On/Off Outlet - Cannot control bottom outlet
I just installed 2 new 2663-222 On/Off Outlets.   Commands sent to either .1 or .2 both control the top.  I cannot control the bottom.  Any suggestions on what could be wrong?
Welcome to the forum!!
I do not have one of these but the usual problems are.
  • Did you factory reset the new device before linking to ISY? These things can come with strange and  unknown problems from the factory.
  • If you did factory reset it, or decide to try it now, you can right click on the device in the admin console device tree and select restore. (any battery devices must be in linking mode first). It's very easy and quick. ISY is your friend here.
I did not factory reset it but I did try the restore device.  It didn't help.
Then try the factory reset and do the restore. Mosr devices involve holding down a button while you power it up. Don't let go until the beeping stops.
So... tried factory reset of both devices and then restored.  Same behavior.
I am at version 4.7.3 for both firmware and UI.
Weird thing... I have a different double outlet that is now behaving the same way.  Commands to top or bottom both change top.
  • 1 month later...
Glad I saw this post as I did not know that there was a outlet that both could be controlled. Can you also dim?
It's not a dimmer so it can't dim
Thanks, the ones I have are dimmers, but only control 1 of the 2 outlets. I will have to check out the ones you got now.
Sent from my SM-T550 using Tapatalk
