Charts not displaying correct data
I am running v5.0.14. Charts are not displaying correct data. For example, plotting status of a light switch shows no data points on the x axis, and shows a y axis of "0 to 1.05", with a label of "%". Plotting temperature of my zwave thermostat shows no data points, and also has a y axis range from 0 to 1.05, with a label of "current temperature F". Charts have actually not been working right for me for some time now, and I keep hoping that new versions of the firmware/UI will fix the problem. Any pointers on what I might try would be appreciated.
On 11/25/2018 at 6:05 PM, Michel Kohanim said:
@wmcneil,
Does anything work at all with your charts?
I haven't yet found any chart that is displaying correct data.
Bill
Hi Bill,
It looks like chart is working for us, so hopefully the following will help us recreate the problem:
- Is this a problem for both Insteon and Z-Wave?
- can you specify an example device type(s) that is giving you the problem (specific product/model number etc. would be most useful)
- Please DM or post a screen shot of the chart
