danbutter Posted December 15, 2018 Share Posted December 15, 2018 So I have been having intermittent issues with the ISY component not working in HomeAssistant. I get errors like this: 2018-12-14 18:08:45 ERROR (MainThread) [homeassistant.setup] Error during setup of component isy994 Traceback (most recent call last): File “/usr/local/lib/python3.6/site-packages/homeassistant/setup.py”, line 148, in _async_setup_component component.setup, hass, processed_config) # type: ignore File “/usr/local/lib/python3.6/concurrent/futures/thread.py”, line 56, in run result = self.fn(*self.args, **self.kwargs) File “/usr/local/lib/python3.6/site-packages/homeassistant/components/isy994.py”, line 379, in setup use_https=https, tls_ver=tls_version, log=_LOGGER) File “/usr/local/lib/python3.6/site-packages/PyISY/ISY.py”, line 84, in init self.nodes = Nodes(self, xml=self.conn.getNodes()) File “/usr/local/lib/python3.6/site-packages/PyISY/Nodes/init.py”, line 52, in init self.parse(xml) File “/usr/local/lib/python3.6/site-packages/PyISY/Nodes/init.py”, line 238, in parse Group(self, nid, nname, members, controllers), ntype) File “/usr/local/lib/python3.6/site-packages/PyISY/Nodes/group.py”, line 43, in init self.update() File “/usr/local/lib/python3.6/site-packages/PyISY/Nodes/group.py”, line 83, in update if self.parent[m].status > 0: File “/usr/local/lib/python3.6/site-packages/VarEvents/init.py”, line 255, in gt return self._val > other TypeError: ‘>’ not supported between instances of ‘NoneType’ and ‘int’ I have been able to use it while on 5.0.14, but very little and today I tried with a fresh install of Hassio and got the above errors again. Trying to figure out why this is happening and what could be done to resolve it, but nothing has worked for me. Any thoughts on this? And please forgive me if there is something obvious in there...I'm not a programmer. Link to comment
Michel Kohanim Posted December 16, 2018 Share Posted December 16, 2018 @danbutter, I think the issue is that node types are not reported the same way in 5.0.14. It seems that PyISY is considering the type an integer: TypeError: ‘>’ not supported between instances of ‘NoneType’ and ‘int’ With kind regards, Michel Link to comment
danbutter Posted December 16, 2018 Author Share Posted December 16, 2018 That may do it! Not sure if PyISY will be updated before version 5 of the firmware is the default, but it is nice to know. Thanks for the insight. Link to comment
steve9f Posted December 17, 2018 Share Posted December 17, 2018 @danbutter - I'm using v5.0.14 and except for the issues I've reported it is working fine. Looking at the traceback it looks like the issue is with ISY scenes and how PyISY parses the XML that the ISY returns. Do any of the ISY devices or scenes show up and work? To troubleshoot you may want to try changing some of the scene names. Also you can enter this URL from a browser to see the XML that the ISY is returning to see if anything looks unusual (change /isy/ to the name or IP address of your system) http://isy/rest/nodes/?members=true. (here's the ISY REST documentation if you need it). Link to comment
