AT&T to end email-to-text ×
break into ISY
tome
Posted (edited)
I have an ISY at a remote location.  For about the last couple months I have noticed that my mobile app can't access anything there.  My wife is at the location now and it appears that the ISY is fine and operating but I cannot log into it.  It claims my userid and password aren't correct (this is trying to access it using "https://name.foo:443").  I get the login screen but my UID and PW are rejected.    I have no idea why they would not be accepted, no change has been made that I am aware of.  Also,  once while trying to log in, it would behave as if the uid and pw were accepted but it would just sit on the blue screen with "System Busy" showing at the bottom.  I could click on a tab, like "Configuration" and it would populate (after a delay) but all fields would be blank.  But mostly I just get UID and PW rejected and presented with the dialog again.
Any idea how I can get past this?  The most recent backup of the config I have is 3 years old (version 4.2).  Nothing has changed in terms of devices or configuration in that time there but I have updated the software (it's probably running 4.6.2).   Could it be related to certs or anything?  I did change computers a few months back...
-Tom
Edited by tome
typo
-Tom
Tom,
Which mobile app are you referring to when you say, "my mobile app can't access anything there"?
7 minutes ago, tome said:
MobilLinc Pro.  But I can't log in via the Admin console on my computer...
-Tom
Can you reach the ISY through the UDI portal?
What is the UDI portal?
 ISY Portal allows seamless remote access without port forwarding in the router.
Posted (edited)
BTW, when my wife connects to the ISY while directly on the same network (not remote) she gets the same thing.  It appears as if the UID/Password combination isn't correct.  Again, I am quite sure it is, unless of course the box was hacked somehow and the password changed.
-Tom
Edited by tome
typo
How do I use it, access it?  Is it an application?
It's a module that is purchased from UDI and added to your ISY. However, if you are using the MobiLinc portal you cannot use the ISY portal too. it's one or the other.
-Tom
Is your wife attempting to connect locally through MobiLinc or the Admin Console?
How old is the PLM at that location? What color is the light on the side of the PLM? Try unplugging the PLM for a minute or so and plugging it back in. If your wife can't access via the LAN the portal will be no help. If none of these offer a lead, submit a ticket to UDI asking for help.
  • 1 month later...
On 8/27/2018 at 10:20 AM, Michel Kohanim said:
I finally got to the site to figure this out.  I did have to follow Michel's link to push the reset button on the ISY and then re-set the password.  Not sure what happened, why it changed in the first place, but all is recovered and well.  Thanks to all.
-Tom
      37.7k
      376.7k
