Multi-tap support
I have a homeseer WS 100+ and I was wondering if ISY supports Multi-tap triggering?
If it does how can I utilize it?
Edited by silverton38
ISY supports double tap on which is "Fast On" in programing and double tap off which is "Fast Off" in programming.
I use the triple tab on one of my Homeseer switches, whereby it turns ON or OFF all switches in that room.
I do not see "fast on" or "fast off" as an option to program it with. Control is ON and OFF only. I am using version 4.6.2.
How did you do that?
I am now running 4.7.3 but nothing has changed in regards to multi-tap. Is the supported on the new beta?
I've not used 4.7.3 so I can't say that it works in that version. It worked for me through 4.6.2 and now in 5.0.13D.
Can you post a sample program?
Do these help?
IF
ZWXXX button is pressed Fast On
THEN
ZWAAA On
ZWBBB On
ZWCCC On
The Homeseer WD-100 uses the 'Central Scene' class to support double and triple taps. This is only supported in the 5.X firmware.
After adding the device - you should see two scene nodes:
These sub-nodes have 'Triple-Tap (On)' and 'Fast On' (for double) support:
Again - you need 5.x for this..
This is a better explanation than mine. Thanks MWareman.
I think the issue is that I do not have 5.X yet. What is latest available 5.X beta?
V5.0.13D
Also be aware that even on 5.0.13x (I forget which version I'm on) you need to query the switch itself before trying to pick the scenes in programs. Well at least I do. They simply aren't there to choose from if I don't query the switch first.
  • 1 month later...
I am now playing around with these double and triple tap Wd-100+ and WF-200+. I can use a program for double and triple tap "ON" (5..0.14) with "scene button 1" which is great but I can not figure out what the "scene button 2" is for?
I believe you can consider "scene button 2" to be the bottom of the paddle on the switch.  I use it to turn multiple items off:
TripleTapOff - [ID 00C4][Parent 00DB]
        'Devices / dirOffice / Office Dimmer Switch / ZW 014 Scene Button 2' is switched Triple Press (On)
        Set 'Devices / dirOffice / Office Dimmer Switch' Fast Off
        Set 'Devices / dirOffice / lmpOfficeDeskLamp' Off
