Webcontrol 8
I'm not sure when it quit but I just noticed that ISY can no longer switch the outputs on my webcontrols via nodelink.
I'm on v5.0.12, v0.9.16 and v03.03.31(also didn't work while on v03.03.27), is there a known issue with this?
Nope.
Enable the Debug in System Config and WC tabs to see what the is being sent.
It doesn't look like anything is getting sent. I don't see anything in ISY event log either, I just get request failed error (after rebooting ISY it gives an error with a bit more info-pretty much the same thing that happens if you try to query battery powered z wave devices).
I just edited my programs back to use network resources again.
I wasn't talking about the ISY log.
If you want to fix it I need decent logs, not a description.  Sounds like a config issue between the ISI and NodeLink.
There is a log on the Nodelink main config page. Set that to Debug. Also, the Nodelink webcontrol device specific page may have a log setting too. Set that to debug. Then either:
  • Try and recreate the problem when that's possible, ... or...
  • Let it sit until until you notice it happen again
Copy the log contents from around the problem as best as you can. Either put that in post here, or PM it if you think sensitive info may be in there.
Paul
Edited by paulbates
One thing I did when converting to Nodelink was to keep the old programs running and my xxxlink running on my pi, and then test new versions of them until I figured nodelink out. Try a few things at a time. Eventually, cut everything over, and you can shut the xxlink program down on the pi.
Its hard to do this in one single cutover.
I completed my Nodelink switch over back on version 0.5.12.0 (at leastwise that's to oldest version in it's folder).
Nodelink was one of the reasons why I switched/stuck with ISY v5 even though i lost some things with my z wave devices (still haven't been fixed) .
Sent from my Pixel XL using Tapatalk
Like a said the Nodelink logs didn't show anything, I'll turn debugging on again and post after I get my pool webcontrol back online later this week.
I also can't start my rainmachine from ISY either.
If neither are working then your configuration from ISY to NodeLink is incorrect.  Setting your System Config log level to Debug will show any requests coming from the ISY.
Was there anything that needed to be change from when I originally set it up, I know there's been a lot of updates but aside from adding my Rainmachine I haven't touched anything related to Nodelink aside from doing updates prior to them being fully automatic. The web control stuff was working but I had my pool webcontrol offline for a awhile due to a failed wifi bridge and never put my other into use as planned (granted I had fully tested using it's outputs as it will be used to control fans in the attic and damper ducts).
Edit:Just checked the nodelink configuration doc and it's the same as what I have in my configuration.
Here's basically everything bellow after restarting Nodelink with debugging on. I tried to turn on caiwc2 output 1 (caiwc1 is the one for my pool automation that's offline, hence the polling errors), I then tried to start rainmachine program and then zone 1. While watching Nodelink I didn't see anything come up other than updates from readings on the webcontrol. This basically what I saw last time.
2018-06-19 07:10:48 - ISY NodeLink Server v0.9.16 started [L]
2018-06-19 07:10:48 - OS: Microsoft Windows NT 6.1.7601 Service Pack 1
2018-06-19 07:10:48 - Web config server started (http://192.168.3.193:8090)
2018-06-19 07:10:48 - ISY resolved to 192.168.3.250
2018-06-19 07:10:48 - ISY Send: Node Server request sent
2018-06-19 07:10:48 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><connections all="true" max="25"><connection profile="1" type="network" enabled="true"><name>isylink</name><ssl>false</ssl><port>8090</port><timeout>10</timeout><isyusernum>0</isyusernum><ip>192.168.3.130</ip><baseurl>isylink</baseurl><nsuser>matrix</nsuser></connection><connection profile="2" type="network" enabled="true"><name>ISY Portal</name><ssl>true</ssl><port>443</port><timeout>3000</timeout><isyusernum>0</isyusernum><ip>my.isy.io</ip><baseurl>/api/nscmd/0021b90226a7</baseurl><nsuser>0021b90226a7</nsuser></connection></connections> (profiles/ns/0/connection)
2018-06-19 07:10:48 - ISY Node Server config detected (profile 1)
2018-06-19 07:10:48 - ISY Send: Node list request sent
2018-06-19 07:10:48 - Auto-Update: Checking for program update...
2018-06-19 07:10:48 - Auto-Update: No web update available
2018-06-19 07:10:50 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><nodes><root></root><node flag="128" nodeDefId="occ2_geofence"><address>n002_occ2geo01</address><name>Home</name><family instance="2">10</family><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n002_occ2geo01</pnode><ELK_ID>A02</ELK_ID></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>4C 37 F 1</address><name>Diningroom</name><type>1.32.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>4C 37 F 1</pnode><ELK_ID>A03</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>42 9F 28 1</address><name>Hallway M</name><type>1.32.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>42 9F 28 1</pnode><ELK_ID>A04</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="128" nodeDefId="UZW0006"><address>ZW004_1</address><name>Main ZW 004 Thermostat</name><family>4</family><type>4.8.6.0</type><enabled>true</enabled><deviceClass>1</deviceClass><wattage>1000</wattage><dcPeriod>60</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW004_1</pnode><sgid>1</sgid><devtype><gen>4.8.6</gen><mfg>139.21586.21561</mfg><cat>140</cat></devtype><ELK_ID>A05</ELK_ID><property id="ST" value="69" formatted="69°F" uom="17" /><property id="CLIMD" value="3" formatted="Auto" uom="67" /><property id="CLISPC" value="78" formatted="78°F" uom="17" /><property id="CLISPH" value="66" formatted="66°F" uom="17" /></node><node flag="0" nodeDefId="UZW0007"><address>ZW004_118</address><name>Main ZW 004 Multilevel Sensor</name><family>4</family><parent type="1">ZW004_1</parent><type>4.8.6.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW004_1</pnode><sgid>118</sgid><devtype><gen>4.8.6</gen><mfg>139.21586.21561</mfg><cat>118</cat></devtype><ELK_ID>A06</ELK_ID></node><node flag="128" nodeDefId="UZW0008"><address>ZW005_1</address><name>Familyroom ZW 005 Thermostat</name><family>4</family><type>4.8.6.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW005_1</pnode><sgid>1</sgid><devtype><gen>4.8.6</gen><mfg>139.21586.21561</mfg><cat>140</cat></devtype><ELK_ID>A07</ELK_ID><property id="ST" value="70" formatted="70°F" uom="17" /><property id="CLIMD" value="3" formatted="Auto" uom="67" /><property id="CLISPC" value="77" formatted="77°F" uom="17" /><property id="CLISPH" value="66" formatted="66°F" uom="17" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>40 CF DA 1</address><name>Familyroom ceiling fan.light</name><type>1.66.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>40 CF DA 1</pnode><ELK_ID>A08</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="0" nodeDefId="KeypadButton_ADV"><address>40 CF DA 3</address><name>Familyroom ceiling fan.fan hi</name><parent type="1">40 CF DA 1</parent><type>1.66.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>40 CF DA 1</pnode><ELK_ID>A09</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="128" nodeDefId="DimmerLampOnly"><address>2A EB 8E 1</address><name>Mermaid Bulb</name><type>1.58.66.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>2A EB 8E 1</pnode><ELK_ID>A10</ELK_ID><property id="ST" value="127" formatted="50%" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>41 98 A2 1</address><name>Porch</name><type>1.32.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>41 98 A2 1</pnode><ELK_ID>A12</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>41 9D 4 1</address><name>Stairs Lower</name><type>1.32.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>41 9D 4 1</pnode><ELK_ID>A13</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>41 A4 70 1</address><name>Stairs Upper</name><type>1.32.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>41 A4 70 1</pnode><ELK_ID>A14</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="128" nodeDefId="DimmerLampOnly"><address>2C 54 E1 1</address><name>Flood Light</name><type>1.73.71.0</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>2C 54 E1 1</pnode><ELK_ID>A16</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>41 9E 41 1</address><name>Front Door</name><type>1.32.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>41 9E 41 1</pnode><ELK_ID>B02</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>41 9D 3F 1</address><name>Livingroom oulet</name><type>1.32.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>41 9D 3F 1</pnode><ELK_ID>B03</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>41 A0 76 1</address><name>Upstairs Hall M</name><type>1.32.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>41 A0 76 1</pnode><ELK_ID>B04</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>41 B8 20 1</address><name>Upstairs Hall S</name><type>1.32.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>41 B8 20 1</pnode><ELK_ID>B05</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="0" nodeDefId="KeypadButton_ADV"><address>40 CF DA 4</address><name>Familyroom ceiling fan.fan me</name><parent type="1">40 CF DA 1</parent><type>1.66.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>40 CF DA 1</pnode><ELK_ID>B07</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="0" nodeDefId="KeypadButton_ADV"><address>40 CF DA 5</address><name>Familyroom ceiling fan.fan lo</name><parent type="1">40 CF DA 1</parent><type>1.66.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>40 CF DA 1</pnode><ELK_ID>B08</ELK_ID><property id="ST" value="255" formatted="100%" uom="100" /></node><node flag="0" nodeDefId="KeypadButton_ADV"><address>40 CF DA 6</address><name>Familyroom ceiling fan.fan of</name><parent type="1">40 CF DA 1</parent><type>1.66.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>40 CF DA 1</pnode><ELK_ID>B09</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="0" nodeDefId="UZW001B"><address>ZW005_118</address><name>Familyroom ZW 005 Multilevel </name><family>4</family><parent type="1">ZW005_1</parent><type>4.8.6.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW005_1</pnode><sgid>118</sgid><devtype><gen>4.8.6</gen><mfg>139.21586.21561</mfg><cat>118</cat></devtype><ELK_ID>B10</ELK_ID></node><node flag="128" nodeDefId="UZW001C"><address>ZW006_1</address><name>Doorbell ZW 006 Siren</name><family>4</family><type>4.16.5.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW006_1</pnode><sgid>1</sgid><devtype><gen>4.16.5</gen><mfg>134.260.56</mfg><cat>137</cat></devtype><ELK_ID>B11</ELK_ID><property id="ST" value="0" formatted="Off" uom="78" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>41 AD 1D 1</address><name>Mermaid Switch</name><type>1.32.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>41 AD 1D 1</pnode><ELK_ID>B12</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>3E 22 E 1</address><name>Kitchen M</name><type>1.31.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>3E 22 E 1</pnode><ELK_ID>C03</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>41 A2 1E 1</address><name>Kitchen S</name><type>1.32.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>41 A2 1E 1</pnode><ELK_ID>C04</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="128" nodeDefId="UZW0027"><address>ZW007_1</address><name>Driveway ZW 007 Scene Switch</name><family>4</family><type>4.17.4.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW007_1</pnode><sgid>1</sgid><devtype><gen>4.17.4</gen><mfg>134.3.27</mfg><cat>134</cat></devtype><ELK_ID>C06</ELK_ID><property id="ST" value="0" formatted="0%" uom="51" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>46 B9 39 1</address><name>Bathroom Light</name><type>1.31.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>46 B9 39 1</pnode><ELK_ID>C07</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="128" nodeDefId="RelayLampSwitch_ADV"><address>4C CB EF 1</address><name>Bathroom Fan</name><type>2.26.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>4C CB EF 1</pnode><ELK_ID>C08</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="128" nodeDefId="UZW002A"><address>ZW009_1</address><name>Familyroom ZW 009 Multilevel </name><family>4</family><type>4.33.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW009_1</pnode><sgid>1</sgid><devtype><gen>4.33.1</gen><mfg>134.258.100</mfg><cat>118</cat></devtype><ELK_ID>C09</ELK_ID></node><node flag="128" nodeDefId="UZW002B"><address>ZW010_1</address><name>Livingroom ZW 010 Multilevel </name><family>4</family><type>4.33.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW010_1</pnode><sgid>1</sgid><devtype><gen>4.33.1</gen><mfg>134.258.100</mfg><cat>118</cat></devtype><ELK_ID>C10</ELK_ID></node><node flag="128" nodeDefId="UZW002C"><address>ZW036_1</address><name>Kitchen ZW 036 Multilevel Sen</name><family>4</family><type>4.33.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW036_1</pnode><sgid>1</sgid><devtype><gen>4.33.1</gen><mfg>134.258.100</mfg><cat>118</cat></devtype><ELK_ID>C11</ELK_ID></node><node flag="128" nodeDefId="UZW002D"><address>ZW012_1</address><name>Doggy Door ZW 012 Multilevel </name><family>4</family><type>4.33.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW012_1</pnode><sgid>1</sgid><devtype><gen>4.33.1</gen><mfg>134.258.100</mfg><cat>118</cat></devtype><ELK_ID>C12</ELK_ID></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>41 BB 51 1</address><name>Garage</name><type>1.32.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>41 BB 51 1</pnode><ELK_ID>C13</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="0" nodeDefId="occ2_device"><address>n002_occ2dev001</address><name>Dan</name><family instance="2">10</family><parent type="1">n002_occ2geo01</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n002_occ2geo01</pnode><ELK_ID>C14</ELK_ID></node><node flag="0" nodeDefId="occ2_device"><address>n002_occ2dev002</address><name>Nana</name><family instance="2">10</family><parent type="1">n002_occ2geo01</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n002_occ2geo01</pnode><ELK_ID>C15</ELK_ID></node><node flag="0" nodeDefId="UZW0031"><address>ZW012_104</address><name>ZW 012 Binary Sensor 1</name><family>4</family><parent type="1">ZW012_1</parent><type>4.33.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW012_1</pnode><sgid>104</sgid><devtype><gen>4.33.1</gen><mfg>134.258.100</mfg><cat>104</cat></devtype><ELK_ID>C16</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>4C 51 54 1</address><name>Kitchen Table</name><type>1.32.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>4C 51 54 1</pnode><ELK_ID>D01</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>40 CD 56 1</address><name>Back Yard.1</name><type>1.66.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>40 CD 56 1</pnode><ELK_ID>D02</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="0" nodeDefId="KeypadButton_ADV"><address>40 CD 56 3</address><name>Waterfall.A</name><parent type="1">40 CD 56 1</parent><type>1.66.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>40 CD 56 1</pnode><ELK_ID>D03</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="0" nodeDefId="KeypadButton_ADV"><address>40 CD 56 4</address><name>Back Yard.B</name><parent type="1">40 CD 56 1</parent><type>1.66.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>40 CD 56 1</pnode><ELK_ID>D04</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="128" nodeDefId="DimmerLampOnly"><address>2D 7D 5A 1</address><name>Familyroom ceiling fan-Light</name><type>1.46.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>2D 7D 5A 1</pnode><ELK_ID>D05</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="0" nodeDefId="FanLincMotor"><address>2D 7D 5A 2</address><name>Familyroom ceiling fan-Motor</name><parent type="1">2D 7D 5A 1</parent><type>1.46.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>2D 7D 5A 1</pnode><ELK_ID>D06</ELK_ID><property id="ST" value="63" formatted="25%" uom="100" /></node><node flag="0" nodeDefId="KeypadButton_ADV"><address>40 CD 56 5</address><name>Back Yard.C</name><parent type="1">40 CD 56 1</parent><type>1.66.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>40 CD 56 1</pnode><ELK_ID>D07</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="0" nodeDefId="KeypadButton_ADV"><address>40 CD 56 6</address><name>Back Yard.D</name><parent type="1">40 CD 56 1</parent><type>1.66.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>40 CD 56 1</pnode><ELK_ID>D08</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>42 A9 7B 1</address><name>Familyroom outlet</name><type>1.32.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>42 A9 7B 1</pnode><ELK_ID>D09</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>4C 2F 81 1</address><name>Hallway S</name><type>1.32.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>4C 2F 81 1</pnode><ELK_ID>D10</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>42 8F 74 1</address><name>Hall Closet</name><type>1.32.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>42 8F 74 1</pnode><ELK_ID>D11</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="128" nodeDefId="RelayLampSwitch"><address>3F 2C E2 1</address><name>Waterfall Relay</name><type>9.11.58.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>3F 2C E2 1</pnode><ELK_ID>D13</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="128" nodeDefId="UZW0040"><address>ZW031_1</address><name>Garage ZW 031 Notify Sensor</name><family>4</family><type>4.7.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW031_1</pnode><sgid>1</sgid><devtype><gen>4.7.1</gen><mfg>410.3.3</mfg><cat>185</cat></devtype><ELK_ID>D15</ELK_ID></node><node flag="0" nodeDefId="UZW0041"><address>ZW031_104</address><name>ZW 031 Binary Sensor 1</name><family>4</family><parent type="1">ZW031_1</parent><type>4.7.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW031_1</pnode><sgid>104</sgid><devtype><gen>4.7.1</gen><mfg>410.3.3</mfg><cat>104</cat></devtype><ELK_ID>D16</ELK_ID><property id="ST" value="0" formatted="Off" uom="78" /></node><node flag="0" nodeDefId="UZW0042"><address>ZW036_104</address><name>ZW 036 Binary Sensor 1</name><family>4</family><parent type="1">ZW036_1</parent><type>4.33.