Google Home Lost Connection to ISY
I don't know if anyone else has had this.  But yesterday when I started to mess around with some new stuff, Google home wasn't synced.  When I went to save my changes, I got an error that it failed authentication.  I hadn't made any changes to anything, so I don't know why this would have happened.  I also found that one of my google home commands was missing from list and none of the remaining ones worked until I resynced.
  • 1 month later...
This has happened again.  Google home reported that it was not connected to ISY upon issuing it a command.  I tried the "send spokens" to Google and it failed, I believe it said it failed authentication. I had to use the Google "home" app and remove ISY then add it back in.  Again, I had not changed anything with my google account or my ISY/portal account.
This is an issue that happens once in a while.
@apostolakisl, this will sound weird, but please try this. In your list of spokens, please add one or two devices, even if you don't use them. Please use devices that regularly changes state, once a day or more.
It would be long to explain, but it seems the issue is that google loses track of the "agentUserId" which uniquely identifies the user sending.
When requesting to send spokens, this makes a request using your agentUserId. In addition, when devices changes states, the same authentication mecanism is used. I think that making regular requests such as sending devices states helps. In your case, all you have are scenes and programs, which don't have states. Adding devices that sends states could help.
In parallel I will also reopen an older ticked with Google.
Benoit
Benoit
OK, I added a device that is used very often so it should be sending lots of updates to Google.
  • 4 weeks later...
Benoit
So far so good since I did as you suggested.
Excellent, thanks for the feedback!
Benoit
In my case, I had only added spoken to scenes. I regularly had to remove and reauthenticate because the connection got broken.
I just started the process of switching to putting the spoken son the controlling device (so you can ask Google the current status) and implementing programs and scenes to keep the scene consistent when the device is controlled in this way. Hopefully, this change will stop my accounts from getting disassociated as well... time will tell...
If this is indeed the issue, then there really should be a keepalive ping implemented in the Portal....
Yes, I think that would be a good idea. The "ping" would need to be a valid request. If there are no devices for which we can send a status, then, the only valid request we could send is a sync request. The same as when clicking the "Send spokens to Google Home".
Benoit
  • 5 weeks later...
I'm having a similar problem and I'm finally trying to track down what's going on.  I regularly have to unlink and re-link the ISY Portal in Google Home.  Unfortunately, Google's updated the app and the linking unlinking is more difficult to discover in the current version.  I'm also kinda tired of having to setup the rooms in Google Home.
I have spokens on all modules that are used regularly, so I don't think this necessarily helps resolve the problem.  By spokens, I'm assuming you mean the words that are included in the my.isy.io portal...
It appears that you're working on this (which is awesome) - is there anything we can do to provide additional information on what's happening?
  • 2 months later...
Well, after a long time of not going down, the link went down again.  So perhaps putting devices into the google home that update often (multiple times per day) doesn't entirely fix this issue.
@apostolakisl,
Do you get Permission Denied errors? We have already opened a support ticket with Google. Something quite screwy is going on there.
22 hours ago, Michel Kohanim said:
@apostolakisl,
When I asked my google home to turn on a light, it responded with something to the affect of "universal devices is not available right now".  It definitely did not say anything about permissions nor did it use the word error.  Having experienced this before, I went directly to "google home" app on my phone, removed Universal Devices, then added it back in.  This fixed the problem and I got no errors adding it back in.
I have not experienced this issue.
  • 3 weeks later...
  • 1 month later...
My google home is now saying things like the following:
"ok, turning on the pond air pump on. . . sorry I couldn't reach universal devices"  for some items, but for others, it just works.
This is hard to explain since the same universal devices ISY controls both items.  I tried this multiple times back and forth, the one device works every time, the other device gives the error message.
EDIT: OK, so I actually checked the pond air pump, and it does turn it on and off even though it says it couldn't reach universal devices.
Edited by apostolakisl
I would suggest to unlink and reliable.
You may have devices that existed in ISY Portal that are no longer there, or were recreated, which would assign them a different ID.
