Insteon camera not available remotely
I have connected an Insteon thermostat and 2 Insteon cameras. I can control the thermostat remotely but am not able to view the camera video remotely unless I use the Foscam app. Is there a way I can view it through the UD? I can see both cameras but get a broken picture icon.
8 minutes ago, Michel Kohanim said:
Hello @laspeslet,
Have you tried:
https://wiki.universal-devices.com/index.php?title=ISY-994i_Initial_Browser_Screen#Camera_Support_.28Requires_4.0.1_and_above.29: (you will need to use the remote IP address to your cameras).
Thanks Michel.  I now have a dumb question. How do I find the remote IP address to my cameras?
42 minutes ago, Michel Kohanim said:
Hi @laspeslet,
Did you create port forwarding rules in your router to the camera?
In all cases, the remote IP is probably your ISP's IP address which you can get from : https://whatismyip.com .
I can't seem to figure out the port forwarding on my router. I guess I will try and get that sorted out first. If only I could get a Shaw tech on the phone that understood what I needed. I thought that maybe since I can access the thermostat, that it was okay.
Port forwarding converts an external IP address (your ISP given IP address) and a port number (default 443) to another IP address (Internal - usually 192.168.0.1xxx = ISY address)  and Port number. (default 443) = ISY secure port)
If you are not using port 80 you may need to use https://ISP address  externally. (note "s" for secure) and setup the secure port address inside your ISY to match.