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW036_1</pnode><sgid>104</sgid><devtype><gen>4.33.1</gen><mfg>134.258.100</mfg><cat>104</cat></devtype><ELK_ID>E01</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="128" nodeDefId="UZW0043"><address>ZW032_1</address><name>Back Door ZW 032 Notify Senso</name><family>4</family><type>4.7.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW032_1</pnode><sgid>1</sgid><devtype><gen>4.7.1</gen><mfg>410.3.3</mfg><cat>185</cat></devtype><ELK_ID>E02</ELK_ID></node><node flag="0" nodeDefId="UZW0044"><address>ZW032_104</address><name>Back Door ZW 032 Binary Senso</name><family>4</family><parent type="1">ZW032_1</parent><type>4.7.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW032_1</pnode><sgid>104</sgid><devtype><gen>4.7.1</gen><mfg>410.3.3</mfg><cat>104</cat></devtype><ELK_ID>E03</ELK_ID><property id="ST" value="0" formatted="Off" uom="78" /></node><node flag="0" nodeDefId="UZW0045"><address>ZW036_155</address><name>ZW 036 Motion Sensor 1</name><family>4</family><parent type="1">ZW036_1</parent><type>4.33.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW036_1</pnode><sgid>155</sgid><devtype><gen>4.33.1</gen><mfg>134.258.100</mfg><cat>155</cat></devtype><ELK_ID>E04</ELK_ID><property id="ST" value="0" formatted="Off" uom="78" /></node><node flag="128" nodeDefId="UZW0046"><address>ZW033_1</address><name>Front Door ZW 033 Notify Sens</name><family>4</family><type>4.7.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW033_1</pnode><sgid>1</sgid><devtype><gen>4.7.1</gen><mfg>410.3.3</mfg><cat>185</cat></devtype><ELK_ID>E05</ELK_ID></node><node flag="0" nodeDefId="UZW0047"><address>ZW033_104</address><name>Front Door ZW 033 Binary Sens</name><family>4</family><parent type="1">ZW033_1</parent><type>4.7.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW033_1</pnode><sgid>104</sgid><devtype><gen>4.7.1</gen><mfg>410.3.3</mfg><cat>104</cat></devtype><ELK_ID>E06</ELK_ID><property id="ST" value="0" formatted="Off" uom="78" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>4C 4F 68 1</address><name>Kitchen Sink</name><type>1.32.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>4C 4F 68 1</pnode><ELK_ID>E07</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="128" nodeDefId="RelayLampSwitch_ADV"><address>4B DC FE 1</address><name>Garbage Disposal</name><type>2.42.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>4B DC FE 1</pnode><ELK_ID>E08</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>40 CC F6 1</address><name>Master Bed Fan Light</name><type>1.66.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>40 CC F6 1</pnode><ELK_ID>E09</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="0" nodeDefId="KeypadButton_ADV"><address>40 CC F6 3</address><name>Master Bed Fan High</name><parent type="1">40 CC F6 1</parent><type>1.66.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>40 CC F6 1</pnode><ELK_ID>E10</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="0" nodeDefId="KeypadButton_ADV"><address>40 CC F6 4</address><name>Master Bed Fan Med</name><parent type="1">40 CC F6 1</parent><type>1.66.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>40 CC F6 1</pnode><ELK_ID>E11</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="0" nodeDefId="KeypadButton_ADV"><address>40 CC F6 5</address><name>Master Bed Fan Low</name><parent type="1">40 CC F6 1</parent><type>1.66.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>40 CC F6 1</pnode><ELK_ID>E12</ELK_ID><property id="ST" value="255" formatted="100%" uom="100" /></node><node flag="0" nodeDefId="KeypadButton_ADV"><address>40 CC F6 6</address><name>Master Bed Fan Off</name><parent type="1">40 CC F6 1</parent><type>1.66.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>40 CC F6 1</pnode><ELK_ID>E13</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>42 9C 20 1</address><name>Master Bed Fan Light Upper</name><type>1.32.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>42 9C 20 1</pnode><ELK_ID>E14</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>42 A9 83 1</address><name>Master Bed Outlet</name><type>1.32.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>42 A9 83 1</pnode><ELK_ID>E15</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="128" nodeDefId="DimmerLampOnly"><address>2D 7C C4 1</address><name>Master Bed Ceiling Fan-Light</name><type>1.46.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>2D 7C C4 1</pnode><ELK_ID>E16</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="0" nodeDefId="FanLincMotor"><address>2D 7C C4 2</address><name>Master Bed Ceiling Fan</name><parent type="1">2D 7C C4 1</parent><type>1.46.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>2D 7C C4 1</pnode><ELK_ID>F01</ELK_ID><property id="ST" value="63" formatted="25%" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>4C 25 A9 1</address><name>Guest Bath Light</name><type>1.32.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>4C 25 A9 1</pnode><ELK_ID>F02</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="128" nodeDefId="RelayLampSwitch_ADV"><address>4B EB FA 1</address><name>Guest Bath Fan</name><type>2.42.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>4B EB FA 1</pnode><ELK_ID>F03</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="128" nodeDefId="WC8" nls="108W"><address>n001_caiwc2</address><name>AtticWebControl</name><family instance="1">10</family><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc2</pnode><ELK_ID>F05</ELK_ID></node><node flag="0" nodeDefId="WC8H" nls="108WH"><address>n001_caiwc2_h</address><name>AtticHumidity</name><family instance="1">10</family><parent type="1">n001_caiwc2</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc2</pnode><ELK_ID>F06</ELK_ID></node><node flag="0" nodeDefId="WC8DI" nls="108WI"><address>n001_caiwc2_i1</address><name>AtticInput1</name><family instance="1">10</family><parent type="1">n001_caiwc2</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc2</pnode><ELK_ID>F07</ELK_ID></node><node flag="0" nodeDefId="WC8V" nls="108WV"><address>n001_caiwc2_v1</address><name>AtticVariable1</name><family instance="1">10</family><parent type="1">n001_caiwc2</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc2</pnode><ELK_ID>F08</ELK_ID></node><node flag="0" nodeDefId="WC8DO" nls="108WO"><address>n001_caiwc2_o1</address><name>AtticOutput1</name><family instance="1">10</family><parent type="1">n001_caiwc2</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc2</pnode><ELK_ID>F09</ELK_ID></node><node flag="0" nodeDefId="WC8T" nls="108WT"><address>n001_caiwc2_t1</address><name>AtticTemperature1</name><family instance="1">10</family><parent type="1">n001_caiwc2</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc2</pnode><ELK_ID>F10</ELK_ID></node><node flag="0" nodeDefId="WC8DI" nls="108WI"><address>n001_caiwc2_i2</address><name>AtticInput2</name><family instance="1">10</family><parent type="1">n001_caiwc2</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc2</pnode><ELK_ID>F11</ELK_ID></node><node flag="0" nodeDefId="WC8V" nls="108WV"><address>n001_caiwc2_v2</address><name>AtticVariable2</name><family instance="1">10</family><parent type="1">n001_caiwc2</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc2</pnode><ELK_ID>F12</ELK_ID></node><node flag="0" nodeDefId="WC8DO" nls="108WO"><address>n001_caiwc2_o2</address><name>AtticOutput2</name><family instance="1">10</family><parent type="1">n001_caiwc2</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc2</pnode><ELK_ID>F13</ELK_ID></node><node flag="0" nodeDefId="WC8T" nls="108WT"><address>n001_caiwc2_t2</address><name>AtticTemperature2</name><family instance="1">10</family><parent type="1">n001_caiwc2</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc2</pnode><ELK_ID>F14</ELK_ID></node><node flag="0" nodeDefId="WC8DI" nls="108WI"><address>n001_caiwc2_i3</address><name>AtticInput3</name><family instance="1">10</family><parent type="1">n001_caiwc2</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc2</pnode><ELK_ID>F15</ELK_ID></node><node flag="0" nodeDefId="WC8V" nls="108WV"><address>n001_caiwc2_v3</address><name>AtticVariable3</name><family instance="1">10</family><parent type="1">n001_caiwc2</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc2</pnode><ELK_ID>F16</ELK_ID></node><node flag="0" nodeDefId="WC8DO" nls="108WO"><address>n001_caiwc2_o3</address><name>AtticOutput3</name><family instance="1">10</family><parent type="1">n001_caiwc2</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc2</pnode><ELK_ID>G01</ELK_ID></node><node flag="0" nodeDefId="WC8T" nls="108WT"><address>n001_caiwc2_t3</address><name>AtticTemperature3</name><family instance="1">10</family><parent type="1">n001_caiwc2</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc2</pnode><ELK_ID>G02</ELK_ID></node><node flag="0" nodeDefId="WC8DI" nls="108WI"><address>n001_caiwc2_i4</address><name>AtticInput4</name><family instance="1">10</family><parent type="1">n001_caiwc2</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc2</pnode><ELK_ID>G03</ELK_ID></node><node flag="0" nodeDefId="WC8V" nls="108WV"><address>n001_caiwc2_v4</address><name>AtticVariable4</name><family instance="1">10</family><parent type="1">n001_caiwc2</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc2</pnode><ELK_ID>G04</ELK_ID></node><node flag="0" nodeDefId="WC8DO" nls="108WO"><address>n001_caiwc2_o4</address><name>AtticOutput4</name><family instance="1">10</family><parent type="1">n001_caiwc2</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc2</pnode><ELK_ID>G05</ELK_ID></node><node flag="0" nodeDefId="WC8T" nls="108WT"><address>n001_caiwc2_t4</address><name>AtticTemperature4</name><family instance="1">10</family><parent type="1">n001_caiwc2</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc2</pnode><ELK_ID>G06</ELK_ID></node><node flag="0" nodeDefId="WC8DI" nls="108WI"><address>n001_caiwc2_i5</address><name>AtticInput5</name><family instance="1">10</family><parent type="1">n001_caiwc2</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc2</pnode><ELK_ID>G07</ELK_ID></node><node flag="0" nodeDefId="WC8V" nls="108WV"><address>n001_caiwc2_v5</address><name>AtticVariable5</name><family instance="1">10</family><parent type="1">n001_caiwc2</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc2</pnode><ELK_ID>G08</ELK_ID></node><node flag="0" nodeDefId="WC8DO" nls="108WO"><address>n001_caiwc2_o5</address><name>AtticOutput5</name><family instance="1">10</family><parent type="1">n001_caiwc2</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc2</pnode><ELK_ID>G09</ELK_ID></node><node flag="0" nodeDefId="WC8T" nls="108WT"><address>n001_caiwc2_t5</address><name>AtticTemperature5</name><family instance="1">10</family><parent type="1">n001_caiwc2</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc2</pnode><ELK_ID>G10</ELK_ID></node><node flag="0" nodeDefId="WC8DI" nls="108WI"><address>n001_caiwc2_i6</address><name>AtticInput6</name><family instance="1">10</family><parent type="1">n001_caiwc2</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc2</pnode><ELK_ID>G11</ELK_ID></node><node flag="0" nodeDefId="WC8V" nls="108WV"><address>n001_caiwc2_v6</address><name>AtticVariable6</name><family instance="1">10</family><parent type="1">n001_caiwc2</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc2</pnode><ELK_ID>G12</ELK_ID></node><node flag="0" nodeDefId="WC8DO" nls="108WO"><address>n001_caiwc2_o6</address><name>AtticOutput6</name><family instance="1">10</family><parent type="1">n001_caiwc2</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc2</pnode><ELK_ID>G13</ELK_ID></node><node flag="0" nodeDefId="WC8T" nls="108WT"><address>n001_caiwc2_t6</address><name>AtticTemperature6</name><family instance="1">10</family><parent type="1">n001_caiwc2</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc2</pnode><ELK_ID>G14</ELK_ID></node><node flag="0" nodeDefId="WC8DI" nls="108WI"><address>n001_caiwc2_i7</address><name>AtticInput7</name><family instance="1">10</family><parent type="1">n001_caiwc2</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc2</pnode><ELK_ID>G15</ELK_ID></node><node flag="0" nodeDefId="WC8V" nls="108WV"><address>n001_caiwc2_v7</address><name>AtticVariable7</name><family instance="1">10</family><parent type="1">n001_caiwc2</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc2</pnode><ELK_ID>G16</ELK_ID></node><node flag="0" nodeDefId="WC8DO" nls="108WO"><address>n001_caiwc2_o7</address><name>AtticOutput7</name><family instance="1">10</family><parent type="1">n001_caiwc2</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc2</pnode><ELK_ID>H01</ELK_ID></node><node flag="0" nodeDefId="WC8T" nls="108WT"><address>n001_caiwc2_t7</address><name>AtticTemperature7</name><family instance="1">10</family><parent type="1">n001_caiwc2</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc2</pnode><ELK_ID>H02</ELK_ID></node><node flag="0" nodeDefId="WC8DI" nls="108WI"><address>n001_caiwc2_i8</address><name>AtticInput8</name><family instance="1">10</family><parent type="1">n001_caiwc2</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc2</pnode><ELK_ID>H03</ELK_ID></node><node flag="0" nodeDefId="WC8V" nls="108WV"><address>n001_caiwc2_v8</address><name>AtticVariable8</name><family instance="1">10</family><parent type="1">n001_caiwc2</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc2</pnode><ELK_ID>H04</ELK_ID></node><node flag="0" nodeDefId="WC8DO" nls="108WO"><address>n001_caiwc2_o8</address><name>AtticOutput8</name><family instance="1">10</family><parent type="1">n001_caiwc2</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc2</pnode><ELK_ID>H05</ELK_ID></node><node flag="0" nodeDefId="WC8T" nls="108WT"><address>n001_caiwc2_t8</address><name>AtticTemperature8</name><family instance="1">10</family><parent type="1">n001_caiwc2</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc2</pnode><ELK_ID>H06</ELK_ID></node><node flag="0" nodeDefId="WC8AI" nls="108WA"><address>n001_caiwc2_a1</address><name>AtticAnalog1</name><family instance="1">10</family><parent type="1">n001_caiwc2</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc2</pnode><ELK_ID>H07</ELK_ID></node><node flag="0" nodeDefId="WC8AI" nls="108WA"><address>n001_caiwc2_a2</address><name>AtticAnalog2</name><family instance="1">10</family><parent type="1">n001_caiwc2</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc2</pnode><ELK_ID>H08</ELK_ID></node><node flag="0" nodeDefId="WC8AI" nls="108WA"><address>n001_caiwc2_a3</address><name>AtticAnalog3</name><family instance="1">10</family><parent type="1">n001_caiwc2</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc2</pnode><ELK_ID>H09</ELK_ID></node><node flag="0" nodeDefId="UZW007B"><address>ZW036_157</address><name>ZW 036 Tamper Alarm 1</name><family>4</family><parent type="1">ZW036_1</parent><type>4.33.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW036_1</pnode><sgid>157</sgid><devtype><gen>4.33.1</gen><mfg>134.258.100</mfg><cat>157</cat></devtype><ELK_ID>H10</ELK_ID><property id="ST" value="0" formatted="Off" uom="78" /></node><node flag="0" nodeDefId="UZW007C"><address>ZW036_172</address><name>ZW 036 Intrusion Alarm 1</name><family>4</family><parent type="1">ZW036_1</parent><type>4.33.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW036_1</pnode><sgid>172</sgid><devtype><gen>4.33.1</gen><mfg>134.258.100</mfg><cat>172</cat></devtype><ELK_ID>H11</ELK_ID><property id="ST" value="0" formatted="Off" uom="78" /></node><node flag="0" nodeDefId="UZW007D"><address>ZW036_173</address><name>ZW 036 Tamper Code Alarm 1</name><family>4</family><parent type="1">ZW036_1</parent><type>4.33.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW036_1</pnode><sgid>173</sgid><devtype><gen>4.33.1</gen><mfg>134.258.100</mfg><cat>173</cat></devtype><ELK_ID>H12</ELK_ID><property id="ST" value="0" formatted="Off" uom="78" /></node><node flag="0" nodeDefId="UZW007E"><address>ZW036_153</address><name>ZW 036 Glass Break Alarm 1</name><family>4</family><parent type="1">ZW036_1</parent><type>4.33.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW036_1</pnode><sgid>153</sgid><devtype><gen>4.33.1</gen><mfg>134.258.100</mfg><cat>153</cat></devtype><ELK_ID>H13</ELK_ID><property id="ST" value="0" formatted="Off" uom="78" /></node><node flag="128" nodeDefId="UZW007F"><address>ZW035_1</address><name>Garage 1 ZW 035 Notify Sensor</name><family>4</family><type>4.7.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW035_1</pnode><sgid>1</sgid><devtype><gen>4.7.1</gen><mfg>134.258.74</mfg><cat>185</cat><model>9</model></devtype><ELK_ID>H14</ELK_ID></node><node flag="128" nodeDefId="UZW0080"><address>ZW037_1</address><name>Garage ZW 037 Multilevel Sens</name><family>4</family><type>4.33.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW037_1</pnode><sgid>1</sgid><devtype><gen>4.33.1</gen><mfg>134.258.100</mfg><cat>118</cat></devtype><ELK_ID>H15</ELK_ID></node><node flag="0" nodeDefId="UZW0081"><address>ZW037_104</address><name>ZW 037 Binary Sensor 1</name><family>4</family><parent type="1">ZW037_1</parent><type>4.33.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW037_1</pnode><sgid>104</sgid><devtype><gen>4.33.1</gen><mfg>134.258.100</mfg><cat>104</cat></devtype><ELK_ID>H16</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="128" nodeDefId="UZW0083"><address>ZW034_1</address><name>Garage 2 ZW 034 Notify Sensor</name><family>4</family><type>4.7.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW034_1</pnode><sgid>1</sgid><devtype><gen>4.7.1</gen><mfg>134.258.74</mfg><cat>185</cat><model>9</model></devtype><ELK_ID>I02</ELK_ID></node><node flag="0" nodeDefId="UZW0084"><address>ZW037_155</address><name>ZW 037 Motion Sensor 1</name><family>4</family><parent type="1">ZW037_1</parent><type>4.33.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW037_1</pnode><sgid>155</sgid><devtype><gen>4.33.1</gen><mfg>134.258.100</mfg><cat>155</cat></devtype><ELK_ID>I03</ELK_ID><property id="ST" value="0" formatted="Off" uom="78" /></node><node flag="0" nodeDefId="UZW0085"><address>ZW037_172</address><name>ZW 037 Intrusion Alarm 1</name><family>4</family><parent type="1">ZW037_1</parent><type>4.33.