Nodelink DSC Time didn't update
I noticed the DSC clock time did not update at all after the time change. I pushed the update clock button in Nodelink and it did change correctly. Did anyone notice the same issue?
I am running pi3, Nodelink v0.9.20, Mono v5.12.0.226
Tim
Edited by TJF1960
Same here:
2018-11-05 03:00:02 - ISY NodeLink Server v0.9.21 started
2018-11-05 03:00:02 - OS: Linux raspberrypi 4.14.62-v7+ #1134 SMP Tue Aug 14 17:10:10 BST 2018 armv7l GNU/Linux
2018-11-05 03:00:02 - Mono version: 5.14.0.177 (tarball Mon Aug  6 10:53:50 UTC 2018)
For the life of me I can't find an update clock button in nodelink though.
Where do you see that?
I usually have to run another software to update the clock.
Update clock is only available on an IT100.  On an EVL i assume you're setting it up internally
Tim
The time should update (assuming auto-update is enabled) every 24h based off when NodeLink started.  You should see a log entry every time it sets the clock ("Notice" level).
