22.130 -> 172.22.22.50 NTP client (Wed Feb 6 22:28:16 2036) 16:22:46.36844 172.22.22.50 -> 172.22.22.130 NTP server (Mon Apr 13 16:22:46 2009) Also note the initial date/time from the ISY device Link to comment
markens Posted April 14, 2009 Share Posted April 14, 2009 I am also seeing this behavior (time gains about 2 minutes per week); manual NTP time sync corrects. I look forward to seeing the fix in 2.7.3. Link to comment
oberkc Posted April 18, 2009 Share Posted April 18, 2009 I have had this problem also, without resolution, having tried all the suggested remedies. Hopefully, this will fix mine, as well. Link to comment
Moshe Posted April 23, 2009 Author Share Posted April 23, 2009 Michel - Thanks for the feed back. I will update to new version when available. Moshe Link to comment
AutomationNut Posted July 11, 2009 Share Posted July 11, 2009 Same issue here. When will the fix be released? Link to comment
Michel Kohanim Posted July 12, 2009 Share Posted July 12, 2009 AutomationNut, Aha, now I understand the context of your previous post. Yes, 2.7.4 + all fix this issue. May I humbly recommend waiting for 2.7.6 which is filled with new features? With kind regards, Michel Same issue here. When will the fix be released? Link to comment
AutomationNut Posted July 12, 2009 Share Posted July 12, 2009 I will wait for 2.7.6 thanks Link to comment