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW037_1</pnode><sgid>172</sgid><devtype><gen>4.33.1</gen><mfg>134.258.100</mfg><cat>172</cat></devtype><ELK_ID>I04</ELK_ID><property id="ST" value="0" formatted="Off" uom="78" /></node><node flag="0" nodeDefId="UZW0086"><address>ZW037_157</address><name>ZW 037 Tamper Alarm 1</name><family>4</family><parent type="1">ZW037_1</parent><type>4.33.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW037_1</pnode><sgid>157</sgid><devtype><gen>4.33.1</gen><mfg>134.258.100</mfg><cat>157</cat></devtype><ELK_ID>I05</ELK_ID><property id="ST" value="0" formatted="Off" uom="78" /></node><node flag="0" nodeDefId="UZW0087"><address>ZW037_173</address><name>ZW 037 Tamper Code Alarm 1</name><family>4</family><parent type="1">ZW037_1</parent><type>4.33.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW037_1</pnode><sgid>173</sgid><devtype><gen>4.33.1</gen><mfg>134.258.100</mfg><cat>173</cat></devtype><ELK_ID>I06</ELK_ID><property id="ST" value="0" formatted="Off" uom="78" /></node><node flag="0" nodeDefId="UZW0088"><address>ZW037_153</address><name>ZW 037 Glass Break Alarm 1</name><family>4</family><parent type="1">ZW037_1</parent><type>4.33.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW037_1</pnode><sgid>153</sgid><devtype><gen>4.33.1</gen><mfg>134.258.100</mfg><cat>153</cat></devtype><ELK_ID>I07</ELK_ID><property id="ST" value="0" formatted="Off" uom="78" /></node><node flag="128" nodeDefId="UZW0089"><address>ZW038_1</address><name>Bedroom ZW 038 Thermostat</name><family>4</family><type>4.8.6.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW038_1</pnode><sgid>1</sgid><devtype><gen>4.8.6</gen><mfg>139.21586.21561</mfg><cat>140</cat></devtype><ELK_ID>I08</ELK_ID><property id="ST" value="69" formatted="69°F" uom="17" /><property id="CLIMD" value="3" formatted="Auto" uom="67" /><property id="CLISPC" value="77" formatted="77°F" uom="17" /><property id="CLISPH" value="66" formatted="66°F" uom="17" /></node><node flag="0" nodeDefId="UZW008A"><address>ZW038_118</address><name>ZW 038 Multilevel Sensor</name><family>4</family><parent type="1">ZW038_1</parent><type>4.8.6.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW038_1</pnode><sgid>118</sgid><devtype><gen>4.8.6</gen><mfg>139.21586.21561</mfg><cat>118</cat></devtype><ELK_ID>I09</ELK_ID></node><node flag="128" nodeDefId="UZW008B"><address>ZW040_1</address><name>Patio outlet ZW 040 On-Off Po</name><family>4</family><type>3.16.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW040_1</pnode><sgid>1</sgid><devtype><gen>3.16.1</gen><mfg>5.1.3</mfg><cat>121</cat></devtype><ELK_ID>I10</ELK_ID><property id="ST" value="0" formatted="Off" uom="78" /></node><node flag="0" nodeDefId="UZW008D"><address>ZW035_104</address><name>ZW 035 Binary Sensor 1</name><family>4</family><parent type="1">ZW035_1</parent><type>4.7.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW035_1</pnode><sgid>104</sgid><devtype><gen>4.7.1</gen><mfg>134.258.74</mfg><cat>104</cat><model>9</model></devtype><ELK_ID>I12</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="0" nodeDefId="UZW008E"><address>ZW035_118</address><name>ZW 035 Multilevel Sensor 1</name><family>4</family><parent type="1">ZW035_1</parent><type>4.7.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW035_1</pnode><sgid>118</sgid><devtype><gen>4.7.1</gen><mfg>134.258.74</mfg><cat>118</cat><model>9</model></devtype><ELK_ID>I13</ELK_ID></node><node flag="0" nodeDefId="UZW008F"><address>ZW034_104</address><name>ZW 034 Binary Sensor 1</name><family>4</family><parent type="1">ZW034_1</parent><type>4.7.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW034_1</pnode><sgid>104</sgid><devtype><gen>4.7.1</gen><mfg>134.258.74</mfg><cat>104</cat><model>9</model></devtype><ELK_ID>I14</ELK_ID><property id="ST" value="0" formatted="Off" uom="78" /></node><node flag="128" nodeDefId="UZW0090"><address>ZW047_1</address><name>Pool outlet ZW 047 On-Off Pow</name><family>4</family><type>3.16.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW047_1</pnode><sgid>1</sgid><devtype><gen>3.16.1</gen><mfg>5.1.3</mfg><cat>121</cat></devtype><ELK_ID>I15</ELK_ID><property id="ST" value="0" formatted="Off" uom="78" /></node><node flag="128" nodeDefId="WC8" nls="108W"><address>n001_caiwc1</address><name>PoolWebControl</name><family instance="1">10</family><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc1</pnode><ELK_ID>I16</ELK_ID></node><node flag="0" nodeDefId="WC8H" nls="108WH"><address>n001_caiwc1_h</address><name>PoolHumidity</name><family instance="1">10</family><parent type="1">n001_caiwc1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc1</pnode><ELK_ID>J01</ELK_ID></node><node flag="0" nodeDefId="WC8DI" nls="108WI"><address>n001_caiwc1_i1</address><name>PoolInput1</name><family instance="1">10</family><parent type="1">n001_caiwc1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc1</pnode><ELK_ID>J02</ELK_ID></node><node flag="0" nodeDefId="WC8V" nls="108WV"><address>n001_caiwc1_v1</address><name>PoolVariable1</name><family instance="1">10</family><parent type="1">n001_caiwc1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc1</pnode><ELK_ID>J03</ELK_ID></node><node flag="0" nodeDefId="UZW0095"><address>ZW012_172</address><name>Doggy Door ZW 012 Intrusion A</name><family>4</family><parent type="1">ZW012_1</parent><type>4.33.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW012_1</pnode><sgid>172</sgid><devtype><gen>4.33.1</gen><mfg>134.258.100</mfg><cat>172</cat></devtype><ELK_ID>J04</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="0" nodeDefId="UZW0096"><address>ZW012_157</address><name>Doggy Door ZW 012 Tamper Alar</name><family>4</family><parent type="1">ZW012_1</parent><type>4.33.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW012_1</pnode><sgid>157</sgid><devtype><gen>4.33.1</gen><mfg>134.258.100</mfg><cat>157</cat></devtype><ELK_ID>J05</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="0" nodeDefId="UZW0097"><address>ZW012_173</address><name>Doggy Door ZW 012 Tamper Code</name><family>4</family><parent type="1">ZW012_1</parent><type>4.33.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW012_1</pnode><sgid>173</sgid><devtype><gen>4.33.1</gen><mfg>134.258.100</mfg><cat>173</cat></devtype><ELK_ID>J06</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="0" nodeDefId="UZW0098"><address>ZW012_153</address><name>Doggy Door ZW 012 Glass Break</name><family>4</family><parent type="1">ZW012_1</parent><type>4.33.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW012_1</pnode><sgid>153</sgid><devtype><gen>4.33.1</gen><mfg>134.258.100</mfg><cat>153</cat></devtype><ELK_ID>J07</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="0" nodeDefId="UZW0099"><address>ZW012_155</address><name>Doggy Door ZW 012 Motion Sens</name><family>4</family><parent type="1">ZW012_1</parent><type>4.33.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW012_1</pnode><sgid>155</sgid><devtype><gen>4.33.1</gen><mfg>134.258.100</mfg><cat>155</cat></devtype><ELK_ID>J08</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="0" nodeDefId="UZW009A"><address>ZW010_172</address><name>Livingroom ZW 010 Intrusion A</name><family>4</family><parent type="1">ZW010_1</parent><type>4.33.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW010_1</pnode><sgid>172</sgid><devtype><gen>4.33.1</gen><mfg>134.258.100</mfg><cat>172</cat></devtype><ELK_ID>J09</ELK_ID><property id="ST" value="0" formatted="Off" uom="78" /></node><node flag="0" nodeDefId="UZW009C"><address>ZW010_157</address><name>Livingroom ZW 010 Tamper Alar</name><family>4</family><parent type="1">ZW010_1</parent><type>4.33.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW010_1</pnode><sgid>157</sgid><devtype><gen>4.33.1</gen><mfg>134.258.100</mfg><cat>157</cat></devtype><ELK_ID>J11</ELK_ID><property id="ST" value="0" formatted="Off" uom="78" /></node><node flag="0" nodeDefId="UZW009D"><address>ZW010_173</address><name>Livingroom ZW 010 Tamper Code</name><family>4</family><parent type="1">ZW010_1</parent><type>4.33.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW010_1</pnode><sgid>173</sgid><devtype><gen>4.33.1</gen><mfg>134.258.100</mfg><cat>173</cat></devtype><ELK_ID>J12</ELK_ID><property id="ST" value="0" formatted="Off" uom="78" /></node><node flag="0" nodeDefId="UZW009E"><address>ZW010_153</address><name>Livingroom ZW 010 Glass Break</name><family>4</family><parent type="1">ZW010_1</parent><type>4.33.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW010_1</pnode><sgid>153</sgid><devtype><gen>4.33.1</gen><mfg>134.258.100</mfg><cat>153</cat></devtype><ELK_ID>J13</ELK_ID><property id="ST" value="0" formatted="Off" uom="78" /></node><node flag="0" nodeDefId="UZW009F"><address>ZW010_155</address><name>Livingroom ZW 010 Motion Sens</name><family>4</family><parent type="1">ZW010_1</parent><type>4.33.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW010_1</pnode><sgid>155</sgid><devtype><gen>4.33.1</gen><mfg>134.258.100</mfg><cat>155</cat></devtype><ELK_ID>J14</ELK_ID><property id="ST" value="100" formatted="On" uom="78" /></node><node flag="0" nodeDefId="WC8DO" nls="108WO"><address>n001_caiwc1_o1</address><name>PoolOutput1</name><family instance="1">10</family><parent type="1">n001_caiwc1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc1</pnode><ELK_ID>J15</ELK_ID></node><node flag="0" nodeDefId="WC8T" nls="108WT"><address>n001_caiwc1_t1</address><name>PoolTemperature1</name><family instance="1">10</family><parent type="1">n001_caiwc1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc1</pnode><ELK_ID>J16</ELK_ID></node><node flag="0" nodeDefId="WC8DI" nls="108WI"><address>n001_caiwc1_i2</address><name>PoolInput2</name><family instance="1">10</family><parent type="1">n001_caiwc1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc1</pnode><ELK_ID>K01</ELK_ID></node><node flag="0" nodeDefId="WC8V" nls="108WV"><address>n001_caiwc1_v2</address><name>PoolVariable2</name><family instance="1">10</family><parent type="1">n001_caiwc1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc1</pnode><ELK_ID>K02</ELK_ID></node><node flag="0" nodeDefId="WC8DO" nls="108WO"><address>n001_caiwc1_o2</address><name>PoolOutput2</name><family instance="1">10</family><parent type="1">n001_caiwc1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc1</pnode><ELK_ID>K03</ELK_ID></node><node flag="0" nodeDefId="UZW00A5"><address>ZW009_172</address><name>Familyroom ZW 009 Intrusion A</name><family>4</family><parent type="1">ZW009_1</parent><type>4.33.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW009_1</pnode><sgid>172</sgid><devtype><gen>4.33.1</gen><mfg>134.258.100</mfg><cat>172</cat></devtype><ELK_ID>K04</ELK_ID><property id="ST" value="0" formatted="Off" uom="78" /></node><node flag="0" nodeDefId="UZW00A6"><address>ZW009_157</address><name>Familyroom ZW 009 Tamper Alar</name><family>4</family><parent type="1">ZW009_1</parent><type>4.33.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW009_1</pnode><sgid>157</sgid><devtype><gen>4.33.1</gen><mfg>134.258.100</mfg><cat>157</cat></devtype><ELK_ID>K05</ELK_ID><property id="ST" value="0" formatted="Off" uom="78" /></node><node flag="0" nodeDefId="UZW00A7"><address>ZW009_173</address><name>Familyroom ZW 009 Tamper Code</name><family>4</family><parent type="1">ZW009_1</parent><type>4.33.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW009_1</pnode><sgid>173</sgid><devtype><gen>4.33.1</gen><mfg>134.258.100</mfg><cat>173</cat></devtype><ELK_ID>K06</ELK_ID><property id="ST" value="0" formatted="Off" uom="78" /></node><node flag="0" nodeDefId="UZW00A8"><address>ZW009_153</address><name>Familyroom ZW 009 Glass Break</name><family>4</family><parent type="1">ZW009_1</parent><type>4.33.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW009_1</pnode><sgid>153</sgid><devtype><gen>4.33.1</gen><mfg>134.258.100</mfg><cat>153</cat></devtype><ELK_ID>K07</ELK_ID><property id="ST" value="0" formatted="Off" uom="78" /></node><node flag="0" nodeDefId="UZW00A9"><address>ZW009_155</address><name>Familyroom ZW 009 Motion Sens</name><family>4</family><parent type="1">ZW009_1</parent><type>4.33.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW009_1</pnode><sgid>155</sgid><devtype><gen>4.33.1</gen><mfg>134.258.100</mfg><cat>155</cat></devtype><ELK_ID>K08</ELK_ID><property id="ST" value="100" formatted="On" uom="78" /></node><node flag="0" nodeDefId="UZW00AA"><address>ZW034_118</address><name>ZW 034 Multilevel Sensor 1</name><family>4</family><parent type="1">ZW034_1</parent><type>4.7.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW034_1</pnode><sgid>118</sgid><devtype><gen>4.7.1</gen><mfg>134.258.74</mfg><cat>118</cat><model>9</model></devtype><ELK_ID>K09</ELK_ID></node><node flag="128" nodeDefId="UZW00AB"><address>ZW018_1</address><name>ZW 018 Smoke Alarm</name><family>4</family><type>4.161.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW018_1</pnode><sgid>1</sgid><devtype><gen>4.161.0</gen><mfg>312.1.2</mfg><cat>156</cat><model>8</model></devtype><ELK_ID>K10</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="0" nodeDefId="UZW00AC"><address>ZW018_164</address><name>ZW 018 Malfunction Alarm</name><family>4</family><parent type="1">ZW018_1</parent><type>4.161.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW018_1</pnode><sgid>164</sgid><devtype><gen>4.161.0</gen><mfg>312.1.2</mfg><cat>164</cat><model>8</model></devtype><ELK_ID>K11</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="0" nodeDefId="UZW00AD"><address>ZW018_161</address><name>ZW 018 Test Alarm</name><family>4</family><parent type="1">ZW018_1</parent><type>4.161.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW018_1</pnode><sgid>161</sgid><devtype><gen>4.161.0</gen><mfg>312.1.2</mfg><cat>161</cat><model>8</model></devtype><ELK_ID>K12</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="0" nodeDefId="UZW00AE"><address>ZW018_162</address><name>ZW 018 Low Battery</name><family>4</family><parent type="1">ZW018_1</parent><type>4.161.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW018_1</pnode><sgid>162</sgid><devtype><gen>4.161.0</gen><mfg>312.1.2</mfg><cat>162</cat><model>8</model></devtype><ELK_ID>K13</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="0" nodeDefId="UZW00AF"><address>ZW018_165</address><name>ZW 018 Heartbeat</name><family>4</family><parent type="1">ZW018_1</parent><type>4.161.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW018_1</pnode><sgid>165</sgid><devtype><gen>4.161.0</gen><mfg>312.1.2</mfg><cat>165</cat><model>8</model></devtype><ELK_ID>K14</ELK_ID></node><node flag="0" nodeDefId="UZW00B0"><address>ZW018_151</address><name>ZW 018 CO Alarm</name><family>4</family><parent type="1">ZW018_1</parent><type>4.161.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW018_1</pnode><sgid>151</sgid><devtype><gen>4.161.0</gen><mfg>312.1.2</mfg><cat>151</cat><model>8</model></devtype><ELK_ID>K15</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="0" nodeDefId="UZW00B1"><address>ZW018_163</address><name>ZW 018 CO End Of Life Alarm</name><family>4</family><parent type="1">ZW018_1</parent><type>4.161.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW018_1</pnode><sgid>163</sgid><devtype><gen>4.161.0</gen><mfg>312.1.2</mfg><cat>163</cat><model>8</model></devtype><ELK_ID>K16</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="0" nodeDefId="WC8T" nls="108WT"><address>n001_caiwc1_t2</address><name>PoolTemperature2</name><family instance="1">10</family><parent type="1">n001_caiwc1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc1</pnode><ELK_ID>L01</ELK_ID></node><node flag="0" nodeDefId="UZW00B3"><address>ZW035_155</address><name>ZW 035 Motion Sensor 1</name><family>4</family><parent type="1">ZW035_1</parent><type>4.7.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW035_1</pnode><sgid>155</sgid><devtype><gen>4.7.1</gen><mfg>134.258.74</mfg><cat>155</cat><model>9</model></devtype><ELK_ID>L02</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="0" nodeDefId="WC8DI" nls="108WI"><address>n001_caiwc1_i3</address><name>PoolInput3</name><family instance="1">10</family><parent type="1">n001_caiwc1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc1</pnode><ELK_ID>L04</ELK_ID></node><node flag="0" nodeDefId="UZW00B6"><address>ZW012_162</address><name>Doggy Door ZW 012 Low Battery</name><family>4</family><parent type="1">ZW012_1</parent><type>4.33.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW012_1</pnode><sgid>162</sgid><devtype><gen>4.33.1</gen><mfg>134.258.100</mfg><cat>162</cat></devtype><ELK_ID>L05</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="0" nodeDefId="UZW00B7"><address>ZW009_162</address><name>Familyroom ZW 009 Low Battery</name><family>4</family><parent type="1">ZW009_1</parent><type>4.33.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW009_1</pnode><sgid>162</sgid><devtype><gen>4.33.1</gen><mfg>134.258.100</mfg><cat>162</cat></devtype><ELK_ID>L06</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="0" nodeDefId="UZW00B8"><address>ZW034_155</address><name>ZW 034 Motion Sensor 1</name><family>4</family><parent type="1">ZW034_1</parent><type>4.7.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW034_1</pnode><sgid>155</sgid><devtype><gen>4.7.1</gen><mfg>134.258.74</mfg><cat>155</cat><model>9</model></devtype><ELK_ID>L07</ELK_ID><property id="ST" value="100" formatted="On" uom="78" /></node><node flag="128" nodeDefId="UZW00B9"><address>ZW023_1</address><name>Garage Door 2 Car ZW 023 Barr</name><family>4</family><type>4.64.7.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW023_1</pnode><sgid>1</sgid><devtype><gen>4.64.7</gen><mfg>335.18244.13616</mfg><cat>184</cat></devtype><ELK_ID>L08</ELK_ID><property id="ST" value="0" formatted="Closed" uom="97" /></node><node flag="0" nodeDefId="UZW00BB"><address>ZW010_162</address><name>Livingroon ZW 010 Low Battery</name><family>4</family><parent type="1">ZW010_1</parent><type>4.33.1.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW010_1</pnode><sgid>162</sgid><devtype><gen>4.33.1</gen><mfg>134.258.100</mfg><cat>162</cat></devtype><ELK_ID>L10</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="0" nodeDefId="WC8V" nls="108WV"><address>n001_caiwc1_v3</address><name>PoolVariable3</name><family instance="1">10</family><parent type="1">n001_caiwc1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc1</pnode><ELK_ID>L11</ELK_ID></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>4C 2F ED 1</address><name>Master Closet</name><type>1.32.