Keypad 8 question.
frank
Is there a way to make two keys mutually exclusive? I would like to say, have button B turn on a program to auto run a pool fill device and have button C to run a manual program to fill the pool. I need to have ONLY one or the other prog enabled and never both at the same time. Further I wish to have the LED on each button be on when that button is toggled on and if possible, turn the other button off. The buttons need to light when enabled until either toggled off or until the other button is toggled on.
Hi frank,
Yes, you can. Create a scene, put them both in there as controllers. Click on each node within the scene and set the on level for the other one to 0 (off). i.e. when button x is on button y will be off.
Michel, thanks a million. Works perfect. Really Appreciate such a quick response.
Frank
      38k
      379.2k
