SMTP timeout setting not saving on v2.7 ? Yahoo Mail
Trying to get my SMTP working via my yahoo pop account. What I've noticed is that the SMTP time out setting does not appear to stay saved. I can change it from the default of 1,000MS to many other values and I can click Save. However when I exit and come back to the config window the timeout setting has returned to 1,000MS.
I have been able to sucessfully use the test gmail settings provided on the forum here. However whenever I try to use my yahoo account and click "test" the ISY just sits there w/o error appearing but the cursor stays stuck on an hour glass. If I close the browser window I can relogin fine.
The test GMAIL works
server: smtp.gmail.com
port: 587
user id: isyalerts@gmail.com
password: holamola
TLS: checked
Yahoo both plus and nonplus give results above (hang):
plus.smtp.mail.yahoo.com
Use SSL, port: 465,
user id: myyahooID
password: yahoomailpass
TLS: tried checked and unchecked both
smtp.mail.yahoo.com
Use SSL, port: 587,
user id: myyahooID
checking in my LOG I see several entries of
-50001
-5012
-5012
-5012
Hello junkycosmos,
This feature is only available on 2.7.3 and above. Would you be kind enough to make sure you have 2.7.3 installed (Help | About).
port: 587
password: holamola
TLS: checked
Use SSL, port: 465,
user id: myyahooID
smtp.mail.yahoo.com
Use SSL, port: 587,
user id: myyahooID
-50001
-5012
-5012
-5012
  • 1 year later...
It took a bit of experimenting but this finally worked for me setup like this...
SMTP Server:  plus.smtp.mail.yahoo.com
SMTP Port:    587
User ID:      yahooID
Password:     yahooMailPassword
Timeout:      1000
TLS:          unchecked
The port 465 may be blocked by the internet provider so that may be why its not working and 587 is. Here is Yahoo's help page.
http://help.yahoo.com/l/us/yahoo/mail/y ... op-14.html