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>4C 2F ED 1</pnode><ELK_ID>L14</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>4C 48 52 1</address><name>Master Bath Sink</name><type>1.32.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>4C 48 52 1</pnode><ELK_ID>L15</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>4C 4C CD 1</address><name>Master Bath Tub</name><type>1.32.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>4C 4C CD 1</pnode><ELK_ID>L16</ELK_ID><property id="ST" value="0" formatted="0%" uom="100" /></node><node flag="0" nodeDefId="WC8DO" nls="108WO"><address>n001_caiwc1_o3</address><name>PoolOutput3</name><family instance="1">10</family><parent type="1">n001_caiwc1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc1</pnode><ELK_ID>M03</ELK_ID></node><node flag="0" nodeDefId="WC8T" nls="108WT"><address>n001_caiwc1_t3</address><name>PoolTemperature3</name><family instance="1">10</family><parent type="1">n001_caiwc1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc1</pnode><ELK_ID>M04</ELK_ID></node><node flag="0" nodeDefId="WC8DI" nls="108WI"><address>n001_caiwc1_i4</address><name>PoolInput4</name><family instance="1">10</family><parent type="1">n001_caiwc1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc1</pnode><ELK_ID>M05</ELK_ID></node><node flag="0" nodeDefId="WC8V" nls="108WV"><address>n001_caiwc1_v4</address><name>PoolVariable4</name><family instance="1">10</family><parent type="1">n001_caiwc1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc1</pnode><ELK_ID>M06</ELK_ID></node><node flag="0" nodeDefId="WC8DO" nls="108WO"><address>n001_caiwc1_o4</address><name>PoolOutput4</name><family instance="1">10</family><parent type="1">n001_caiwc1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc1</pnode><ELK_ID>M07</ELK_ID></node><node flag="0" nodeDefId="WC8T" nls="108WT"><address>n001_caiwc1_t4</address><name>PoolTemperature4</name><family instance="1">10</family><parent type="1">n001_caiwc1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc1</pnode><ELK_ID>M08</ELK_ID></node><node flag="0" nodeDefId="WC8DI" nls="108WI"><address>n001_caiwc1_i5</address><name>PoolInput5</name><family instance="1">10</family><parent type="1">n001_caiwc1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc1</pnode><ELK_ID>M09</ELK_ID></node><node flag="0" nodeDefId="WC8V" nls="108WV"><address>n001_caiwc1_v5</address><name>PoolVariable5</name><family instance="1">10</family><parent type="1">n001_caiwc1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc1</pnode><ELK_ID>M10</ELK_ID></node><node flag="0" nodeDefId="WC8DO" nls="108WO"><address>n001_caiwc1_o5</address><name>PoolOutput5</name><family instance="1">10</family><parent type="1">n001_caiwc1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc1</pnode><ELK_ID>M11</ELK_ID></node><node flag="0" nodeDefId="WC8T" nls="108WT"><address>n001_caiwc1_t5</address><name>PoolTemperature5</name><family instance="1">10</family><parent type="1">n001_caiwc1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc1</pnode><ELK_ID>M12</ELK_ID></node><node flag="0" nodeDefId="WC8DI" nls="108WI"><address>n001_caiwc1_i6</address><name>PoolInput6</name><family instance="1">10</family><parent type="1">n001_caiwc1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc1</pnode><ELK_ID>M13</ELK_ID></node><node flag="128" nodeDefId="UZW00CF"><address>ZW029_1</address><name>Back Door ZW 029 Yale Door Lo</name><family>4</family><type>4.64.3.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW029_1</pnode><sgid>1</sgid><devtype><gen>4.64.3</gen><mfg>297.32770.1536</mfg><cat>111</cat><model>5</model></devtype><ELK_ID>M14</ELK_ID><property id="ST" value="100" formatted="Locked" uom="11" /></node><node flag="128" nodeDefId="UZW00D0"><address>ZW030_1</address><name>Front Door ZW 030 Yale Door L</name><family>4</family><type>4.64.3.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>ZW030_1</pnode><sgid>1</sgid><devtype><gen>4.64.3</gen><mfg>297.32770.1536</mfg><cat>111</cat><model>5</model></devtype><ELK_ID>M15</ELK_ID><property id="ST" value="100" formatted="Locked" uom="11" /></node><node flag="0" nodeDefId="WC8V" nls="108WV"><address>n001_caiwc1_v6</address><name>PoolVariable6</name><family instance="1">10</family><parent type="1">n001_caiwc1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc1</pnode><ELK_ID>M16</ELK_ID></node><node flag="128" nodeDefId="RainMachine" nls="123R"><address>n001_rain1</address><name>RainMachine</name><family instance="1">10</family><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_rain1</pnode><ELK_ID>N01</ELK_ID></node><node flag="0" nodeDefId="RainMachineProgram" nls="123RP"><address>n001_rain1_p1</address><name>New Program</name><family instance="1">10</family><parent type="1">n001_rain1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_rain1</pnode><ELK_ID>N02</ELK_ID></node><node flag="0" nodeDefId="RainMachineZone" nls="123RZ"><address>n001_rain1_z1</address><name>Zone 1</name><family instance="1">10</family><parent type="1">n001_rain1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_rain1</pnode><ELK_ID>N03</ELK_ID></node><node flag="0" nodeDefId="RainMachineZone" nls="123RZ"><address>n001_rain1_z2</address><name>Zone 2</name><family instance="1">10</family><parent type="1">n001_rain1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_rain1</pnode><ELK_ID>N04</ELK_ID></node><node flag="0" nodeDefId="RainMachineZone" nls="123RZ"><address>n001_rain1_z3</address><name>Zone 3</name><family instance="1">10</family><parent type="1">n001_rain1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_rain1</pnode><ELK_ID>N05</ELK_ID></node><node flag="0" nodeDefId="RainMachineZone" nls="123RZ"><address>n001_rain1_z4</address><name>Zone 4</name><family instance="1">10</family><parent type="1">n001_rain1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_rain1</pnode><ELK_ID>N06</ELK_ID></node><node flag="0" nodeDefId="RainMachineZone" nls="123RZ"><address>n001_rain1_z5</address><name>Zone 5</name><family instance="1">10</family><parent type="1">n001_rain1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_rain1</pnode><ELK_ID>N07</ELK_ID></node><node flag="0" nodeDefId="RainMachineZone" nls="123RZ"><address>n001_rain1_z6</address><name>Zone 6</name><family instance="1">10</family><parent type="1">n001_rain1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_rain1</pnode><ELK_ID>N08</ELK_ID></node><node flag="0" nodeDefId="RainMachineZone" nls="123RZ"><address>n001_rain1_z7</address><name>Zone 7</name><family instance="1">10</family><parent type="1">n001_rain1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_rain1</pnode><ELK_ID>N09</ELK_ID></node><node flag="0" nodeDefId="RainMachineZone" nls="123RZ"><address>n001_rain1_z8</address><name>Zone 8</name><family instance="1">10</family><parent type="1">n001_rain1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_rain1</pnode><ELK_ID>N10</ELK_ID></node><node flag="0" nodeDefId="WC8DO" nls="108WO"><address>n001_caiwc1_o6</address><name>PoolOutput6</name><family instance="1">10</family><parent type="1">n001_caiwc1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc1</pnode><ELK_ID>N11</ELK_ID></node><node flag="0" nodeDefId="WC8T" nls="108WT"><address>n001_caiwc1_t6</address><name>PoolTemperature6</name><family instance="1">10</family><parent type="1">n001_caiwc1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc1</pnode><ELK_ID>N12</ELK_ID></node><node flag="0" nodeDefId="WC8DI" nls="108WI"><address>n001_caiwc1_i7</address><name>PoolInput7</name><family instance="1">10</family><parent type="1">n001_caiwc1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc1</pnode><ELK_ID>N13</ELK_ID></node><node flag="0" nodeDefId="WC8V" nls="108WV"><address>n001_caiwc1_v7</address><name>PoolVariable7</name><family instance="1">10</family><parent type="1">n001_caiwc1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc1</pnode><ELK_ID>N14</ELK_ID></node><node flag="0" nodeDefId="WC8DO" nls="108WO"><address>n001_caiwc1_o7</address><name>PoolOutput7</name><family instance="1">10</family><parent type="1">n001_caiwc1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc1</pnode><ELK_ID>N15</ELK_ID></node><node flag="0" nodeDefId="WC8T" nls="108WT"><address>n001_caiwc1_t7</address><name>PoolTemperature7</name><family instance="1">10</family><parent type="1">n001_caiwc1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc1</pnode><ELK_ID>N16</ELK_ID></node><node flag="0" nodeDefId="WC8DI" nls="108WI"><address>n001_caiwc1_i8</address><name>PoolInput8</name><family instance="1">10</family><parent type="1">n001_caiwc1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc1</pnode><ELK_ID>O01</ELK_ID></node><node flag="0" nodeDefId="WC8V" nls="108WV"><address>n001_caiwc1_v8</address><name>PoolVariable8</name><family instance="1">10</family><parent type="1">n001_caiwc1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc1</pnode><ELK_ID>O02</ELK_ID></node><node flag="0" nodeDefId="WC8DO" nls="108WO"><address>n001_caiwc1_o8</address><name>PoolOutput8</name><family instance="1">10</family><parent type="1">n001_caiwc1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc1</pnode><ELK_ID>O03</ELK_ID></node><node flag="0" nodeDefId="WC8T" nls="108WT"><address>n001_caiwc1_t8</address><name>PoolTemperature8</name><family instance="1">10</family><parent type="1">n001_caiwc1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc1</pnode><ELK_ID>O04</ELK_ID></node><node flag="0" nodeDefId="WC8AI" nls="108WA"><address>n001_caiwc1_a1</address><name>PoolAnalog1</name><family instance="1">10</family><parent type="1">n001_caiwc1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc1</pnode><ELK_ID>O05</ELK_ID></node><node flag="0" nodeDefId="WC8AI" nls="108WA"><address>n001_caiwc1_a2</address><name>PoolAnalog2</name><family instance="1">10</family><parent type="1">n001_caiwc1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc1</pnode><ELK_ID>O06</ELK_ID></node><node flag="0" nodeDefId="WC8AI" nls="108WA"><address>n001_caiwc1_a3</address><name>PoolAnalog3</name><family instance="1">10</family><parent type="1">n001_caiwc1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_caiwc1</pnode><ELK_ID>O07</ELK_ID></node><group flag="12" nodeDefId="InsteonDimmer"><address>00:21:b9:02:26:a7</address><name>ISY</name><family>6</family><members><link type="0">00:21:b9:02:26:a7</link><link type="0">ADR0001</link><link type="0">n002_occ2geo01</link><link type="0">4C 37 F 1</link><link type="0">42 9F 28 1</link><link type="0">ZW004_1</link><link type="0">ZW004_118</link><link type="0">ZW005_1</link><link type="0">40 CF DA 1</link><link type="0">40 CF DA 3</link><link type="0">2A EB 8E 1</link><link type="0">32604</link><link type="0">41 98 A2 1</link><link type="0">41 9D 4 1</link><link type="0">41 A4 70 1</link><link type="0">60862</link><link type="0">2C 54 E1 1</link><link type="0">15256</link><link type="0">41 9E 41 1</link><link type="0">41 9D 3F 1</link><link type="0">41 A0 76 1</link><link type="0">41 B8 20 1</link><link type="0">44079</link><link type="0">40 CF DA 4</link><link type="0">40 CF DA 5</link><link type="0">40 CF DA 6</link><link type="0">ZW005_118</link><link type="0">ZW006_1</link><link type="0">41 AD 1D 1</link><link type="0">30486</link><link type="0">4596</link><link type="0">6812</link><link type="0">5918</link><link type="0">28204</link><link type="0">48135</link><link type="0">3E 22 E 1</link><link type="0">41 A2 1E 1</link><link type="0">53025</link><link type="0">ZW007_1</link><link type="0">46 B9 39 1</link><link type="0">4C CB EF 1</link><link type="0">ZW009_1</link><link type="0">ZW010_1</link><link type="0">ZW036_1</link><link type="0">ZW012_1</link><link type="0">41 BB 51 1</link><link type="0">n002_occ2dev001</link><link type="0">n002_occ2dev002</link><link type="0">ZW012_104</link><link type="0">4C 51 54 1</link><link type="0">40 CD 56 1</link><link type="0">40 CD 56 3</link><link type="0">40 CD 56 4</link><link type="0">2D 7D 5A 1</link><link type="0">2D 7D 5A 2</link><link type="0">40 CD 56 5</link><link type="0">40 CD 56 6</link><link type="0">42 A9 7B 1</link><link type="0">4C 2F 81 1</link><link type="0">42 8F 74 1</link><link type="0">50338</link><link type="0">3F 2C E2 1</link><link type="0">62432</link><link type="0">ZW031_1</link><link type="0">ZW031_104</link><link type="0">ZW036_104</link><link type="0">ZW032_1</link><link type="0">ZW032_104</link><link type="0">ZW036_155</link><link type="0">ZW033_1</link><link type="0">ZW033_104</link><link type="0">4C 4F 68 1</link><link type="0">4B DC FE 1</link><link type="0">40 CC F6 1</link><link type="0">40 CC F6 3</link><link type="0">40 CC F6 4</link><link type="0">40 CC F6 5</link><link type="0">40 CC F6 6</link><link type="0">42 9C 20 1</link><link type="0">42 A9 83 1</link><link type="0">2D 7C C4 1</link><link type="0">2D 7C C4 2</link><link type="0">4C 25 A9 1</link><link type="0">4B EB FA 1</link><link type="0">42428</link><link type="0">n001_caiwc2</link><link type="0">n001_caiwc2_h</link><link type="0">n001_caiwc2_i1</link><link type="0">n001_caiwc2_v1</link><link type="0">n001_caiwc2_o1</link><link type="0">n001_caiwc2_t1</link><link type="0">n001_caiwc2_i2</link><link type="0">n001_caiwc2_v2</link><link type="0">n001_caiwc2_o2</link><link type="0">n001_caiwc2_t2</link><link type="0">n001_caiwc2_i3</link><link type="0">n001_caiwc2_v3</link><link type="0">n001_caiwc2_o3</link><link type="0">n001_caiwc2_t3</link><link type="0">n001_caiwc2_i4</link><link type="0">n001_caiwc2_v4</link><link type="0">n001_caiwc2_o4</link><link type="0">n001_caiwc2_t4</link><link type="0">n001_caiwc2_i5</link><link type="0">n001_caiwc2_v5</link><link type="0">n001_caiwc2_o5</link><link type="0">n001_caiwc2_t5</link><link type="0">n001_caiwc2_i6</link><link type="0">n001_caiwc2_v6</link><link type="0">n001_caiwc2_o6</link><link type="0">n001_caiwc2_t6</link><link type="0">n001_caiwc2_i7</link><link type="0">n001_caiwc2_v7</link><link type="0">n001_caiwc2_o7</link><link type="0">n001_caiwc2_t7</link><link type="0">n001_caiwc2_i8</link><link type="0">n001_caiwc2_v8</link><link type="0">n001_caiwc2_o8</link><link type="0">n001_caiwc2_t8</link><link type="0">n001_caiwc2_a1</link><link type="0">n001_caiwc2_a2</link><link type="0">n001_caiwc2_a3</link><link type="0">ZW036_157</link><link type="0">ZW036_172</link><link type="0">ZW036_173</link><link type="0">ZW036_153</link><link type="0">ZW035_1</link><link type="0">ZW037_1</link><link type="0">ZW037_104</link><link type="0">38865</link><link type="0">ZW034_1</link><link type="0">ZW037_155</link><link type="0">ZW037_172</link><link type="0">ZW037_157</link><link type="0">ZW037_173</link><link type="0">ZW037_153</link><link type="0">ZW038_1</link><link type="0">ZW038_118</link><link type="0">ZW040_1</link><link type="0">16823</link><link type="0">ZW035_104</link><link type="0">ZW035_118</link><link type="0">ZW034_104</link><link type="0">ZW047_1</link><link type="0">n001_caiwc1</link><link type="0">n001_caiwc1_h</link><link type="0">n001_caiwc1_i1</link><link type="0">n001_caiwc1_v1</link><link type="0">ZW012_172</link><link type="0">ZW012_157</link><link type="0">ZW012_173</link><link type="0">ZW012_153</link><link type="0">ZW012_155</link><link type="0">ZW010_172</link><link type="0">554</link><link type="0">ZW010_157</link><link type="0">ZW010_173</link><link type="0">ZW010_153</link><link type="0">ZW010_155</link><link type="0">n001_caiwc1_o1</link><link type="0">n001_caiwc1_t1</link><link type="0">n001_caiwc1_i2</link><link type="0">n001_caiwc1_v2</link><link type="0">n001_caiwc1_o2</link><link type="0">ZW009_172</link><link type="0">ZW009_157</link><link type="0">ZW009_173</link><link type="0">ZW009_153</link><link type="0">ZW009_155</link><link type="0">ZW034_118</link><link type="0">ZW018_1</link><link type="0">ZW018_164</link><link type="0">ZW018_161</link><link type="0">ZW018_162</link><link type="0">ZW018_165</link><link type="0">ZW018_151</link><link type="0">ZW018_163</link><link type="0">n001_caiwc1_t2</link><link type="0">ZW035_155</link><link type="0">39717</link><link type="0">n001_caiwc1_i3</link><link type="0">ZW012_162</link><link type="0">ZW009_162</link><link type="0">ZW034_155</link><link type="0">ZW023_1</link><link type="0">38469</link><link type="0">ZW010_162</link><link type="0">n001_caiwc1_v3</link><link type="0">63652</link><link type="0">44614</link><link type="0">4C 2F ED 1</link><link type="0">4C 48 52 1</link><link type="0">4C 4C CD 1</link><link type="0">n001_caiwc1_o3</link><link type="0">n001_caiwc1_t3</link><link type="0">n001_caiwc1_i4</link><link type="0">n001_caiwc1_v4</link><link type="0">n001_caiwc1_o4</link><link type="0">n001_caiwc1_t4</link><link type="0">n001_caiwc1_i5</link><link type="0">n001_caiwc1_v5</link><link type="0">n001_caiwc1_o5</link><link type="0">n001_caiwc1_t5</link><link type="0">n001_caiwc1_i6</link><link type="0">ZW029_1</link><link type="0">ZW030_1</link><link type="0">n001_caiwc1_v6</link><link type="0">n001_rain1</link><link type="0">n001_rain1_p1</link><link type="0">n001_rain1_z1</link><link type="0">n001_rain1_z2</link><link type="0">n001_rain1_z3</link><link type="0">n001_rain1_z4</link><link type="0">n001_rain1_z5</link><link type="0">n001_rain1_z6</link><link type="0">n001_rain1_z7</link><link type="0">n001_rain1_z8</link><link type="0">n001_caiwc1_o6</link><link type="0">n001_caiwc1_t6</link><link type="0">n001_caiwc1_i7</link><link type="0">n001_caiwc1_v7</link><link type="0">n001_caiwc1_o7</link><link type="0">n001_caiwc1_t7</link><link type="0">n001_caiwc1_i8</link><link type="0">n001_caiwc1_v8</link><link type="0">n001_caiwc1_o8</link><link type="0">n001_caiwc1_t8</link><link type="0">n001_caiwc1_a1</link><link type="0">n001_caiwc1_a2</link><link type="0">n001_caiwc1_a3</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>ADR0001</address><name>Auto DR</name><family>6</family><deviceGroup>16</deviceGroup><pnode>ADR0001</pnode><ELK_ID>A01</ELK_ID><members></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>32604</address><name>Night Lights</name><family>6</family><deviceGroup>17</deviceGroup><pnode>32604</pnode><ELK_ID>A11</ELK_ID><members><link