Z-Wave Plus PIR Multi Sensor
How do you change the parameters. I'm trying to change the motion default time from 3 min to 1 min.
Right-click the device (in the Admin console), select ‘Z-Wave’ then ‘Set Configuration Parameter’.
As to which parameter, the size of the parameter and the value to set - you will need to refer to the device specific documentation.
