KPL LED Off
I may be having a couple issues to debug, but let me simply ask. Should the program below turn the KPL LED off (ie program is off) after it finishes, that is after 1 hour?
Control 'KPL Pool Eq B' is switched On
Send X10 'K16/On (3)'
Wait 1 hour
Send X10 'K16/Off (11)'
       Wait  1 hour
Yes, that should work unless Control 'KPL Pool Eq B' is switched which will either restart the program or quit it if the button is switched any way but On. So if you switch KPL Pool Eq B Off the program will end before the Wait is over.
If you find that is the case you could watch for the Off.
   And Control 'KPL Pool Eq B' is not switched Off
       Wait  1 hour
Rand
Thanks Sub-Routine
As you describe it is exactly how I want it to work However, after the 1 hr the light on the KPL was still on (like the program was still active), but like I said I am having a few other things to debug so it may not be related. I just wanted to make sure I was not missing something obvious, like I needed to add something like "stop program after the 1hr" which of course did not make sense to me as the program would be over after 1 hr, just wanted to make sure
I must have some other issue
Thx
Joe
After thinking further (as your program works fine) could you explain in more detail
why you include the "And" line and the "Else" line. It should be simple but not totally clear to me
Wait 1 hour
Hi Joe,
The And line watches for the KPL button to be turned Off. When the button is turned Off the program will become False and the Else is executed.
Rand
Supose this KPL button was one of 4 buttons with similar programs (just different wait time) and they were all Mutually exclusive. If the first button was pressed ON and the second button was then pressed on, would the first program in button A stop?
No. The KPL will only send button B On and not a button A Off. You could write that into your program though. In your button B program add a line that says Stop program button A.
Rand
Great, thanks! Implemented your suggestions and works great. Man, I keep learning the programming, but see the advantage of using the "Run Else" and your other suggestion.
All is OK now, again, thanks
Joe