type="0">2A EB 8E 1</link><link type="0">41 9D 4 1</link><link type="0">41 A4 70 1</link><link type="0">41 AD 1D 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>60862</address><name>Front Lights</name><family>6</family><deviceGroup>18</deviceGroup><pnode>60862</pnode><ELK_ID>A15</ELK_ID><members><link type="0">41 98 A2 1</link><link type="0">ZW007_1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>15256</address><name>Stairs 3 way</name><family>6</family><deviceGroup>19</deviceGroup><pnode>15256</pnode><ELK_ID>B01</ELK_ID><members><link type="16">41 9D 4 1</link><link type="16">41 A4 70 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>44079</address><name>Upstairs Hall</name><family>6</family><deviceGroup>20</deviceGroup><pnode>44079</pnode><ELK_ID>B06</ELK_ID><members><link type="16">41 A0 76 1</link><link type="16">41 B8 20 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>30486</address><name>Mermaid</name><family>6</family><deviceGroup>21</deviceGroup><pnode>30486</pnode><ELK_ID>B13</ELK_ID><members><link type="0">2A EB 8E 1</link><link type="16">41 AD 1D 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>4596</address><name>Familyroom Fan-Light</name><family>6</family><deviceGroup>22</deviceGroup><pnode>4596</pnode><ELK_ID>B14</ELK_ID><members><link type="16">40 CF DA 1</link><link type="0">2D 7D 5A 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>6812</address><name>Familyroom Fan High</name><family>6</family><deviceGroup>23</deviceGroup><pnode>6812</pnode><ELK_ID>B15</ELK_ID><members><link type="16">40 CF DA 3</link><link type="0">40 CF DA 4</link><link type="0">40 CF DA 5</link><link type="0">40 CF DA 6</link><link type="0">2D 7D 5A 2</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>5918</address><name>Familyroom Fan Med</name><family>6</family><deviceGroup>24</deviceGroup><pnode>5918</pnode><ELK_ID>B16</ELK_ID><members><link type="0">40 CF DA 3</link><link type="16">40 CF DA 4</link><link type="0">40 CF DA 5</link><link type="0">40 CF DA 6</link><link type="0">2D 7D 5A 2</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>28204</address><name>Familyroom Fan Low</name><family>6</family><deviceGroup>25</deviceGroup><pnode>28204</pnode><ELK_ID>C01</ELK_ID><members><link type="0">40 CF DA 3</link><link type="0">40 CF DA 4</link><link type="16">40 CF DA 5</link><link type="0">40 CF DA 6</link><link type="0">2D 7D 5A 2</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>48135</address><name>Familyroom Fan Off</name><family>6</family><deviceGroup>26</deviceGroup><pnode>48135</pnode><ELK_ID>C02</ELK_ID><members><link type="0">40 CF DA 3</link><link type="0">40 CF DA 4</link><link type="0">40 CF DA 5</link><link type="16">40 CF DA 6</link><link type="0">2D 7D 5A 2</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>53025</address><name>Kitchen</name><family>6</family><deviceGroup>27</deviceGroup><pnode>53025</pnode><ELK_ID>C05</ELK_ID><members><link type="16">3E 22 E 1</link><link type="16">41 A2 1E 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>50338</address><name>Hallway</name><family>6</family><deviceGroup>30</deviceGroup><pnode>50338</pnode><ELK_ID>D12</ELK_ID><members><link type="16">42 9F 28 1</link><link type="16">4C 2F 81 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>62432</address><name>Waterfall</name><family>6</family><deviceGroup>31</deviceGroup><pnode>62432</pnode><ELK_ID>D14</ELK_ID><members><link type="16">40 CD 56 3</link><link type="16">3F 2C E2 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>42428</address><name>Master Bed Ceiling Fan Light</name><family>6</family><deviceGroup>32</deviceGroup><pnode>42428</pnode><ELK_ID>F04</ELK_ID><members><link type="16">40 CC F6 1</link><link type="0">2D 7C C4 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>38865</address><name>Pool</name><family>6</family><deviceGroup>28</deviceGroup><pnode>38865</pnode><ELK_ID>I01</ELK_ID><members></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>16823</address><name>Patio Outlet</name><family>6</family><deviceGroup>37</deviceGroup><pnode>16823</pnode><ELK_ID>I11</ELK_ID><members><link type="16">40 CD 56 5</link><link type="0">ZW040_1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>554</address><name>test</name><family>6</family><deviceGroup>29</deviceGroup><pnode>554</pnode><ELK_ID>J10</ELK_ID><members></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>39717</address><name>Master Bed Ceiling Fan High</name><family>6</family><deviceGroup>33</deviceGroup><pnode>39717</pnode><ELK_ID>L03</ELK_ID><members><link type="16">40 CC F6 3</link><link type="0">40 CC F6 4</link><link type="0">40 CC F6 5</link><link type="0">40 CC F6 6</link><link type="0">2D 7C C4 2</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>38469</address><name>Master Bed Ceiling Fan Med</name><family>6</family><deviceGroup>34</deviceGroup><pnode>38469</pnode><ELK_ID>L09</ELK_ID><members><link type="0">40 CC F6 3</link><link type="16">40 CC F6 4</link><link type="0">40 CC F6 5</link><link type="0">40 CC F6 6</link><link type="0">2D 7C C4 2</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>63652</address><name>Master Bed Ceiling Fan Low</name><family>6</family><deviceGroup>35</deviceGroup><pnode>63652</pnode><ELK_ID>L12</ELK_ID><members><link type="0">40 CC F6 3</link><link type="0">40 CC F6 4</link><link type="16">40 CC F6 5</link><link type="0">40 CC F6 6</link><link type="0">2D 7C C4 2</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>44614</address><name>Master Bed Ceiling Fan Off</name><family>6</family><deviceGroup>36</deviceGroup><pnode>44614</pnode><ELK_ID>L13</ELK_ID><members><link type="0">40 CC F6 3</link><link type="0">40 CC F6 4</link><link type="0">40 CC F6 5</link><link type="16">40 CC F6 6</link><link type="0">2D 7C C4 2</link></members></group></nodes> (nodes)
2018-06-19 07:10:50 - ISY Receive: <editors>
   <editor id="I_INTEGER">
       <range uom="25" min="0" max="50000000" prec="0" />
   </editor>
   <editor id="I_INTEGER16">
       <range uom="25" min="0" max="65535" prec="0" />
   </editor>
   <editor id="I_TEL">
      <range uom="25" subset="0,1" nls="EN_PHONE_RINGING" />
   </editor>
   <editor id="I_TEL_NUMBER">
       <range uom="25" min="0" max="9999999" prec="0" />
   </editor>
   <editor id="I_TEL_AREACODE">
       <range uom="25" min="0" max="999" prec="0" />
   </editor>
   <editor id="I_FREQUENCY">
       <range uom="90" min="0" max="65535" prec="0" />
   </editor>
   <editor id="I_ANALOG">
       <range uom="25" min="0" max="1023" prec="0" />
   </editor>
   <editor id="I_BATTERY">
       <range uom="51" min="0" max="100" prec="0" />
   </editor>
   <editor id="I_FLOAT1">
       <range uom="25" min="0" max="50000000" prec="1" />
   </editor>
   <editor id="I_FLOAT2">
       <range uom="25" min="0" max="50000000" prec="2" />
   </editor>
   <editor id="I_DEGREE">
       <range uom="14" min="-360" max="360" prec="0" />
   </editor>
   <editor id="I_10DAYS">
      <range uom="25" min="0" max="10" prec="0" />
   </editor>
   <editor id="I_ODDEVEN">
      <range uom="25" subset="0,1" nls="EN_ODD" />
   </editor>
   <editor id="I_TIMEOFUSE">
      <range uom="25" subset="0-2" nls="EN_TOU" />
   </editor>
   <editor id="I_SEASON">
      <range uom="25" subset="1-4" nls="EN_SEASON" />
   </editor>
   <editor id="I_MONTH">
      <range uom="47" subset="1-12" />
   </editor>
   <editor id="I_DAYOFWEEK">
      <range uom="25" subset="0-6" nls="EN_DAY" />
   </editor>
   <editor id="I_SKY">
      <range uom="25" subset="0-34" nls="EN_SKY" />
   </editor>
   <editor id="I_WIND_DIRECTION">
      <range uom="25" subset="0-8" nls="EN_WIND_DIRECTION" />
   </editor>
   <editor id="I_WIND_C">
      <range uom="32" subset="0-500" />
   </editor>
   <editor id="I_WIND_F">
      <range uom="48" subset="0-500" />
   </editor>
   <editor id="I_WEATHER_SYMBOL">
      <range uom="25" subset="0-21" />
   </editor>
   <editor id="I_PRESSURE">
       <range uom="25" min="0" max="150" prec="2" />
   </editor>
   <editor id="I_ENABLED">
       <range uom="25" subset="0-1" nls="EN_ENABLED" />
   </editor>
   <editor id="I_SWITCH">
      <range uom="25" subset="0,255" nls="EN_SWITCH" />
   </editor>
   <editor id="I_DIMMER">
      <range uom="51" subset="0-100" />
   </editor>
   <editor id="I_MIDIMMER">
      <range uom="51" subset="10-100" />
   </editor>
   <editor id="I_COLOR">
      <range uom="25" subset="0-255" nls="EN_COLOR" />
   </editor>
   <editor id="I_COLORSET">
      <range uom="25" subset="0-15" nls="EN_COLORSET" />
   </editor>
   <editor id="I_NA">
      <range uom="25" subset="0" nls="EN_NA" />
   </editor>
   <editor id="I_RAINMACHINEPROGRAM">
      <range uom="25" subset="0-2" nls="EN_RAINMACHINEPROGRAM" />
   </editor>
   <editor id="I_RAIN_NEXTRUN">
      <range uom="25" subset="0-3" nls="EN_RAIN_NEXTRUN" />
   </editor>
   <editor id="I_BINARY">
      <range uom="25" subset="0-1" />
   </editor>
   <editor id="I_TRUE_BOOL">
      <range uom="25" subset="0-1" nls="EN_TRUE_BOOL" />
   </editor>
   <editor id="I_PHONE_RINGING">
      <range uom="25" subset="0-1" nls="EN_PHONE_RINGING" />
   </editor>
    <editor id="I_LOC_STATUS">
      <range uom="25" subset="0-1" nls="EN_LOC_STATUS" />
   </editor>
    <editor id="I_ERROR_STATUS">
      <range uom="25" subset="0-1" nls="EN_ERROR_STATUS" />
   </editor>
   <!-- Honeywell Alarm -->
   <editor id="I_HONALARM_STATUS">
       <range uom="25" subset="0-3" nls="EN_HONALARM_STATUS" />
   </editor>
   <!-- DSC -->
   <editor id="I_DSC_STANDARD">
       <range uom="25" subset="0-1" nls="EN_STATUS" />
   </editor>
    <editor id="I_DSC_STATUS">
       <range uom="25" subset="0-4" nls="EN_DSCSTAT" />
   </editor>
   <editor id="I_DSC_USER">
       <range uom="70" min="1" max="42" prec="0" />
   </editor>
   <editor id="I_ALARM_ZONE">
       <range uom="25" min="0" max="1" prec="0" nls="EN_ALARM_ZONE" />
   </editor>
   <editor id="I_DSC_PANIC">
      <range uom="25" subset="0-3" nls="EN_DSC_PANIC" />
   </editor>
   <editor id="I_HONTSTAT_FAN_MODE">
      <range uom="68" subset="0,1,6" />
   </editor>
   <editor id="I_HONTSTAT_STATUS">
      <range uom="25" subset="0-4" nls="EN_HONTSTAT_STATUS" />
   </editor>
   <!-- GEM -->
   <editor id="I_GEM_A">
       <range uom="1" min="0" max="200" prec="1" />
   </editor>
   <editor id="I_GEM_CO">
       <range uom="55" min="0" max="32768" prec="0" />
   </editor>
   <editor id="I_GEM_T">
       <range uom="14" min="0" max="500" prec="2" />
   </editor>
   <editor id="I_GEM_V">
       <range uom="72" min="0" max="300" prec="1" />
   </editor>
   <editor id="I_GEM_W">
       <range uom="73" min="0" max="50000" prec="0" />
   </editor>
   <editor id="I_GEM_WH">
       <range uom="33" min="0" max="500"  prec="2" />
   </editor>
   <editor id="I_GEM_RUNTIME">
      <range uom="10" min="0" max="5000000000" prec="2" />
   </editor>
    <!-- GenMon -->
   <editor id="I_GEN_MAINV">
   </editor>
   <editor id="I_GEN_BATTV">
       <range uom="72" min="0" max="300" />
   </editor>
   <editor id="I_GEN_FREQ">
       <range uom="90" min="0" max="100" />
   </editor>
   <editor id="I_GEN_SWITCHSTATE">
       <range uom="25" min="0" max="5" nls="EN_GEN_SWITCHSTATE" />
   </editor>
   <editor id="I_GEN_ENGINESTATE">
       <range uom="25" min="0" max="11" nls="EN_GEN_ENGINESTATE" />
   </editor>
   <editor id="I_GEN_TRANSFERSWITCHSTATE">
       <range uom="25" min="0" max="2" nls="EN_GEN_TRANSFERSWITCHSTATE" />
   </editor>
   <editor id="I_GEN_MONITORHEALTH">
       <range uom="25" min="0" max="2" nls="EN_GEN_MONITORHEALTH" />
   </editor>
   <!-- Temperature -->
   <editor id="I_TEMP">
      <range uom="14" min="-50" max="200" prec="2" />
   </editor>
   <editor id="I_TEMP_1">
      <range uom="14" min="-50" max="200" step="0.5" prec="1" />
   </editor>
   <editor id="I_TEMP_C">
      <range uom="14" min="-50" max="75" step="0.5" prec="1" />
   </editor>
   <editor id="I_TEMP_F">
      <range uom="14" min="-50" max="150" step="1" prec="0" />
   </editor>
   <editor id="I_SETTEMP_C">
      <range uom="14" min="0" max="10" step="0.5" prec="1" />
   </editor>
   <editor id="I_SETTEMP_F">
      <range uom="14" min="0" max="10" step="1" prec="0" />
   </editor>
   <!-- CLISPC -  Cool Setpoint -->
   <editor id="I_CLISPC_C">
      <range uom="14" min="5" max="35" step="0.5" prec="1" />
   </editor>
   <editor id="I_CLISPC_F">
      <range uom="14" min="32" max="90" step="1" prec="0"/>
   </editor>
   <!-- CLISPH -  Heat Setpoint -->
   <editor id="I_CLISPH_C">
   </editor>
   <editor id="I_CLISPH_F">
   </editor>
   <editor id="I_TSTAT_ALERT">
      <range uom="25" subset="0,1" nls="EN_ALERT" />
   </editor>
   <editor id="I_TSTAT_ECO_SCHED_TYPE">
      <range uom="25" subset="0-10" nls="EN_ECOSCH" />
   </editor>
   <editor id="I_TSTAT_ECO_SCHED_OPT">
      <range uom="25" subset="0-1" nls="EN_ECOSCH_OPT" />
   </editor>
   <editor id="I_TSTAT_FAN_MODE">
      <range uom="68" subset="0,1" />
   </editor>
   <editor id="I_TSTAT_FAN_STATE">
      <range uom="80" subset="0,1" />
   </editor>
   <editor id="I_TSTAT_FANONTIME">
      <range uom="25" min="0" max="55" step="1" prec="0" />
   </editor>
   <editor id="I_HEARTBEAT">
      <range uom="25" min="-1" max="1" step="1" prec="0" />
   </editor>
   <editor id="I_TSTAT_ECOHCS">
      <range uom="25" subset="0-8" nls="EN_ECOHCS" />
   </editor>
    <editor id="I_TSTAT_VEN_ACTSTAGE">
      <range uom="25" subset="0-4" />
   </editor>
   <editor id="I_TSTAT_HCS">
      <range uom="66" subset="0-2" />
   </editor>
   <editor id="I_HUMIDITY">
   </editor>
   <editor id="I_TSTAT_HUM_SET">
      <range uom="51" min="10" max="100" step="1" prec="0" />
   </editor>
   <editor id="I_TSTAT_LOC">
      <range uom="25" subset="0,1" nls="EN_LOC" />
   </editor>
   <editor id="I_TSTAT_MODE">
      <range uom="67" subset="0-3" />
   </editor>
   <editor id="I_TSTAT_OCC">
      <range uom="25" subset="0,1" nls="EN_BOOL" />
   </editor>
   <editor id="I_TSTAT_PROG_MODE">
      <range uom="25" subset="0,1" nls="EN_PM" />
   </editor>
   <editor id="I_TSTAT_PROG_MODE2">
      <range uom="25" subset="0-2" nls="EN_PM2" />
   </editor>
   <editor id="I_TSTAT_RUNTIME">
      <range uom="25" min="0" max="5000000000" prec="0" />
   </editor>
   <editor id="I_TSTAT_RUNTIME2">
   </editor>
   <editor id="I_VSTAR_HCS">
      <range uom="25" subset="0-4" nls="EN_VENSTATE" />
   </editor>
   <editor id="I_RAIN_ZONE">
      <range uom="25" subset="0-2" nls="EN_RAIN_ZONE" />
   </editor>
   <editor id="I_RAIN_ZONE_DURATION">
      <range uom="25" subset="5-120" />
   </editor>
</editors>
 (profiles/family/10/profile/1/download/EDITOR/I_EDIT.XML)
2018-06-19 07:10:50 - ISY Receive: <nodeDefs>
<!-- === Ecobee Thermostat ============================================================  -->
   <nodeDef id="EcobeeF" nodeType="140" nls="140E" >
      <sts>
         <st id="ST" editor="I_TEMP_F" />
         <st id="CLISPH" editor="I_CLISPH_F" />
         <st id="CLISPC" editor="I_CLISPC_F" />
         <st id="CLIMD" editor="I_TSTAT_MODE" />
         <st id="CLIHUM" editor="I_HUMIDITY" />
         <st id="CLIHCS" editor="I_TSTAT_ECOHCS" />
         <st id="CLIFRS" editor="I_TSTAT_FAN_STATE" />
         <st id="GV1" editor="I_TSTAT_HUM_SET" />
         <st id="CLISMD" editor="I_TSTAT_PROG_MODE2" />
         <st id="GV2" editor="I_HEARTBEAT" />
         <st id="GV4" editor="I_TSTAT_FANONTIME" />
         <st id="GV3" editor="I_TSTAT_ECO_SCHED_TYPE" />
         <st id="GV5" editor="I_HUMIDITY" />
         <st id="GV6" editor="I_ENABLED" />
         <st id="GV7" editor="I_ENABLED" />
      </sts>
      <cmds>
         <accepts>
            <cmd id="CLISPH">
               <p id="" editor="I_CLISPH_F" init="CLISPH" />
            </cmd>
            <cmd id="CLISPC">
               <p id="" editor="I_CLISPC_F" init="CLISPC" />
            </cmd>
            <cmd id="CLIMD">
               <p id="" editor="I_TSTAT_MODE" init="CLIMD" />
            </cmd>
               <cmd id="CLISMD">
               <p id="" editor="I_TSTAT_PROG_MODE2" init="CLISMD" />
            </cmd>
            <cmd id="GV3">
               <p id="" editor="I_TSTAT_ECO_SCHED_TYPE" init="GV3" />
               <p id="HoldType" editor="I_TSTAT_ECO_SCHED_OPT" init="0" optional="T" />
            </cmd>
            <cmd id="GV4">
               <p id="" editor="I_TSTAT_FANONTIME" init="GV4" />
            </cmd>
            <cmd id="GV6">
               <p id="" editor="I_ENABLED" init="GV6" />
            </cmd>
            <cmd id="GV7">
               <p id="" editor="I_ENABLED" init="GV7" />
            </cmd>
            <cmd id="BRT">
               <p id="" editor="I_SETTEMP_F" optional="T" />
            </cmd>
            <cmd id="DIM">
            </cmd>
            <cmd id="QUERY" />
         </accepts>
      </cmds>
  </nodeDef>
  <nodeDef id="EcobeeC" nodeType="140" nls="140E" >
      <sts>
         <st id="ST" editor="I_TEMP_C" />
         <st id="CLISPH" editor="I_CLISPH_C" />
         <st id="CLISPC" editor="I_CLISPC_C" />
      </sts>
      <cmds>
         <accepts>
            <cmd id="CLISPH">
               <p id="" editor="I_CLISPH_C" init="CLISPH" />
            </cmd>
            <cmd id="CLISPC">
               <p id="" editor="I_CLISPC_C" init="CLISPC" />
            </cmd>
            <cmd id="CLIMD">
            </cmd>
            <cmd id="CLISMD">
            </cmd>
            <cmd id="GV3">
            </cmd>
            <cmd id="GV4">
            </cmd>
            <cmd id="GV6">
            </cmd>
            <cmd id="GV7">
            </cmd>
            <cmd id="BRT">
               <p id="" editor="I_SETTEMP_C" optional="T" />
            </cmd>
            <cmd id="DIM">
            </cmd>
            <cmd id="QUERY" />
         </accepts>
      </cmds>
  </nodeDef>
  <nodeDef id="EcobeeSensorC" nodeType="140" nls="140ES" >
      <sts>
         <st id="GV1" editor="I_TSTAT_OCC" />
      </sts>
  </nodeDef>
  <nodeDef id="EcobeeSensorF" nodeType="140" nls="140ES" >
      <sts>
      </sts>
  </nodeDef>
  <nodeDef id="EcobeeWeatherF" nodeType="140" nls="140EW" >
      <sts>
         <st id="GV1" editor="I_HUMIDITY" />
         <st id="GV2" editor="I_HUMIDITY" />
         <st id="GV3" editor="I_TEMP_F" />
