Trouble linking I/O 2450 to ISY994i
CADman
Good day everyone, I am having an issue when trying to link the I/O 2450 to my ISY.  I keep getting an error (see picture).  I have tried multiple times, both manually and automatically, same error.  I have installed multiple light switches, outlets, keypads without an issue so I am at a loss to what to do.  Any suggestions would be greatly appreciated.
For the device type, I have been using: (7:00)(2450)IOLink
One thing to know about the iolinc is that it hasn't changed over time... meaning its still single band, no insteon rf. Even if you have a good insteon RF mesh, this may be too far away for the ISY to see it.
I had a problem with mine in my detached garage for that reason.
  • Do you have a spare lamplinc / appliancelinc to plug into the back of the iolinc and try again?
    • If no, can you move the iolinc to an outlet near the PLM or other working dualband device to see if that works?
Paul
Edited by paulbates
Thanks for the feedback.  As for the distance between the IOlink and the hub and PLM, its no more than 12 feet. The hub is literally on the other side of the wall. (garage is attached).
I do have a spare lamp plug in, maybe I'll add that to see if it helps.  I will update this post once I have had a chance to try it.
Did you try to link using
Link Management / Add a ControlLinc  and select 07.00 2450 I0Linc ?
Fill in the device address and name and then OK it.
I've found that some devices do not link correctly using standard linking (Click on start linking and then press button on device)
I've always had good results when doing  manual linking from Link Management, especially after the "cannot determine Insteon engine" error shows up, or when Automatic discovery in manual linking does not yield the desired result.
Edited by Craigb
Hi Craig,
Thanks, I only tried the Link Management, New Insteon Device.  I will try your suggestion and update this post as soon as I can.
Since it is a power line only Insteon module. Physical distance can be deceiving. If the PLM and 2450 are on different power circuits. The commands may not be getting between them. I would try a dual band module as suggested earlier.
Criag's idea is important too. When I read the first post and saw "manually and automatically", I was thinking that meant the "start linking" from link management. That frequently works for me.
Paul
UPDATE:  Plugging in my spare lamp link worked like a charm, all is working perfectly.
Thank you for all your help with this.
Glad you're working. You'll need to keep one there; buy a lamplinc or range extender (which is really a lamplinc with the outlet removed) when they are next on sale. Usually around holidays they'll have a sale.
Paul
      37.8k
      378.1k