         <st id="GV4" editor="I_TEMP_F" />
         <st id="GV5" editor="I_WIND_F" />
         <st id="GV6" editor="I_WIND_DIRECTION" />
         <st id="GV7" editor="I_SKY" />
         <st id="GV8" editor="I_WEATHER_SYMBOL" />
      </sts>
  </nodeDef>
  <nodeDef id="EcobeeWeatherC" nodeType="140" nls="140EW" >
      <sts>
         <st id="GV3" editor="I_TEMP_C" />
         <st id="GV4" editor="I_TEMP_C" />
         <st id="GV5" editor="I_WIND_C" />
      </sts>
  </nodeDef>
  <!-- === Honeywell Thermostat ============================================================  -->
   <nodeDef id="HonTCCF" nodeType="140" nls="140H" >
      <sts>
         <st id="CLIFS" editor="I_HONTSTAT_FAN_MODE" />
         <st id="GV1" editor="I_HONTSTAT_STATUS" />
         <st id="GV4" editor="I_HUMIDITY" />
      </sts>
      <cmds>
         <accepts>
            <cmd id="CLISPH">
            </cmd>
            <cmd id="CLISPC">
            </cmd>
            <cmd id="CLIMD">
            </cmd>
            <cmd id="GV1">
               <p id="" editor="I_HONTSTAT_STATUS" init="GV1" />
            </cmd>
            <cmd id="CLIFS">
               <p id="" editor="I_HONTSTAT_FAN_MODE" init="CLIFS" />
            </cmd>
            <cmd id="QUERY" />
         </accepts>
      </cmds>
  </nodeDef>
  <nodeDef id="HonTCCC" nodeType="140" nls="140H" >
      <sts>
      </sts>
      <cmds>
         <accepts>
            <cmd id="CLISPH">
            </cmd>
            <cmd id="CLISPC">
            </cmd>
            <cmd id="CLIMD">
            </cmd>
            <cmd id="GV1">
            </cmd>
            <cmd id="CLIFS">
            </cmd>
            <cmd id="QUERY" />
         </accepts>
      </cmds>
  </nodeDef>
  <!-- === Venstar Thermostat ============================================================  -->
   <nodeDef id="VenstarF" nodeType="140" nls="140V" >
      <sts>
         <st id="CLIFS" editor="I_TSTAT_FAN_MODE" />
         <st id="CLIHCS" editor="I_VSTAR_HCS" />
         <st id="GV4" editor="I_TSTAT_VEN_ACTSTAGE" />
         <st id="CLISMD" editor="I_TSTAT_PROG_MODE" />
         <st id="GV3" editor="I_TSTAT_LOC" />
         <st id="GV6" editor="I_TSTAT_ALERT" />
         <st id="GV7" editor="I_TRUE_BOOL" />
      </sts>
      <cmds>
         <accepts>
            <cmd id="CLISPH">
            </cmd>
            <cmd id="CLISPC">
            </cmd>
            <cmd id="CLIMD">
            </cmd>
            <cmd id="CLIFS">
               <p id="" editor="I_TSTAT_FAN_MODE" init="CLIFS" />
            </cmd>
            <cmd id="CLISMD">
               <p id="" editor="I_TSTAT_PROG_MODE" init="CLISMD" />
            </cmd>
            <cmd id="GV1">
               <p id="" editor="I_TSTAT_HUM_SET" init="GV1" />
            </cmd>
            <cmd id="GV3">
               <p id="" editor="I_TSTAT_LOC" init="GV3" />
            </cmd>
            <cmd id="GV5">
               <p id="" editor="I_TSTAT_HUM_SET" init="GV5" />
            </cmd>
            <cmd id="BRT" />
            <cmd id="DIM" />
            <cmd id="QUERY" />
         </accepts>
      </cmds>
  </nodeDef>
  <nodeDef id="VenstarC" nodeType="140" nls="140V" >
      <sts>
         <st id="GV4" editor="I_TSTAT_VENHCS" />
      </sts>
      <cmds>
         <accepts>
            <cmd id="CLISPH">
            </cmd>
            <cmd id="CLISPC">
            </cmd>
            <cmd id="CLIMD">
            </cmd>
            <cmd id="CLIFS">
            </cmd>
            <cmd id="CLISMD">
            </cmd>
            <cmd id="GV1">
            </cmd>
            <cmd id="GV3">
            </cmd>
            <cmd id="GV5">
            </cmd>
            <cmd id="BRT" />
            <cmd id="DIM" />
            <cmd id="QUERY" />
         </accepts>
      </cmds>
  </nodeDef>
  <nodeDef id="VenstarRuntimes" nodeType="140" nls="140VR" >
      <sts>
         <st id="GV1" editor="I_TSTAT_RUNTIME" />
         <st id="GV2" editor="I_TSTAT_RUNTIME" />
         <st id="GV3" editor="I_TSTAT_RUNTIME" />
         <st id="GV4" editor="I_TSTAT_RUNTIME" />
         <st id="GV5" editor="I_TSTAT_RUNTIME" />
         <st id="GV6" editor="I_TSTAT_RUNTIME" />
         <st id="GV7" editor="I_TSTAT_RUNTIME" />
         <st id="GV8" editor="I_TSTAT_RUNTIME" />
         <st id="GV9" editor="I_TSTAT_RUNTIME2" />
      </sts>
      <cmds>
         <accepts>
            <cmd id="GV9" />
         </accepts>
      </cmds>
  </nodeDef>
  <nodeDef id="VenstarSensorC" nodeType="140" nls="140VS" >
      <sts>
         <st id="GV1" editor="I_BATTERY" />
      </sts>
  </nodeDef>
  <nodeDef id="VenstarSensorF" nodeType="140" nls="140VS" >
      <sts>
      </sts>
  </nodeDef>
  <!-- === Honeywell Alarm ============================================================  -->
  <nodeDef id="HonAlarm" nodeType="102" nls="102H" >
      <sts>
         <st id="ST" editor="I_HEARTBEAT" />
      </sts>
      <cmds>
         <accepts>
            <cmd id="QUERY" />
         </accepts>
      </cmds>
  </nodeDef>
  <nodeDef id="HonAlarmZone" nodeType="102" nls="102Z" >
      <sts>
         <st id="ST" editor="I_ALARM_ZONE" />
      </sts>
  </nodeDef>
  <nodeDef id="HonAlarmPartition" nodeType="102" nls="102HP" >
      <sts>
         <st id="ST" editor="I_HONALARM_STATUS" />
         <st id="GV1" editor="I_TRUE_BOOL" />
         <st id="GV2" editor="I_TRUE_BOOL" />
         <st id="GV3" editor="I_TRUE_BOOL" />
         <st id="GV4" editor="I_TRUE_BOOL" />
         <st id="GV5" editor="I_BINARY" />
         <st id="GV6" editor="I_BINARY" />
      </sts>
        <cmds>
         <accepts>
               <cmd id="DISARM" />
            <cmd id="ARMAWAY" />
            <cmd id="ARMSTAY" />
            <cmd id="ARMNOENTRY" />
         </accepts>
      </cmds>
  </nodeDef>
  <!-- === DSC Alarm ============================================================  -->
  <nodeDef id="DSC" nodeType="102" nls="102D" >
      <sts>
         <st id="GV1" editor="I_DSC_USER" />
         <st id="GV2" editor="I_BINARY" />
         <st id="GV3" editor="I_BINARY" />
         <st id="GV4" editor="I_BINARY" />
         <st id="GV7" editor="I_DSC_STANDARD" />
         <st id="GV8" editor="I_DSC_STANDARD" />
         <st id="GV9" editor="I_DSC_STANDARD" />
         <st id="GV10" editor="I_DSC_STANDARD" />
         <st id="GV11" editor="I_HEARTBEAT" />
      </sts>
      <cmds>
         <accepts>
            <cmd id="QUERY" />
            <cmd id="FIRE" />
            <cmd id="AMB" />
            <cmd id="PANIC" />
         </accepts>
      </cmds>
  </nodeDef>
  <nodeDef id="DSCZone" nodeType="102" nls="102Z" >
      <sts>
      </sts>
  </nodeDef>
  <nodeDef id="DSCPartition" nodeType="102" nls="102DP" >
      <sts>
         <st id="ST" editor="I_DSC_STATUS" />
      </sts>
        <cmds>
         <accepts>
               <cmd id="DISARM" />
         </accepts>
      </cmds>
  </nodeDef>
  <!-- === GreenEye ============================================================  -->
  <nodeDef id="GreenEye" nodeType="143" nls="143" >
      <sts>
         <st id="ST" editor="I_GEM_V" />
         <st id="GV1" editor="I_HEARTBEAT" />
      </sts>
      <cmds>
         <accepts>
            <cmd id="QUERY" />
            <cmd id="RESET" />
         </accepts>
      </cmds>
  </nodeDef>
  <nodeDef id="GreenEyeMain" nodeType="143" nls="143M" >
      <sts>
         <st id="GV1" editor="I_GEM_A" />
         <st id="GV2" editor="I_GEM_W" />
         <st id="GV3" editor="I_GEM_WH" />
         <st id="GV4" editor="I_GEM_A" />
         <st id="GV5" editor="I_GEM_W" />
         <st id="GV6" editor="I_HEARTBEAT" />
      </sts>
      <cmds>
         <accepts>
            <cmd id="QUERY" />
            <cmd id="RESET" />
            <cmd id="RUNRES" />
         </accepts>
      </cmds>
  </nodeDef>
  <nodeDef id="GreenEyeChannel" nodeType="143" nls="143C" >
      <sts>
         <st id="ST" editor="I_GEM_A" />
         <st id="GV1" editor="I_GEM_W" />
         <st id="GV2" editor="I_GEM_WH" />
         <st id="GV3" editor="I_GEM_RUNTIME" />
      </sts>
      <cmds>
         <accepts>
            <cmd id="RESET" />
            <cmd id="RUNRES" />
         </accepts>
      </cmds>
  </nodeDef>
  <nodeDef id="GreenEyeCounter" nodeType="144" nls="143CO" >
      <sts>
         <st id="ST" editor="I_GEM_CO" />
      </sts>
  </nodeDef>
  <nodeDef id="GreenEyeTemperature" nodeType="117" nls="143T" >
      <sts>
         <st id="ST" editor="I_GEM_T" />
      </sts>
  </nodeDef>
   <!-- === 1-Wire ============================================================  -->
   <nodeDef id="OneWire" nodeType="139" nls="139OW" >
      <sts>
         <st id="GV1" editor="I_INTEGER" />
      </sts>
      <cmds>
         <accepts>
            <cmd id="QUERY" />
         </accepts>
      </cmds>
   </nodeDef>
   <nodeDef id="OneWireTemp" nodeType="139" nls="139OWT" >
      <sts>
         <st id="ST" editor="I_TEMP" />
      </sts>
   </nodeDef>
   <nodeDef id="OneWireTempHum" nodeType="139" nls="139OWTH" >
      <sts>
      </sts>
   </nodeDef>
   <nodeDef id="OneWireCounter" nodeType="139" nls="139OWC" >
      <sts>
         <st id="ST" editor="I_INTEGER" />
      </sts>
   </nodeDef>
   <!-- === Flair ============================================================  -->
   <nodeDef id="FlairCloud" nodeType="139" nls="139FC" >
      <sts>
      </sts>
      <cmds>
         <accepts>
            <cmd id="QUERY" />
         </accepts>
      </cmds>
   </nodeDef>
   <nodeDef id="FlairPuck" nodeType="139" nls="139FP" >
      <sts>
         <st id="GV1" editor="I_TEMP_1" />
         <st id="GV3" editor="I_PRESSURE" />
         <st id="GV4" editor="I_INTEGER" />
      </sts>
   </nodeDef>
   <nodeDef id="FlairVent" nodeType="139" nls="139FV" >
      <sts>
         <st id="GV2" editor="I_TEMP_1" />
      </sts>
      <cmds>
         <accepts>
            <cmd id="GV1">
                <p id="" editor="I_HUMIDITY" init="GV1" />
            </cmd>
         </accepts>
      </cmds>
   </nodeDef>
  <!-- === ISY Data ============================================================  -->
   <nodeDef id="ISYData" nodeType="139" nls="139D" >
      <sts>
         <st id="GV2" editor="I_INTEGER" />
         <st id="GV3" editor="I_INTEGER" />
         <st id="GV4" editor="I_ODDEVEN" />
         <st id="GV5" editor="I_INTEGER" />
         <st id="GV6" editor="I_DAYOFWEEK" />
         <st id="GV7" editor="I_MONTH" />
         <st id="GV8" editor="I_INTEGER" />
         <st id="GV9" editor="I_INTEGER" />
         <st id="GV10" editor="I_INTEGER" />
         <st id="GV11" editor="I_SEASON" />
         <st id="GV12" editor="I_TRUE_BOOL" />
      </sts>
      <cmds>
         <accepts>
            <cmd id="QUERY" />
         </accepts>
      </cmds>
  </nodeDef>
  <nodeDef id="ISYDataSun" nodeType="139" nls="139DS" >
      <sts>
         <st id="GV1" editor="I_DEGREE" />
         <st id="GV2" editor="I_DEGREE" />
         <st id="GV3" editor="I_DEGREE" />
      </sts>
  </nodeDef>
  <nodeDef id="ISYDataElec" nodeType="139" nls="139DE" >
      <sts>
         <st id="ST" editor="I_TIMEOFUSE" />
      </sts>
  </nodeDef>
  <!-- === Location ============================================================  -->
  <nodeDef id="Location" nodeType="113" nls="113L" >
      <sts>
      </sts>
      <cmds>
         <accepts>
            <cmd id="QUERY" />
         </accepts>
      </cmds>
  </nodeDef>
  <nodeDef id="LocationDevice" nodeType="113" nls="113LD" >
      <sts>
         <st id="ST" editor="I_LOC_STATUS" />
      </sts>
  </nodeDef>
  <!-- === RainMachine ============================================================  -->
  <nodeDef id="RainMachine" nodeType="123" nls="123R" >
      <sts>
         <st id="ST" editor="I_RAIN_ZONE" />
         <st id="GV2" editor="I_FLOAT2" />
         <st id="GV4" editor="I_RAIN_NEXTRUN" />
      </sts>
      <cmds>
         <accepts>
            <cmd id="DELAY">
               <p id="" editor="I_10DAYS" />
            </cmd>
            <cmd id="QUERY" />
            <cmd id="ALLOFF" />
         </accepts>
      </cmds>
  </nodeDef>
  <nodeDef id="RainMachineProgram" nodeType="123" nls="123RP" >
      <sts>
         <st id="ST" editor="I_RAINMACHINEPROGRAM" />
         <st id="GV1" editor="I_RAIN_NEXTRUN" />
      </sts>
       <cmds>
         <accepts>
            <cmd id="START" />
            <cmd id="STOP" />
         </accepts>
      </cmds>
  </nodeDef>
  <nodeDef id="RainMachineZone" nodeType="123" nls="123RZ" >
      <sts>
      </sts>
       <cmds>
         <accepts>
            <cmd id="ON">
                <p id="" editor="I_RAIN_ZONE_DURATION" optional="T" />
            </cmd>
            <cmd id="OFF" />
         </accepts>
      </cmds>
  </nodeDef>
  <!-- === MiLight ============================================================  -->
  <nodeDef id="MiLi" nodeType="109" nls="109ML" >
      <sts>
      </sts>
      <cmds>
         <accepts>
            <cmd id="ALLON">
                <p id="" editor="I_MIDIMMER" optional="T" />
                <p id="COLOR" editor="I_COLOR" optional="T" />
            </cmd>
            <cmd id="COLORCODE">
                <p id="" editor="I_COLORSET" nls="EN_COLORSET" />
            </cmd>
            <cmd id="COLOR">
                <p id="" editor="I_COLOR" />
            </cmd>
            <cmd id="ALLWHITE">
            </cmd>
            <cmd id="ALLOFF" />
            <cmd id="ALLFADEOFF" />
         </accepts>
      </cmds>
  </nodeDef>
  <nodeDef id="MiLiGroup" nodeType="109" nls="109MLG" >
      <sts>
         <st id="ST" editor="I_MIDIMMER" />
         <st id="GV1" editor="I_COLOR" />
      </sts>
      <cmds>
         <accepts>
            <cmd id="DON">
                <p id="COLOR" editor="I_COLOR" init="GV1" optional="T" />
            </cmd>
            </cmd>
            <cmd id="COLOR">
                <p id="" editor="I_COLOR" init="GV1" />
            </cmd>
            <cmd id="WHITE">
            </cmd>
            <cmd id="DOF" />
            <cmd id="FADEOFF" />
         </accepts>
      </cmds>
  </nodeDef>
  <!-- === Modbus TCP ============================================================  -->
  <nodeDef id="MBTCP" nodeType="108" nls="108MB" >
      <sts>
      </sts>
      <cmds>
         <accepts>
            <cmd id="QUERY" />
         </accepts>
      </cmds>
  </nodeDef>
  <nodeDef id="MBTCPDI" nodeType="108" nls="108MBDI" >
      <sts>
         <st id="ST" editor="I_SWITCH" />
      </sts>
  </nodeDef>
  <nodeDef id="MBTCPAI" nodeType="108" nls="108MBAI" >
      <sts>
      </sts>
  </nodeDef>
  <nodeDef id="MBTCPDO" nodeType="108" nls="108MBDO" >
      <sts>
      </sts>
      <cmds>
         <accepts>
            <cmd id="ON" />
            <cmd id="OFF" />
         </accepts>
      </cmds>
  </nodeDef>
  <nodeDef id="MBTCPAO" nodeType="108" nls="108MBAO" >
      <sts>
         <st id="ST" editor="I_INTEGER16" />
      </sts>
      <cmds>
         <accepts>
            <cmd id="VAL">
                <p id="" editor="I_INTEGER" init="ST" />
            </cmd>
         </accepts>
      </cmds>
  </nodeDef>
  <!-- === Webcontrol 8/32 ============================================================  -->
  <nodeDef id="WC8" nodeType="108" nls="108W" >
      <sts>
         <st id="GV1" editor="I_ERROR_STATUS" />
      </sts>
      <cmds>
         <accepts>
            <cmd id="QUERY" />
         </accepts>
      </cmds>
  </nodeDef>
  <nodeDef id="WC8T" nodeType="108" nls="108WT" >
      <sts>
         <st id="ST" editor="I_FLOAT2" />
      </sts>
  </nodeDef>
  <nodeDef id="WC8H" nodeType="108" nls="108WH" >
      <sts>
         <st id="ST" editor="I_HUMIDITY" />
      </sts>
  </nodeDef>
  <nodeDef id="WC8V" nodeType="108" nls="108WV" >
      <sts>
      </sts>
  </nodeDef>
  <nodeDef id="WC8P" nodeType="108" nls="108WP" >
      <sts>
         <st id="ST" editor="I_DIMMER" />
         <st id="GV1" editor="I_FREQUENCY" />
      </sts>
      <cmds>
         <accepts>
            <cmd id="ON">
               <p id="" editor="I_DIMMER" init="ST" />
               <p id="Frequency" editor="I_FREQUENCY" init="GV1" optional="T" />
            </cmd>
            <cmd id="OFF" />
            <cmd id="FREQ">
               <p id="" editor="I_FREQUENCY" init="GV1" />
            </cmd>
         </accepts>
      </cmds>
  </nodeDef>
  <nodeDef id="WC8C" nodeType="108" nls="108WC" >
      <sts>
      </sts>
  </nodeDef>
  <nodeDef id="WC8AI" nodeType="108" nls="108WA" >
      <sts>
      </sts>
  </nodeDef>
  <nodeDef id="WC8DI" nodeType="108" nls="108WI" >
      <sts>
         <st id="ST" editor="I_BINARY" />
      </sts>
  </nodeDef>
  <nodeDef id="WC8DO" nodeType="108" nls="108WO" >
      <sts>
      </sts>
      <cmds>
         <accepts>
            <cmd id="ON" />
            <cmd id="OFF" />
         </accepts>
      </cmds>
  </nodeDef>
 <!-- === Tank Utility ============================================================  -->
  <nodeDef id="TankUtility" nodeType="146" nls="146T" >
      <sts>
         <st id="ST" editor="I_BATTERY" />
         <st id="GV1" editor="I_INTEGER16" />
         <st id="GV2" editor="I_TEMP_F" />
         <st id="GV3" editor="I_HEARTBEAT" />
      </sts>
      <cmds>
         <accepts>
            <cmd id="QUERY" />
         </accepts>
      </cmds>
  </nodeDef>
  <!-- === GenMon ============================================================  -->
  <nodeDef id="GenMon" nodeType="181" nls="181G" >
      <sts>
         <st id="ST" editor="I_GEN_SWITCHSTATE" />
         <st id="GV1" editor="I_GEN_ENGINESTATE" />
         <st id="GV2" editor="I_GEN_TRANSFERSWITCHSTATE" />
         <st id="GV3" editor="I_GEN_MAINV" />
         <st id="GV4" editor="I_GEN_MAINV" />
         <st id="GV5" editor="I_GEN_FREQ" />
         <st id="GV6" editor="I_GEN_BATTV" />
         <st id="GV7" editor="I_GEN_MONITORHEALTH" />
         <st id="GV8" editor="I_HEARTBEAT" />
      </sts>
      <cmds>
         <accepts>
            <cmd id="QUERY" />
            <cmd id="START" />
            <cmd id="STOP" />
            <cmd id="EXERCISE" />
            <cmd id="TRANSFER" />
         </accepts>
      </cmds>
  </nodeDef>
 <!-- === Caller ID ============================================================  -->
  <nodeDef id="CallerID" nodeType="185" nls="185CID" >
      <sts>
         <st id="ST" editor="I_TEL" />
         <st id="GV1" editor="I_TEL_AREACODE" />
         <st id="GV2" editor="I_TEL_NUMBER" />
      </sts>
      <cmds>
         <accepts>
            <cmd id="QUERY" />
         </accepts>
      </cmds>
  </nodeDef>
 </nodeDefs>
  (profiles/family/10/profile/1/download/NODEDEF/I_NDEFS.XML)
2018-06-19 07:10:51 - ISY Receive: ND-VenstarC-NAME = Venstar ColorTouch Thermostat (C)
ND-VenstarC-ICON = Thermostat
ND-VenstarF-NAME = Venstar ColorTouch Thermostat (F)
ND-VenstarF-ICON = Thermostat
ND-VenstarRuntimes-NAME = Venstar Runtime Data
ND-VenstarRuntimes-ICON = Thermostat
ND-VenstarSensorC-NAME = Venstar Sensor (C)
ND-VenstarSensorC-ICON = TempSensor
ND-VenstarSensorF-NAME = Venstar Sensor (F)
ND-VenstarSensorF-ICON = TempSensor
ND-EcobeeC-NAME = Ecobee Thermostat (C)
ND-EcobeeC-ICON = Thermostat
ND-EcobeeF-NAME = Ecobee Thermostat (F)
ND-EcobeeF-ICON = Thermostat
ND-EcobeeSensorC-NAME = Ecobee Sensor (C)
ND-EcobeeSensorC-ICON = TempSensor
ND-EcobeeSensorF-NAME = Ecobee Sensor (F)
ND-EcobeeSensorF-ICON = TempSensor
ND-EcobeeWeatherC-NAME = Ecobee Weather (C)
ND-EcobeeWeatherC-ICON = Weather
ND-EcobeeWeatherF-NAME = Ecobee Weather (F)
ND-EcobeeWeatherF-ICON = Weather
ND-HonTCCC-NAME = Honeywell Thermostat (C)
ND-HonTCCC-ICON = Thermostat
ND-HonTCCF-NAME = Honeywell Thermostat (F)
ND-HonTCCF-ICON = Thermostat
ND-FlairCloud-NAME = Flair Smart Vent Cloud
ND-FlairCloud-ICON = Thermostat
ND-FlairPuck-NAME = Flair Puck
ND-FlairPuck-ICON = TempSensor
ND-FlairVent-NAME = Flair Vent
ND-FlairVent-ICON = Switch
ST-139FC-ST-NAME = Heartbeat
ST-139FP-GV1-NAME = Temperature
ST-139FP-GV2-NAME = Humidity
ST-139FP-GV3-NAME = Pressure
ST-139FP-GV4-NAME = Light
ST-139FP-GV5-NAME = Battery
ST-139FV-GV1-NAME = Duct Position
ST-139FV-GV2-NAME = Duct Temperature
ST-139FV-GV3-NAME = Duct Pressure
ST-139FV-GV4-NAME = Battery
CMD-139FV-GV1-NAME = Duct Position
ND-RainMachine-NAME = RainMachine Irrigation Controller
ND-RainMachine-ICON = Irrigation
ND-RainMachineProgram-NAME = RainMachine Program
ND-RainMachineProgram-ICON = GenericCtl
ND-RainMachineZone-NAME = RainMachine Zone
ND-RainMachineZone-ICON = Output
ST-123R-GV1-NAME = Heartbeat
ST-123R-GV2-NAME = Rain Delay
ST-123R-GV3-NAME = Rain Sensor
ST-123R-GV4-NAME = Next Program Run
ST-123RP-GV1-NAME = Next Run
CMD-123R-ALLOFF-NAME = All Off
CMD-123R-DELAY-NAME = Rain Delay
CMD-123RP-START-NAME = Start
CMD-123RP-STOP-NAME = Stop
CMD-123RZ-ON-NAME = On
CMD-123RZ-OFF-NAME = Off
ND-ISYData-NAME = Additional ISY Data
ND-ISYData-ICON = Input
ND-ISYDataSun-NAME = Sun Position
ND-ISYDataSun-ICON = Weather
ND-ISYDataElec-NAME = Electricity Time-of-Use
ND-ISYDataElec-ICON = Electricity
ND-MiLi-NAME = MiLight WiFi Bridge
ND-MiLi-ICON = LampAndSwitch
ND-MiLiGroup-NAME = MiLight WiFi Bridge Group
ND-MiLiGroup-ICON = Lamp
ST-109MLG-GV1-NAME = Color
CMD-109ML-ALLON-NAME = All On
CMD-109ML-ALLWHITE-NAME = All On White
CMD-109ML-ALLOFF-NAME = All Off
CMD-109ML-ALLFADEOFF-NAME = All Fade Off
CMD-109MLG-FADEOFF-NAME = Fade Off
CMD-109ML-COLOR-NAME = Color
CMD-109ML-COLORCODE-NAME = Color Code
CMD-109MLG-WHITE-NAME = On White
CMD-109MLG-COLOR-NAME = Color
CMD-109MLG-COLORCODE-NAME = Color Code
PGM-CMD-109ML-ALLON-FMT = //${c}/to ${v}/ /COLOR//, color ${v}/
PGM-CMD-109MLG-DON-FMT = //${c}/to ${v}/ /COLOR//, color ${v}/
CMDP-I_COLOR-COLOR-NAME = Color
ND-OneWire-NAME = 1-Wire Controller
ND-OneWire-ICON = GenericCtl
ND-OneWireTemp-NAME = 1-Wire Temperature Sensor
ND-OneWireTemp-ICON = TempSensor
ND-OneWireTempHum-NAME = 1-Wire Climate Sensor
ND-OneWireTempHum-ICON = TempSensor
ND-OneWireCounter-NAME = 1-Wire 2-Channel Counter
ND-OneWire-ICON = Input
ST-139OW-ST-NAME = Heartbeat
ST-139OW-GV1-NAME = Sensor Count
ST-139OW-GV2-NAME = Read Errors
ST-139OWT-ST-NAME = Temperature
ST-139OWTH-ST-NAME = Temperature
ST-139OWTH-GV1-NAME = Humidity
ST-139OWC-ST-NAME = Counter 1
ST-139OWC-GV1-NAME = Counter 2
ND-Location-NAME = Geofence
ND-Location-ICON = DoorLock
ND-LocationDevice-NAME = Geo Device
ND-LocationDevice-ICON = GenericRsp
ST-108MB-ST-NAME = Heartbeat
ND-TankUtility-NAME = Tank Utility
ND-TankUtility-ICON = Switch
ST-146T-GV1-NAME = Capacity
ST-146T-GV2-NAME = Temperature
ST-146T-GV3-NAME = Heartbeat
ND-CallerID-NAME = Caller ID
ND-CallerID-ICON = MotionSensor
ST-185CID-GV1-NAME = Area Code
ST-185CID-GV2-NAME = Phone Number
ND-MBTCP-NAME = Modbus TCP
ND-MBTCP-ICON = GenericCtl
ND-MBTCPDI-NAME = Digital Input
ND-MBTCPDI-ICON = Input
ND-MBTCPAI-NAME = Analog Input
ND-MBTCPAI-ICON = Input
ND-MBTCPDO-NAME = Digital Output
ND-MBTCPDO-ICON = Output
ND-MBTCPAO-NAME = Analog Output
ND-MBTCPAO-ICON = Output
ST-113L-ST-NAME = Heartbeat
CMD-108MBDO-ON-NAME = On
CMD-108MBDO-OFF-NAME = Off
CMD-108MBAO-VAL-NAME = Value
ND-WC8-NAME = CAI WebControl
ND-WC8-ICON = GenericCtl
ND-WC8T-NAME = Climate Sensor
ND-WC8T-ICON = TempSensor
ND-WC8DI-NAME = Digital Input
ND-WC8DI-ICON = Input
ND-WC8DO-NAME = Digital Output
ND-WC8DO-ICON = Output
ND-WC8AI-NAME = Analog Input
ND-WC8AI-ICON = Input
ND-WC8H-NAME = Humidity
ND-WC8H-ICON = Irrigation
ND-WC8V-NAME = Variable
ND-WC8V-ICON = GenericCtl
ND-WC8C-NAME = Counter
ND-WC8C-ICON = Input
ND-WC8P-NAME = PWM
ND-WC8P-ICON = Output
ST-108WP-ST-NAME = Duty Cycle
ST-108WP-GV1-NAME = Frequency
CMD-108WP-ON-NAME = On
CMD-108WP-OFF-NAME = Off
CMD-108WP-FREQ-NAME = Frequency
PGM-CMD-108WP-ON-FMT = //${c}/to ${v}/ /Frequency//, Frequency ${v}/
CMDP-I_FREQUENCY-Frequency-NAME = Frequency
CMD-108WO-ON-NAME = On
CMD-108WO-OFF-NAME = Off
ST-108W-ST-NAME = Heartbeat
ST-108W-GV1-NAME = Temp Sensor Status
ST-108WA-ST-NAME = Scaled Value
ST-108WA-GV1-NAME = Raw Value
ST-139D-GV1-NAME = Hour
ST-139D-GV2-NAME = Minutes
ST-139D-GV3-NAME = Minutes This Year
ST-139D-GV4-NAME = Odd/Even Day
ST-139D-GV5-NAME = Week
ST-139D-GV6-NAME = Day of Week
ST-139D-GV7-NAME = Month
ST-139D-GV8-NAME = Day of Month
ST-139D-GV9-NAME = Year
ST-139D-GV10-NAME = Day of Year
ST-139D-GV11-NAME = Season
ST-139D-GV12-NAME = Daylight Savings
ST-139DS-GV1-NAME = Azimuth
ST-139DS-GV2-NAME = Elevation
ST-139DS-GV3-NAME = Zenith
ST-139DE-ST-NAME = Time-of-Use
EN_PM-0 = Manual
EN_PM-1 = Running
EN_ODD-0 = Even
EN_ODD-1 = Odd
EN_SWITCH-0 = Off
EN_SWITCH-255 = On
EN_COLOR-256 = White
EN_COLORSET-0 = Violet
EN_COLORSET-1 = Royal Blue
EN_COLORSET-2 = Baby Blue
EN_COLORSET-3 = Aqua
EN_COLORSET-4 = Mint
EN_COLORSET-5 = Seafoam Green
EN_COLORSET-6 = Green
EN_COLORSET-7 = Lime Green
EN_COLORSET-8 = Yellow
EN_COLORSET-9 = Yellow Orange
EN_COLORSET-10 = Orange
EN_COLORSET-11 = Red
EN_COLORSET-12 = Pink
EN_COLORSET-13 = Fuschia
EN_COLORSET-14 = Lilac
EN_COLORSET-15 = Lavendar
EN_RAINMACHINEPROGRAM-0 = Not Running
EN_RAINMACHINEPROGRAM-1 = Running
EN_RAINMACHINEPROGRAM-2 = Queued
EN_RAIN_NEXTRUN-0 = Today
EN_RAIN_NEXTRUN-1 = Tomorrow
EN_RAIN_NEXTRUN-2 = Several Days
EN_RAIN_NEXTRUN-3 = Not Scheduled
EN_PM2-0 = Running
EN_PM2-1 = Hold Next
EN_PM2-2 = Hold
EN_NA-0 = N/A
EN_DAY-0 = Sunday
EN_DAY-1 = Monday
EN_DAY-2 = Tuesday
EN_DAY-3 = Wednesday
EN_DAY-4 = Thursday
EN_DAY-5 = Friday
EN_DAY-6 = Saturday
EN_WIND_DIRECTION-0 = N/A
EN_WIND_DIRECTION-1 = N
EN_WIND_DIRECTION-2 = NE
EN_WIND_DIRECTION-3 = E
EN_WIND_DIRECTION-4 = SE
EN_WIND_DIRECTION-5 = S
EN_WIND_DIRECTION-6 = SW
EN_WIND_DIRECTION-7 = W
EN_WIND_DIRECTION-8 = NW
EN_SKY-0 = N/A
EN_SKY-1 = Sunny
EN_SKY-2 = Clear
EN_SKY-3 = Mostly Sunny
EN_SKY-4 = Mostly Clear
EN_SKY-5 = Hazy Sunshine
EN_SKY-6 = Haze
EN_SKY-7 = Passing Clouds
EN_SKY-8 = More Sun than Clouds
EN_SKY-9 = Scattered Clouds
EN_SKY-10 = Partly Cloudy
EN_SKY-11 = A Mixture of Sun and CLouds
EN_SKY-12 = High Level Clouds
EN_SKY-13 = More Clouds than Sun
EN_SKY-14 = Partly Sunny
EN_SKY-15 = Broken Clouds
EN_SKY-16 = Mostly Cloudy
EN_SKY-17 = Cloudy
EN_SKY-18 = Overcast
EN_SKY-19 = Low Clouds
EN_SKY-20 = Light Fog
EN_SKY-21 = Fog
EN_SKY-22 = Dense Fog
EN_SKY-23 = Ice Fog
EN_SKY-24 = Sandstorm
EN_SKY-25 = Duststorm
EN_SKY-26 = Increasing Cloudiness
EN_SKY-27 = Decreasing Cloudiness
EN_SKY-28 = Clearing Skies
EN_SKY-29 = Breaks of Sun Late
EN_SKY-30 = Early Fog Followed by Sunny Skies
EN_SKY-31 = Afternoon Clouds
EN_SKY-32 = Morning Couds
EN_SKY-33 = Smoke
EN_SKY-34 = Low Level Haze
EN_HONALARM_STATUS-0 = Disarmed
EN_HONALARM_STATUS-1 = Armed Stay
EN_HONALARM_STATUS-2 = Armed Night Stay
EN_HONALARM_STATUS-3 = Armed Away
EN_DSCSTAT-0 = Disarmed
EN_DSCSTAT-1 = Armed Stay
EN_DSCSTAT-2 = Armed Away
EN_DSCSTAT-3 = Entry Delay
EN_DSCSTAT-4 = Exit Delay
EN_DSC_PANIC-0 = None
EN_DSC_PANIC-1 = Fire
EN_DSC_PANIC-2 = Ambulance
EN_DSC_PANIC-3 = Panic
EN_RAIN_ZONE-0 = Off
EN_RAIN_ZONE-1 = On
EN_RAIN_ZONE-2 = Queued
EN_HONTSTAT_STATUS-0 = Schedule
EN_HONTSTAT_STATUS-1 = Temp Hold
EN_HONTSTAT_STATUS-2 = Perm Hold
EN_HONTSTAT_STATUS-3 = Vacation Hold
EN_HONTSTAT_STATUS-4 = N/A
EN_SEASON-1 = Spring
EN_SEASON-2 = Summer
EN_SEASON-3 = Fall
EN_SEASON-4 = Winter
EN_ECOSCH-0 = Away
EN_ECOSCH-1 = Home
EN_ECOSCH-2 = Sleep
EN_ECOSCH-3 = Smart1
EN_ECOSCH-4 = Smart2
EN_ECOSCH-5 = Smart3
EN_ECOSCH-6 = Smart4
EN_ECOSCH-7 = Smart5
EN_ECOSCH-8 = Smart6
EN_ECOSCH-9 = Smart7
EN_ECOSCH-10 = N/A
EN_ECOSCH_OPT-0 = Permanent
EN_ECOSCH_OPT-1 = Transition
EN_ECOHCS-0 = Idle
EN_ECOHCS-1 = Heat
EN_ECOHCS-2 = Cool
EN_ECOHCS-3 = Heat2
EN_ECOHCS-4 = Heat3
EN_ECOHCS-5 = Cool2
EN_ECOHCS-6 = AuxHeat
EN_ECOHCS-7 = AuxHeat2
EN_ECOHCS-8 = AuxHeat3
EN_VENSTATE-0 = Idle
EN_VENSTATE-1 = Heating
EN_VENSTATE-2 = Cooling
EN_VENSTATE-3 = Lockout
EN_VENSTATE-4 = Error
EN_TOU-0 = On-Peak
EN_TOU-1 = Mid-Peak
EN_TOU-2 = Off-Peak
EN_BOOL-0 = No
EN_BOOL-1 = Yes
EN_PHONE_RINGING-0 = Idle
EN_PHONE_RINGING-1 = Ringing
EN_LOC_STATUS-0 = Away
EN_LOC_STATUS-1 = Home
EN_ERROR_STATUS-0 = OK
EN_ERROR_STATUS-1 = Error
EN_STATUS-0 = Off
EN_STATUS-1 = On
EN_ENABLED-0 = Disabled
EN_ENABLED-1 = Enabled
EN_TRUE_BOOL-0 = False
EN_TRUE_BOOL-1 = True
EN_ALERT-0 = OK
EN_ALERT-1 = Alert
EN_LOC-0 = Home
EN_LOC-1 = Away
EN_ALARM_ZONE-0 = Closed
EN_ALARM_ZONE-1 = Open
EN_GEN_SWITCHSTATE-0 = N/A
EN_GEN_SWITCHSTATE-1 = Auto
EN_GEN_SWITCHSTATE-2 = Off
EN_GEN_SWITCHSTATE-3 = Manual
EN_GEN_SWITCHSTATE-4 = Two Wire Stop
EN_GEN_SWITCHSTATE-5 = System in Alarm
EN_GEN_ENGINESTATE-0 = N/A
EN_GEN_ENGINESTATE-1 = Exercising
EN_GEN_ENGINESTATE-2 = Stopped
EN_GEN_ENGINESTATE-3 = Startup Delay Timer Activated
EN_GEN_ENGINESTATE-4 = Cranking in Alarm
EN_GEN_ENGINESTATE-5 = Cranking
EN_GEN_ENGINESTATE-6 = Cooling Down
EN_GEN_ENGINESTATE-7 = Running in Alarm
EN_GEN_ENGINESTATE-8 = Running
EN_GEN_ENGINESTATE-9 = Running in Warning
EN_GEN_ENGINESTATE-10 = Stopped in Alarm
EN_GEN_ENGINESTATE-11 = Off
EN_GEN_TRANSFERSWITCHSTATE-0 = N/A
EN_GEN_TRANSFERSWITCHSTATE-1 = Generator
EN_GEN_TRANSFERSWITCHSTATE-2 = Utility
EN_GEN_MONITORHEALTH-0 = N/A
EN_GEN_MONITORHEALTH-1 = OK
EN_GEN_MONITORHEALTH-2 = Not OK
CMD-ST-NAME = Query
ST-140H-ST-NAME = Temperature
ST-140H-GV1-NAME = Schedule Status
ST-140H-GV2-NAME = Heartbeat
ST-140H-GV3-NAME = Outdoor Temperature
ST-140H-GV4-NAME = Outdoor Humidity
CMD-140H-GV1-NAME = Schedule Status
ST-140V-ST-NAME = Temperature
ST-140V-GV1-NAME = Humidification Setpoint
ST-140V-GV2-NAME = Heartbeat
ST-140V-GV3-NAME = Home / Away
ST-140V-GV4-NAME = Active Stage
ST-140V-GV5-NAME = Dehumidification Setpoint
ST-140V-GV6-NAME = Filter
ST-140V-GV7-NAME = Humidity Active
CMD-140V-GV1-NAME = Humidification Setpoint
CMD-140V-GV3-NAME = Home / Away
CMD-140V-GV5-NAME = Dehumidification Setpoint
CMD-140V-BRT-NAME = Setpoint Up
CMD-140V-DIM-NAME = Setpoint Down
ST-140VR-GV1-NAME = Timestamp
ST-140VR-GV2-NAME = Heat Stage 1
ST-140VR-GV3-NAME = Heat Stage 2
ST-140VR-GV4-NAME = Cool Stage 1
ST-140VR-GV5-NAME = Cool Stage 2
ST-140VR-GV6-NAME = Aux Stage 1
ST-140VR-GV7-NAME = Aux Stage 2
ST-140VR-GV8-NAME = Free Cooling
ST-140VR-GV9-NAME = Filter Runtime
CMD-140VR-GV9-NAME = Reset Filter Runtime
ST-140E-ST-NAME = Temperature
ST-140E-GV1-NAME = Humidification Setpoint
ST-140E-GV2-NAME = Heartbeat
ST-140E-GV3-NAME = Climate Type
ST-140E-GV4-NAME = Fan On Time
ST-140E-GV5-NAME = Dehumidification Setpoint
ST-140E-GV6-NAME = Smart Home-Away
ST-140E-GV7-NAME = Follow Me
CMD-140E-GV3-NAME = Climate Type
CMD-140E-GV4-NAME = Fan On Time
CMD-140E-GV6-NAME = Smart Home-Away
CMD-140E-GV7-NAME = Follow Me
CMD-140E-BRT-NAME = Setpoint Up
CMD-140E-DIM-NAME = Setpoint Down
PGM-CMD-140E-GV3-FMT = //${c}/to ${v}/ /HoldType//, Hold Type ${v}/
CMDP-I_TSTAT_ECO_SCHED_OPT-HoldType-NAME = Hold Type
ST-140ES-ST-NAME = Temperature
ST-140ES-GV1-NAME = Occupancy
ST-140EW-ST-NAME = Temperature
ST-140EW-GV1-NAME = Humidity
ST-140EW-GV2-NAME = POP
ST-140EW-GV3-NAME = High Temp
ST-140EW-GV4-NAME = Low Temp
ST-140EW-GV5-NAME = Wind Speed
ST-140EW-GV6-NAME = Wind Direction
ST-140EW-GV7-NAME = Sky
ST-140EW-GV8-NAME = Symbol
ST-140VS-ST-NAME = Temperature
ST-140VS-GV1-NAME = Battery
ND-GenMon-NAME = GenMon Generator
ND-GenMon-ICON = EnergyMonitor
ST-181G-ST-NAME = Switch State
ST-181G-GV1-NAME = Engine State
ST-181G-GV2-NAME = Transfer Switch State
ST-181G-GV3-NAME = Output Voltage
ST-181G-GV4-NAME = Utility Voltage
ST-181G-GV5-NAME = Frequency
ST-181G-GV6-NAME = Battery Voltage
ST-181G-GV7-NAME = Monitor Health
ST-181G-GV8-NAME = Heartbeat
CMD-181G-START-NAME = Start
CMD-181G-STOP-NAME = Stop
CMD-181G-EXERCISE-NAME = Start Exercise
CMD-181G-TRANSFER-NAME = Start Transfer
ND-GreenEye-NAME = GreenEye Energy Monitor
ND-GreenEye-ICON = EnergyMonitor
ND-GreenEyeMain-NAME = GreenEye Energy Monitor (Main)
ND-GreenEyeMain-ICON = EnergyMonitor
ND-GreenEyeChannel-NAME = GreenEye Energy Channel
ND-GreenEyeChannel-ICON = Electricity
ND-GreenEyeCounter-NAME = GreenEye Counter Input
ND-GreenEyeCounter-ICON = Input
ND-GreenEyeTemperature-NAME = GreenEye Temperature Sensor
ND-GreenEyeTemperature-ICON = TempSensor
ST-143-ST-NAME = Voltage
ST-143-GV1-NAME = Heartbeat
CMD-143-RESET-NAME = Reset All kWh Counters
CMD-143-RUNRES-NAME = Reset All Runtime Counters
ST-143M-ST-NAME = Voltage
ST-143M-GV1-NAME = Current
ST-143M-GV2-NAME = Power
ST-143M-GV3-NAME = Total Energy
ST-143M-GV4-NAME = Phase Imbalance
ST-143M-GV5-NAME = Not Monitored
ST-143M-GV6-NAME = Heartbeat
CMD-143M-RESET-NAME = Reset All kWh Counters
CMD-143M-RUNRES-NAME = Reset All Runtime Counters
CMD-143C-RESET-NAME = Reset kWh Counter
CMD-143C-RUNRES-NAME = Reset Runtime Counter
ST-143C-ST-NAME = Current
ST-143C-GV1-NAME = Power
ST-143C-GV2-NAME = Total Energy
ST-143C-GV3-NAME = Runtime
ND-HonAlarm-NAME = Honeywell Alarm Panel
ND-HonAlarm-ICON = GenericCtl
ND-HonAlarmZone-NAME = Honeywell Zone
ND-HonAlarmZone-ICON = MotionSensor
ND-HonAlarmPartition-NAME = Honeywell Partition
ND-HonAlarmPartition-ICON = Input
ST-102H-ST-NAME = Heartbeat
ST-102HP-ST-NAME = Status
ST-102HP-GV1-NAME = Alarm
ST-102HP-GV2-NAME = Ready
ST-102HP-GV3-NAME = Entry Delay
ST-102HP-GV4-NAME = Zones Bypassed
ST-102HP-GV5-NAME = Panel Trouble
ST-102HP-GV6-NAME = Fire Alarm
CMD-102H-QUERY-NAME = Query
CMD-102HP-DISARM-NAME = Disarm
CMD-102HP-ARMAWAY-NAME = Arm Away
CMD-102HP-ARMSTAY-NAME = Arm Stay
CMD-102HP-ARMNOENTRY-NAME = Arm No Entry
ND-DSC-NAME = DSC Alarm Panel
ND-DSC-ICON = GenericCtl
ND-DSCZone-NAME = DSC Zone
ND-DSCZone-ICON = MotionSensor
ND-DSCPartition-NAME = DSC Partition
ND-DSCPartition-ICON = Input
ST-102Z-ST-NAME = Status
ST-102D-GV1-NAME = Disarming User
ST-102D-GV2-NAME = Panel Trouble
ST-102D-GV3-NAME = Fire Alarm
ST-102D-GV4-NAME = Aux Alarm
ST-102D-GV5-NAME = Panic Alarm
ST-102D-GV6-NAME = Aux Input Alarm
ST-102D-GV7-NAME = Command Output 1
ST-102D-GV8-NAME = Command Output 2
ST-102D-GV9-NAME = Command Output 3
ST-102D-GV10-NAME = Command Output 4
ST-102D-GV11-NAME = Heartbeat
ST-102DP-ST-NAME = Status
ST-102DP-GV1-NAME = Alarm
ST-102DP-GV2-NAME = Ready
ST-102DP-GV3-NAME = No Delay Enabled
CMD-102D-QUERY-NAME = Query
CMD-102D-FIRE-NAME = Trigger Fire Alarm
CMD-102D-AMB-NAME = Trigger Ambulance
CMD-102D-PANIC-NAME = Trigger Panic Alarm
CMD-102DP-DISARM-NAME = Disarm
CMD-102DP-ARMAWAY-NAME = Arm Away
CMD-102DP-ARMSTAY-NAME = Arm Stay
CMD-102DP-ARMNOENTRY-NAME = Arm No Entry
 (profiles/family/10/profile/1/download/NLS/EN_US.TXT)
2018-06-19 07:10:51 - Relay Server: Started on port 2405
2018-06-19 07:10:52 - WC: <response>
<firmware>v03.03.31</firmware>
<op1>1</op1>
<op2>1</op2>
<op3>1</op3>
<op4>1</op4>
<op5>1</op5>
<op6>1</op6>
<op7>1</op7>
<op8>1</op8>
<ophex>0xFF</ophex>
<var1>0</var1>
<var2>0</var2>
<var3>0</var3>
<var4>0</var4>
<var5>0</var5>
<var6>0</var6>
<var7>0</var7>
<var8>0</var8>
<ip1>0</ip1>
<ip2>0</ip2>
<ip3>0</ip3>
<ip4>0</ip4>
<ip5>0</ip5>
<ip6>0</ip6>
<ip7>0</ip7>
<ip8>0</ip8>
<ts1>67.6 F</ts1>
<ts2>unbound</ts2>
<ts3>67.2 F</ts3>
<ts4>unbound</ts4>
<ts5>unbound</ts5>
<ts6>unbound</ts6>
<ts7>unbound</ts7>
<ts8>unbound</ts8>
<tstat1>ok</tstat1>
<tstat2>unbound</tstat2>
<tstat3>ok</tstat3>
<tstat4>unbound</tstat4>
<tstat5>unbound</tstat5>
<tstat6>unbound</tstat6>
<tstat7>unbound</tstat7>
<tstat8>unbound</tstat8>
<romcode1>28FFB81254150312</romcode1>
<romcode2>28A1272600008029</romcode2>
<romcode3>0000000000000000</romcode3>
<romcode4>0000000000000000</romcode4>
<romcode5>0000000000000000</romcode5>
<romcode6>0000000000000000</romcode6>
<romcode7>0000000000000000</romcode7>
<romcode8>0000000000000000</romcode8>
<boundromcode1>28A1272600008029</boundromcode1>
<boundromcode2>28FFE6D3501604DB</boundromcode2>
<boundromcode3>28FFB81254150312</boundromcode3>
<boundromcode4>0000000000000000</boundromcode4>
<boundromcode5>0000000000000000</boundromcode5>
<boundromcode6>0000000000000000</boundromcode6>
<boundromcode7>0000000000000000</boundromcode7>
<boundromcode8>0000000000000000</boundromcode8>
<hs1>0 %</hs1>
<aip1>0</aip1>
<aip2>0</aip2>
<aip3>0</aip3>
<aip4>0</aip4>
<aip5>0</aip5>
<aip6>0</aip6>
<aip7>0</aip7>
<aip8>0</aip8>
<urom1>0</urom1>
<urom2>0</urom2>
<urom3>0</urom3>
<urom4>0</urom4>
<tdso>10</tdso>
<counter>0</counter>
<fcounter>0</fcounter>
<date>06/19/2018</date>
<time>07:10:52</time>
<datetime>06/19/2018 07:10:52</datetime>
<ipaddr>192.168.3.251</ipaddr>
<macaddr>00:22:12:02:0A:1C</macaddr>
<name>WEBCONTROL ATTI</name>
<builddate>Dec 07 2017, 13:19:41</builddate>
</response> [caiwc2]
2018-06-19 07:10:52 - WC: Output 1 changed to 1 [caiwc2]
2018-06-19 07:10:52 - WC: Iutput 1 changed to 0 [caiwc2]
2018-06-19 07:10:52 - WC: Variable 1 changed to 0 [caiwc2]
2018-06-19 07:10:52 - WC: Temp 1 changed to 67.6 [caiwc2]
2018-06-19 07:10:52 - WC: Output 2 changed to 1 [caiwc2]
2018-06-19 07:10:52 - WC: Iutput 2 changed to 0 [caiwc2]
2018-06-19 07:10:52 - WC: Variable 2 changed to 0 [caiwc2]
2018-06-19 07:10:52 - WC: Output 3 changed to 1 [caiwc2]
2018-06-19 07:10:52 - WC: Iutput 3 changed to 0 [caiwc2]
2018-06-19 07:10:52 - WC: Variable 3 changed to 0 [caiwc2]
2018-06-19 07:10:52 - WC: Temp 3 changed to 67.2 [caiwc2]
2018-06-19 07:10:52 - WC: Output 4 changed to 1 [caiwc2]
2018-06-19 07:10:52 - WC: Iutput 4 changed to 0 [caiwc2]
2018-06-19 07:10:52 - WC: Variable 4 changed to 0 [caiwc2]
2018-06-19 07:10:52 - WC: Output 5 changed to 1 [caiwc2]
2018-06-19 07:10:52 - WC: Iutput 5 changed to 0 [caiwc2]
2018-06-19 07:10:52 - WC: Variable 5 changed to 0 [caiwc2]
2018-06-19 07:10:52 - WC: Output 6 changed to 1 [caiwc2]
2018-06-19 07:10:52 - WC: Iutput 6 changed to 0 [caiwc2]
2018-06-19 07:10:52 - WC: Variable 6 changed to 0 [caiwc2]
2018-06-19 07:10:52 - WC: Output 7 changed to 1 [caiwc2]
2018-06-19 07:10:52 - WC: Iutput 7 changed to 0 [caiwc2]
2018-06-19 07:10:52 - WC: Variable 7 changed to 0 [caiwc2]
2018-06-19 07:10:52 - WC: Output 8 changed to 1 [caiwc2]
2018-06-19 07:10:52 - WC: Iutput 8 changed to 0 [caiwc2]
2018-06-19 07:10:52 - WC: Variable 8 changed to 0 [caiwc2]
2018-06-19 07:10:52 - WC: Analog In 1 changed to 0 [caiwc2]
2018-06-19 07:10:52 - WC: Analog In 2 changed to 0 [caiwc2]
2018-06-19 07:10:52 - WC: Analog In 3 changed to 0 [caiwc2]
2018-06-19 07:10:52 - WC: Humidity changed to 0 [caiwc2]
2018-06-19 07:10:52 - ISY Send: Variable caiwc2-ST added to queue (Val: -1, QS: 1)
2018-06-19 07:10:52 - ISY Send: Variable caiwc2_o1-ST added to queue (Val: 1, QS: 2)
2018-06-19 07:10:52 - ISY Send: Variable caiwc2_i1-ST added to queue (Val: 0, QS: 3)
2018-06-19 07:10:52 - ISY Send: Variable caiwc2_v1-ST added to queue (Val: 0, QS: 4)
2018-06-19 07:10:52 - {"access_token": "815d6584e45f140f09f90b1f6187cc61c0d4312e1227ca79ab3165ad", "checksum": "6dcd65a84eebb6ac7ee471dc689978edf694c4b0f90e0e192579c8bf9944d01293958cca3dfd9d973a5330ddbf2f2c7502e210b5cb48304e", "expires_in": 157680000, "expiration": "Sun, 18 Jun 2023 14:10:52 GMT", "statusCode": 0}(P) [rain1]
2018-06-19 07:10:52 - ISY Send: Variable caiwc2_t1-ST added to queue (Val: 67.6, QS: 5)
2018-06-19 07:10:52 - ISY Send: Variable caiwc2_o2-ST added to queue (Val: 1, QS: 6)
2018-06-19 07:10:52 - ISY Send: Variable caiwc2_i2-ST added to queue (Val: 0, QS: 7)
2018-06-19 07:10:52 - ISY Send: Variable caiwc2_v2-ST added to queue (Val: 0, QS: 8)
2018-06-19 07:10:52 - ISY Send: Variable caiwc2_o3-ST added to queue (Val: 1, QS: 9)
2018-06-19 07:10:52 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_caiwc2/report/status/ST/-1/25)
2018-06-19 07:10:52 - ISY Send: Variable caiwc2_i3-ST added to queue (Val: 0, QS: 9)
2018-06-19 07:10:52 - ISY Send: Variable caiwc2_v3-ST added to queue (Val: 0, QS: 10)
2018-06-19 07:10:52 - ISY Send: Variable caiwc2_t3-ST added to queue (Val: 67.2, QS: 11)
2018-06-19 07:10:52 - ISY Send: Variable caiwc2_o4-ST added to queue (Val: 1, QS: 12)
2018-06-19 07:10:52 - ISY Send: Variable caiwc2_i4-ST added to queue (Val: 0, QS: 13)
2018-06-19 07:10:52 - ISY Send: Variable caiwc2_v4-ST added to queue (Val: 0, QS: 14)
2018-06-19 07:10:52 - ISY Send: Variable caiwc2_o5-ST added to queue (Val: 1, QS: 15)
2018-06-19 07:10:52 - ISY Send: Variable caiwc2_i5-ST added to queue (Val: 0, QS: 16)
2018-06-19 07:10:52 - ISY Send: Variable caiwc2_v5-ST added to queue (Val: 0, QS: 17)
2018-06-19 07:10:52 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_caiwc2_o1/report/status/ST/1/25)
2018-06-19 07:10:52 - ISY Send: Variable caiwc2_o6-ST added to queue (Val: 1, QS: 17)
2018-06-19 07:10:52 - ISY Send: Variable caiwc2_i6-ST added to queue (Val: 0, QS: 18)
2018-06-19 07:10:52 - ISY Send: Variable caiwc2_v6-ST added to queue (Val: 0, QS: 19)
2018-06-19 07:10:52 - ISY Send: Variable caiwc2_o7-ST added to queue (Val: 1, QS: 20)
2018-06-19 07:10:52 - ISY Send: Variable caiwc2_i7-ST added to queue (Val: 0, QS: 21)
2018-06-19 07:10:52 - ISY Send: Variable caiwc2_v7-ST added to queue (Val: 0, QS: 22)
2018-06-19 07:10:52 - ISY Send: Variable caiwc2_o8-ST added to queue (Val: 1, QS: 23)
2018-06-19 07:10:52 - ISY Send: Variable caiwc2_i8-ST added to queue (Val: 0, QS: 24)
2018-06-19 07:10:52 - ISY Send: Variable caiwc2_v8-ST added to queue (Val: 0, QS: 25)
2018-06-19 07:10:52 - ISY Send: Variable caiwc2-GV1 added to queue (Val: 1, QS: 26)
2018-06-19 07:10:52 - ISY Send: Variable caiwc2_a1-ST added to queue (Val: 0, QS: 27)
2018-06-19 07:10:52 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_caiwc2_i1/report/status/ST/0/25)
2018-06-19 07:10:52 - ISY Send: Variable caiwc2_a1-GV1 added to queue (Val: 0, QS: 27)
2018-06-19 07:10:53 - ISY Send: Variable caiwc2_a2-ST added to queue (Val: 0, QS: 28)
2018-06-19 07:10:53 - ISY Send: Variable caiwc2_a2-GV1 added to queue (Val: 0, QS: 29)
2018-06-19 07:10:53 - ISY Send: Variable caiwc2_a3-ST added to queue (Val: 0, QS: 30)
2018-06-19 07:10:53 - ISY Send: Variable caiwc2_a3-GV1 added to queue (Val: 0, QS: 31)
2018-06-19 07:10:53 - ISY Send: Variable caiwc2_h-ST added to queue (Val: 0, QS: 32)
2018-06-19 07:10:53 - ISY Send: Variable rain1-ST added to queue (Val: 0, QS: 33)
2018-06-19 07:10:53 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_caiwc2_v1/report/status/ST/0/25)
2018-06-19 07:10:53 - ISY Send: Variable rain1-GV1 added to queue (Val: -1, QS: 33)
2018-06-19 07:10:53 - ISY Send: Variable rain1-GV2 added to queue (Val: 0, QS: 34)
2018-06-19 07:10:53 - ISY Send: Variable rain1-GV3 added to queue (Val: 0, QS: 35)
2018-06-19 07:10:53 - ISY Send: Variable rain1-GV4 added to queue (Val: 1, QS: 36)
2018-06-19 07:10:53 - ISY Send: Variable rain1_p1-ST added to queue (Val: 0, QS: 37)
2018-06-19 07:10:53 - ISY Send: Variable rain1_p1-GV1 added to queue (Val: 1, QS: 38)
2018-06-19 07:10:53 - ISY Send: Variable rain1_z1-ST added to queue (Val: 0, QS: 39)
2018-06-19 07:10:53 - ISY Send: Variable rain1_z2-ST added to queue (Val: 0, QS: 40)
2018-06-19 07:10:53 - ISY Send: Variable rain1_z3-ST added to queue (Val: 0, QS: 41)
2018-06-19 07:10:53 - ISY Send: Variable rain1_z4-ST added to queue (Val: 0, QS: 42)
2018-06-19 07:10:53 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_caiwc2_t1/report/status/ST/67.6/25)
2018-06-19 07:10:53 - ISY Send: Variable rain1_z5-ST added to queue (Val: 0, QS: 42)
2018-06-19 07:10:53 - ISY Send: Variable rain1_z6-ST added to queue (Val: 0, QS: 43)
2018-06-19 07:10:53 - ISY Send: Variable rain1_z7-ST added to queue (Val: 0, QS: 44)
2018-06-19 07:10:53 - ISY Send: Variable rain1_z8-ST added to queue (Val: 0, QS: 45)
2018-06-19 07:10:53 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_caiwc2_o2/report/status/ST/1/25)
2018-06-19 07:10:53 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_caiwc2_i2/report/status/ST/0/25)
2018-06-19 07:10:53 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_caiwc2_v2/report/status/ST/0/25)
2018-06-19 07:10:53 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_caiwc2_o3/report/status/ST/1/25)
2018-06-19 07:10:53 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_caiwc2_i3/report/status/ST/0/25)
2018-06-19 07:10:53 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_caiwc2_v3/report/status/ST/0/25)
2018-06-19 07:10:53 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_caiwc2_t3/report/status/ST/67.2/25)
2018-06-19 07:10:54 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_caiwc2_o4/report/status/ST/1/25)
2018-06-19 07:10:54 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_caiwc2_i4/report/status/ST/0/25)
2018-06-19 07:10:54 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_caiwc2_v4/report/status/ST/0/25)
2018-06-19 07:10:54 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_caiwc2_o5/report/status/ST/1/25)
2018-06-19 07:10:54 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_caiwc2_i5/report/status/ST/0/25)
2018-06-19 07:10:54 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_caiwc2_v5/report/status/ST/0/25)
2018-06-19 07:10:54 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_caiwc2_o6/report/status/ST/1/25)
2018-06-19 07:10:54 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_caiwc2_i6/report/status/ST/0/25)
2018-06-19 07:10:54 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_caiwc2_v6/report/status/ST/0/25)
2018-06-19 07:10:55 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_caiwc2_o7/report/status/ST/1/25)
2018-06-19 07:10:55 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_caiwc2_i7/report/status/ST/0/25)
2018-06-19 07:10:55 - Web Request Auth Failure: /config.htm
2018-06-19 07:10:55 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_caiwc2_v7/report/status/ST/0/25)
2018-06-19 07:10:55 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_caiwc2_o8/report/status/ST/1/25)
2018-06-19 07:10:55 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_caiwc2_i8/report/status/ST/0/25)
2018-06-19 07:10:55 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_caiwc2_v8/report/status/ST/0/25)
2018-06-19 07:10:55 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_caiwc2/report/status/GV1/1/25)
2018-06-19 07:10:55 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_caiwc2_a1/report/status/ST/0/25)
2018-06-19 07:10:55 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_caiwc2_a1/report/status/GV1/0/25)
2018-06-19 07:10:56 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_caiwc2_a2/report/status/ST/0/25)
2018-06-19 07:10:56 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_caiwc2_a2/report/status/GV1/0/25)
2018-06-19 07:10:56 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_caiwc2_a3/report/status/ST/0/25)
2018-06-19 07:10:56 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_caiwc2_a3/report/status/GV1/0/25)
2018-06-19 07:10:56 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_caiwc2_h/report/status/ST/0/51)
2018-06-19 07:10:56 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rain1/report/status/ST/0/25)
2018-06-19 07:10:56 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rain1/report/status/GV1/-1/25)
2018-06-19 07:10:56 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rain1/report/status/GV2/0/25)
2018-06-19 07:10:56 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rain1/report/status/GV3/0/25)
2018-06-19 07:10:57 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rain1/report/status/GV4/1/25)
2018-06-19 07:10:57 - WC: Data poll error - One or more errors occurred. [caiwc1]
2018-06-19 07:10:57 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rain1_p1/report/status/ST/0/25)
2018-06-19 07:10:57 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rain1_p1/report/status/GV1/1/25)
2018-06-19 07:10:57 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rain1_z1/report/status/ST/0/25)
2018-06-19 07:10:57 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rain1_z2/report/status/ST/0/25)
2018-06-19 07:10:57 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rain1_z3/report/status/ST/0/25)
2018-06-19 07:10:57 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rain1_z4/report/status/ST/0/25)
2018-06-19 07:10:57 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rain1_z5/report/status/ST/0/25)
2018-06-19 07:10:57 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rain1_z6/report/status/ST/0/25)
2018-06-19 07:10:58 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rain1_z7/report/status/ST/0/25)
2018-06-19 07:10:58 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rain1_z8/report/status/ST/0/25)
2018-06-19 07:11:00 - Web Request: /config.htm
2018-06-19 07:11:08 - WC: <response>
<op1>1</op1>
<op2>1</op2>
<op3>1</op3>
<op4>1</op4>
<op5>1</op5>
<op6>1</op6>
<op7>1</op7>
<op8>1</op8>
<ophex>0xFF</ophex>
<var1>0</var1>
<var2>0</var2>
<var3>0</var3>
<var4>0</var4>
<var5>0</var5>
<var6>0</var6>
<var7>0</var7>
<var8>0</var8>
<ip1>0</ip1>
<ip2>0</ip2>
<ip3>0</ip3>
<ip4>0</ip4>
<ip5>0</ip5>
<ip6>0</ip6>
<ip7>0</ip7>
<ip8>0</ip8>
<ts1>67.6 F</ts1>
<ts2>unbound</ts2>
<ts3>67.2 F</ts3>
<ts4>unbound</ts4>
<ts5>unbound</ts5>
<ts6>unbound</ts6>
<ts7>unbound</ts7>
<ts8>unbound</ts8>
<tstat1>ok</tstat1>
<tstat3>ok</tstat3>
<hs1>0 %</hs1>
<aip1>0</aip1>
<aip2>0</aip2>
<aip3>0</aip3>
<aip4>0</aip4>
<aip5>0</aip5>
<aip6>0</aip6>
<aip7>0</aip7>
<aip8>0</aip8>
<urom1>0</urom1>
<urom2>0</urom2>
<urom3>0</urom3>
<urom4>0</urom4>
<tdso>10</tdso>
<time>07:11:08</time>
<datetime>06/19/2018 07:11:08</datetime>
2018-06-19 07:11:08 - ISY Send: Variable caiwc2-ST added to queue (Val: 1, QS: 1)
2018-06-19 07:11:08 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_caiwc2/report/status/ST/1/25)
2018-06-19 07:11:17 - WC: Data poll error - One or more errors occurred. [caiwc1]
2018-06-19 07:11:23 - ISY Send: Variable rain1-GV1 added to queue (Val: 1, QS: 1)
2018-06-19 07:11:23 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rain1/report/status/GV1/1/25)
2018-06-19 07:11:23 - WC: <response>
<op1>1</op1>
<op2>1</op2>
<op3>1</op3>
<op4>1</op4>
<op5>1</op5>
<op6>1</op6>
<op7>1</op7>
<op8>1</op8>
<ophex>0xFF</ophex>
<var1>0</var1>
<var2>0</var2>
<var3>0</var3>
<var4>0</var4>
<var5>0</var5>
<var6>0</var6>
<var7>0</var7>
<var8>0</var8>
<ip1>0</ip1>
<ip2>0</ip2>
<ip3>0</ip3>
<ip4>0</ip4>
<ip5>0</ip5>
<ip6>0</ip6>
<ip7>0</ip7>
<ip8>0</ip8>
<ts1>67.6 F</ts1>
<ts2>unbound</ts2>
<ts3>67.2 F</ts3>
<ts4>unbound</ts4>
<ts5>unbound</ts5>
<ts6>unbound</ts6>
<ts7>unbound</ts7>
<ts8>unbound</ts8>
<tstat1>ok</tstat1>
<tstat3>ok</tstat3>
<hs1>0 %</hs1>
<aip1>0</aip1>
<aip2>0</aip2>
<aip3>0</aip3>
<aip4>0</aip4>
<aip5>0</aip5>
<aip6>0</aip6>
<aip7>0</aip7>
<aip8>0</aip8>
<urom1>0</urom1>
<urom2>0</urom2>
<urom3>0</urom3>
<urom4>0</urom4>
<tdso>10</tdso>
<time>07:11:23</time>
<datetime>06/19/2018 07:11:23</datetime>
2018-06-19 07:11:23 - ISY Send: Variable caiwc2-ST added to queue (Val: -1, QS: 1)
2018-06-19 07:11:23 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_caiwc2/report/status/ST/-1/25)
2018-06-19 07:11:37 - WC: Data poll error - One or more errors occurred. [caiwc1]
2018-06-19 07:11:40 - WC: <response>
<op1>1</op1>
<op2>1</op2>
<op3>1</op3>
<op4>1</op4>
<op5>1</op5>
<op6>1</op6>
<op7>1</op7>
<op8>1</op8>
<ophex>0xFF</ophex>
<var1>0</var1>
<var2>0</var2>
<var3>0</var3>
<var4>0</var4>
<var5>0</var5>
<var6>0</var6>
<var7>0</var7>
<var8>0</var8>
<ip1>0</ip1>
<ip2>0</ip2>
<ip3>0</ip3>
<ip4>0</ip4>
<ip5>0</ip5>
<ip6>0</ip6>
<ip7>0</ip7>
<ip8>0</ip8>
<ts1>67.6 F</ts1>
<ts2>unbound</ts2>
<ts3>67.2 F</ts3>
<ts4>unbound</ts4>
<ts5>unbound</ts5>
<ts6>unbound</ts6>
<ts7>unbound</ts7>
<ts8>unbound</ts8>
<tstat1>ok</tstat1>
<tstat3>ok</tstat3>
<hs1>0 %</hs1>
<aip1>0</aip1>
<aip2>0</aip2>
<aip3>0</aip3>
<aip4>0</aip4>
<aip5>0</aip5>
<aip6>0</aip6>
<aip7>0</aip7>
<aip8>0</aip8>
<urom1>0</urom1>
<urom2>0</urom2>
<urom3>0</urom3>
<urom4>0</urom4>
<tdso>10</tdso>
<time>07:11:40</time>
<datetime>06/19/2018 07:11:40</datetime>
2018-06-19 07:11:40 - ISY Send: Variable caiwc2-ST added to queue (Val: 1, QS: 1)
2018-06-19 07:11:40 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_caiwc2/report/status/ST/1/25)
2018-06-19 07:11:41 - Web Request: /index.htm
2018-06-19 07:11:53 - ISY Send: Variable rain1-GV1 added to queue (Val: -1, QS: 1)
2018-06-19 07:11:53 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rain1/report/status/GV1/-1/25)
2018-06-19 07:11:56 - WC: <response>
<op1>1</op1>
<op2>1</op2>
<op3>1</op3>
<op4>1</op4>
<op5>1</op5>
<op6>1</op6>
<op7>1</op7>
<op8>1</op8>
<ophex>0xFF</ophex>
<var1>0</var1>
<var2>0</var2>
<var3>0</var3>
<var4>0</var4>
<var5>0</var5>
<var6>0</var6>
<var7>0</var7>
<var8>0</var8>
<ip1>0</ip1>
<ip2>0</ip2>
<ip3>0</ip3>
<ip4>0</ip4>
<ip5>0</ip5>
<ip6>0</ip6>
<ip7>0</ip7>
<ip8>0</ip8>
<ts1>67.6 F</ts1>
<ts2>unbound</ts2>
<ts3>67.2 F</ts3>
<ts4>unbound</ts4>
<ts5>unbound</ts5>
<ts6>unbound</ts6>
<ts7>unbound</ts7>
<ts8>unbound</ts8>
<tstat1>ok</tstat1>
<tstat3>ok</tstat3>
<hs1>0 %</hs1>
<aip1>0</aip1>
<aip2>0</aip2>
<aip3>0</aip3>
<aip4>0</aip4>
<aip5>0</aip5>
<aip6>0</aip6>
<aip7>0</aip7>
<aip8>0</aip8>
<urom1>0</urom1>
<urom2>0</urom2>
<urom3>0</urom3>
<urom4>0</urom4>
<tdso>10</tdso>
<time>07:11:56</time>
<datetime>06/19/2018 07:11:56</datetime>
2018-06-19 07:11:56 - ISY Send: Variable caiwc2-ST added to queue (Val: -1, QS: 1)
2018-06-19 07:11:56 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_caiwc2/report/status/ST/-1/25)
2018-06-19 07:11:57 - WC: Data poll error - One or more errors occurred. [caiwc1]
2018-06-19 07:12:11 - WC: <response>
<op1>1</op1>
<op2>1</op2>
<op3>1</op3>
<op4>1</op4>
<op5>1</op5>
<op6>1</op6>
<op7>1</op7>
<op8>1</op8>
<ophex>0xFF</ophex>
<var1>0</var1>
<var2>0</var2>
<var3>0</var3>
<var4>0</var4>
<var5>0</var5>
<var6>0</var6>
<var7>0</var7>
<var8>0</var8>
<ip1>0</ip1>
<ip2>0</ip2>
<ip3>0</ip3>
<ip4>0</ip4>
<ip5>0</ip5>
<ip6>0</ip6>
<ip7>0</ip7>
<ip8>0</ip8>
<ts1>67.6 F</ts1>
<ts2>unbound</ts2>
<ts3>67.2 F</ts3>
<ts4>unbound</ts4>
<ts5>unbound</ts5>
<ts6>unbound</ts6>
<ts7>unbound</ts7>
<ts8>unbound</ts8>
<tstat1>ok</tstat1>
<tstat3>ok</tstat3>
<hs1>0 %</hs1>
<aip1>0</aip1>
<aip2>0</aip2>
<aip3>0</aip3>
<aip4>0</aip4>
<aip5>0</aip5>
<aip6>0</aip6>
<aip7>0</aip7>
<aip8>0</aip8>
<urom1>0</urom1>
<urom2>0</urom2>
<urom3>0</urom3>
<urom4>0</urom4>
<tdso>10</tdso>
<time>07:12:11</time>
<datetime>06/19/2018 07:12:11</datetime>
2018-06-19 07:12:11 - ISY Send: Variable caiwc2-ST added to queue (Val: 1, QS: 1)
2018-06-19 07:12:11 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_caiwc2/report/status/ST/1/25)
2018-06-19 07:12:16 - Web Request: /index.htm
Edited by lovemyram4x4
That's webcontrol debug, not System Config.
Did you enable logging in to the NodeLink web interface?
And you cut the first lines of the restart log, which gives me all your system info.
Sorry only clicked on debug on the web display, I left off the first few lines because they didn't seem relevant. I ran it again and pasted it over the old one. This time I only tried to turn on output 1 and like before I didn't see the request.
It's because you have login configured for the NodeLink web interface.
You need to add that user/pass to the isylink node config within the ISY.
I have it in the node config, I also had it turned off completely until last night.
I figured it out, but i can't seem to fix it. It's firewall related on my server, I have rules for nodelink but they don't seem to be working but if I turn off firewall I can get ISY to control the webcontrol (I assume rainmachine also). I don't think I even have anything set up for the relay server though yet that's working.
